freezer works fine, main refrigerator does nor get cold, water forms on top shelf of refrigeratorfreezer works fine, main refrigerator does nor get cold, water forms on top shelf of refrigerator
freezer working fine but other side where milk goes is warm and not cooling what should i dofreezer working fine but other side where milk goes is warm and not cooling what should i do
my freezer works perfectly...but my fridge is not working. the light works but the fridge is not cool. whats wrong?my freezer works perfectly...but my fridge is not working. the light works but the fridge is not cool. whats wrong?
My freezer works fine, but the refrigerator section is staying near room temp. I opened the freezer and I don't hear any sort of fan working. There does seem to be quite a bit of frost on it and the nob that makes get the refrigerator get warmer and colder is stuck. Suggestions?
You can't post conmments that contain an email address.
The freezer does all the cooling for both look in the freezer see if there is a lot of frost in the back wall listen for the fan running then reply to me will help
Check to see if the compressor in back is running. It could need a new compressor start device. If it is running it could need a new compressor. The compressor cooling fan could be stalled and the compressor is overheating.
This normally indicates that the gas is low. If compressor runs continuously, but fridge does not cool, then you must have a regas done. Dont let it run like this cos it can damage compressor by overheating.
Sometimes this can happen with fridges that have two evaporator circuits. One circuit controls the freezer and the other controls the chillier part. I can't be sure how your fridge has been configured but the first thing to do is defrost it.
Has the fridge been moved recently or tipped on its side? The compressor has a small amount of oil in it to help it run smoothly and prolong its life. If any of this oil finds its way into the gas circuit it can restrict the calibrated evaporator jet. Defrost the fridge and let it stand for 12 hrs. before restarting it.
This problem can also point to an old and worn out fridge or a fridge that requires re-gassing. Either way its best to buy a new fridge in this case, you can generally tell as the fridge motor will run almost continually and get very, very hot indeed and can become a fire risk.
Lastly, some people put fridges out in a cold garage or store. This can also prevent some fridges from working properly when the garage temperature drops below the temperature that the fridge operates at, it this case the freezer part might also stop working if the temperature of the garage dropped below freezing.
So, Defrost your fridge and let it stand for a while at normal room temperature. Restart the fridge and it should work normally. make sure the temperature dial is set to a reasonable setting, it should work, if not it might be time for a new one.
I understand that your Refridgerator is not getting cold. I do not know if it is just the fridge or the fridge and freezer. If both are getting warm then you need to make sure the compressor is running in the back at the bottom of the fridge it will be humming. If the compressor is not running then nothing is going to get cold.
If the compressor is running then you may have a problem with your fan not running inorder to move around the cold air. Below are two tips that will help you to check both of them.
Check to make sure that the fan in the freezer is running whenever the compressor turns on to cool the unit down. If the fan's not going, warmer moist air from the fridge will make the air duct frost up. The fan needs to be running to blow the cold air into the fridge section.
More likely than not there is a blockage of ice bettween the freezer and the refridgerator. most fridges work to get the freezer cold as a priority.Then the cold freezer air is circulated throughout the rest of the unit to keep the fridge cold. Thats why you may hear a fan running in the fridge unit while the compressor is not on. Unplug and open the doors to warm the inside. Look at the plastic piece bettween the two units and remove. See if there is ice build up and use a hair dryer to melt, dry area out and restart the unit by plugging back in or turning temp dial. Hope this helps.
Condenser is in need of being cleaned badly or your fan motor to cool the condenser is not operating. Compressor is overheating. Removed the panel in back of the refrigerator and clean the condenser so air can freely pass over it for heat removal. Allow compressor to cool off before restarting it.
sound like your compressor ain't running. also you can try putting the thermostat on the highest number and see if there's cooling if not, suspect a defective relay/overload or capacitor.
if you see any mechanisms on the line with an button press it should restart the system.
freezer works fridge not getting cold
