Question about Mitsubishi VS-50607 50" Rear Projection Television
Wavy picture on television screen
I have a 50 inch mitsubishi television. The model is VS-50607. I bought the television in 1998. My television picture shows triple wavy picture on the screen. The sound is good. All other controls work fine. I have disconnected and reconnected all satellite features. I have checked all cables to ensure that everything is connected properly.
  • Anonymous Nov 17, 2008
    Same as described
    Genius:
  • 1,153 Answers
First do the self test on these threads or goto ctechnicians.com
Posted on Dec 29, 2007
I have a Mitsubishi VS 50607 and the sound and color are good, but the screen is jumping. The picture is there but it is almost as if there are two of them. Anyone know of a solution?
Howdy,
CHECK and replace C2P05 100 UFD 16 V OFF PIN 3 OF IC2P01 AND IC2P01 PART # 270P466020 (9-VOLT REGULATOR). BOTH ARE ON THE SIGNAL PCB. REPLACE NO MATTER WHAT.
gOOD lUCK, BIG irish.
Dec 29, 2009 | Mitsubishi VS-50607 50" Rear Projection...
We have a 52 inch rear projection Mitsubishi not sure of the model number and the picture is starting to go blurry with reds and greens at the bottom of the screen
Here is another similar problem with a Mitsubishi Rear Proj. TV and it has some things to try and an estimate if that is the problem.
"Cost of convergence repair is always around $400"
http://en.allexperts.com/q/TV-VCR-Stereo-1749/Mitsubishi-WS55511-Projection-TV-1.htm
You could also try messing around in the menu for convergence adjustments. Usually it will let you adjust at 8 points on the screen.
Oct 26, 2009 | Mitsubishi VS-50607 50" Rear Projection...
How do i clean the projectors and screens of my mitsubishi vs-50607 tv
Pull the Front Bottom panel off under screen will be screws that hol pn screen remove all of them then lift up on screen anf remove it Now you should be where Mirror and Tubes Clean all lenses and mirror with windex.
Sep 19, 2009 | Mitsubishi VS-50607 50" Rear Projection...
I don't know how to get to the mirror and projection guns
the front trim on the tv pops off...there are screws all the way around the screen that you have to take out to remove he screen to get to the tubes and the mirror. once you pop the trim off youll see how easy the rest of it is
Feb 21, 2009 | Mitsubishi VS-50607 50" Rear Projection...
Rolling screen
my screen on my mitsubishi won't stop rolling
Aug 22, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS 50607 Problems
Vertical output IC most likely needs to be re-solderd. However this model is famous for the CRT leaking coolant in the area of the Vertical output IC and corroding the solder. Check for a sticky residule near the Vertical IC indicating a leaky CRT seal.
Apr 09, 2008 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 has Jitter at top of picture- intermitant
IF you would like help diagnosing your set. Go to the enclosed link. They have the service manual for your set and offer unlimited chat support for only 10.99. Just click on your sets manufacturer and you will see your model. Then click on the contact us link and provide your email address and they will email your manual and instructions on how to obtain your support. I am one of their techs
http://servicemanuals.vstore.ca/
Jan 14, 2008 | Mitsubishi VS-50607 50" Rear Projection...
VS 50607 50 inch
Deflection Protect is the problem. You can check C411 and C412 on main board to see if bad. More info ctechnicians.com
Nov 17, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi vs 50607
CHeck 9 V circuit.. Change caps C2p04 & 5.. 100uf 16V & 47uf 50V..Both electrolytics....Directly behind shield on Signal PCB..
Oct 27, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Tv shuts off
You could have a problem in the sweep or main power supply, Bad capacitors on the DM module, they will be all grouped together and have swollen tops, Coolent fluid leaking out of one of the CRT's. If you have no electronic or solid state repair experience, please get a pro to assist you in this repair. Good Luck
Apr 03, 2007 | Mitsubishi VS-50607 50" Rear Projection...
Mitsubishi VS-50607 50" Rear Projection Television Logo
231 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
