Question about Protron PLTV-32 Television
Protron 32c lt32c1p1 screen
There is a foam type of product behind glass in front of picture.[cant touch it but can see it] is falling down starting from top left hand corner ..
can this be fixed is this a defect that is knowen? help please
  • 579 Answers
Can you post a picture of this?
Assuming it hasn't affected the operation (yet), you may want to have it corrected because the many cable connections to the display matrix depend on tiny contacts that use pressure to hold them in place. The foam you are talking about is used to support this pressure.
Posted on Dec 31, 2007
Which software to scan ?
Down load the software for your windows 32 or 64 bit here:
You need the full package to use the scanner.
To scan a picture or document, follow these steps: Step one: Load the item to scan You can scan from the scanner glass or from the ADF (Automatic Document Feeder) tray, if your product has one.
  1. Make sure that the product is connected to the computer.
  2. Turn the product on.
  3. Load the picture or document:
    • Scanner glass : Place the item with the print side down on the scanner glass, and then position it according to the engraved guides around the glass (usually on the right-front corner or the left-front corner). Close the scanner lid.
    • ADF : Place the item into the document feeder tray. The printed side faces up and the top edge goes into the tray first. Adjust the width guides to fit the item. CAUTION: Do not load photos in the ADF. Use the scanner glass instead to prevent damage to photos.
Step two: Scan the item
  1. Open HP Solution Center with one of the following methods:
    • Click Start , click All Programs , click the HP folder, and then click HP Solution Center
    • Double-click the HP Solution Center icon (c01810967.gif ) on your desktop.
  2. If you have more than one HP device installed, click the tab or icon for the product that you are using to scan.
  3. Use one of the following methods to start the scan:
    • For photos or artwork : Click the on-screen Scan Picture "button" in HP Solution Center.
    • For a text document with or without graphics : Click the on-screen Scan Document "button" in HP Solution Center.
    A screen displays to prompt for scan settings. If a settings screen does not display before the scan starts, a preference was set to bypass the prompt. To adjust settings, follow these steps to turn the prompt back on:
    1. Cancel the scan, return to the home screen of HP Solution Center, and then click the Settings option.
    2. For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
    3. Start the scan again.
  4. Read through the various options for the scan settings. Make selections for at least the following items:
    • Scan to: Select your scan destination from the drop-down list.
    • File Type: Select the file type from the drop-down list.
    • ...Save Options...: (available only for certain "Scan to" destinations): For example, if you are saving to a file, click this option to select your Save Location .
    • Show preview...: Select this check box if you want to see a preview before the actual scan.
    c01940398.gifImportant : HP Solution Center software versions vary, depending on the age of your product, and whether you installed updated software after the initial setup. For specific instructions on all the settings the software offers, click the Help button on the home screen or settings screens in HP Solution Center.
  5. Click Scan . The preview screen might display, if you selected an option to show a preview. Use the options on the preview screen to make any desired adjustments before you complete the scan.
After the scan completes, it goes to the destination that you specified in the settings. hpweb_1-2_plus.gifhpweb_1-2_minus.gif Using the scan button on your printer HP recommends that you first get comfortable with using the "Scan Picture" and "Scan Document" on-screen "buttons" in HP Solution Center as explained in the previous steps. By doing this, you determine the scan settings that you use most often, and then you can more easily set up the scan button on your printer. c01940398.gifImportant: Before you use the scan button on your printer, use HP Solution Center to create the settings for that button . For example, you need to decide whether you want a settings prompt screen and a scan preview for each scan. Also, you must create the list of "shortcuts" that you want to display on the front panel of the printer. To get started, click Settings , click Scan Settings , click Button Settings , and then click the tab for Front Panel Scan Buttons . Read through the options, and then create the settings that you want.
Mar 03, 2011 | HP Officejet 4355 All-In-One InkJet...
How change setting to received a digital signal. Look like TV is in Analog mode. I put a coverted BOX and see TV without any problem but without converted Box, I see a white screen with noise. TV Model:...
U want free air DTV?Yes,have a good Digital antena or a roof antena hood up to ur tv.Goto the tv menu.Goto SETUP go down to Ch.setup enter and pick AIR not CABLE.Enter it again for scanning for DTV free air channels.After done the scanning u should have all the free DTV free air channels.
Jan 24, 2011 | Protron PLTV-32 Television
Hi have a protron and can't seem where the plug to connect it is can you please help me
You mean that you don't have the A/C cord running out the back? If not there is a small black hold in the back of the set that you have to plug this type of cord in, if you don't have try places like walmart, home depot, or any electronic store.
Dec 04, 2010 | Protron PLTV-32 Television
Protron PLTV-32C, Model No. LT32C1P1 just went black as we were watching. It did it last night but within seconds the picture came back on. Now it went off and is staying off. Didn't realize at first but...
Mother board Is My Guess That's What's Wrong With Mine And Part Is $250.00 My Problem IS Can I Replace it By Myeslf . I Had Mine looked At .By So Called Professional He Kept it For 8 Months.
Aug 31, 2010 | Protron PLTV-32 Television
My protron tv pltv-32c has no picture but has sound, if you change channels the picture will flash on for about 1 second
If there is sound but no picture, screen is completely dark and the picture is occasionally flashing, then the fault is likely a faulty inverter. In some case a faulty controller board or a defective PSU can cause the same problem.
I summarized the problem here:My LCD TV has sound but no picture.
I posted general procedure to test inverter, PSU and controller board on LCD here : How to test an LCD TV or monitor PSU and inverter.
If screen is not dark, but has blacklight or noise things are different. In that case check connection cables first. Parts that may be defective are main controller board, terminal circuit and tuner board.
Protron parts are available using the link below. Ensure that parts are compatible with your model before purchasing.
ShopJimmy - Protron Parts.
May 15, 2010 | Televison & Video
I have a protron 26" tv. The screen looks dirty it is not on top screen(will not clean off)Looks like a cloud under the surface. Can this befixed? Thanks, Sue
If the surface of your screen is somewhat soft to the touch, you can't do much other than carefully clean it with glass cleaner. Using anything else (Mr. Clean or similar) you may make it worse.
If it is a 'glare-proof' glass, it may or may not be possible to remove it for cleaning.
Mar 17, 2009 | Protron PLTV-32 Television
Pltv-32c black horizontal curved line like sagging seal on top of screen
My Protron 32' has a droopy dust seal at the top of the screen that is getting lower. I took it apart until I got to the screen assembly and decided to look for a professional answer.
Sep 09, 2008 | Protron PLTV-32 Television
Hooking cable to tv
I have a protron tv and unable to hook the cable box staight to the tv. what am I missing.
Jun 14, 2008 | Protron PLTV-32 Television
Shadow on screen
your vertical ciruit is malfunctioning
May 26, 2008 | Protron PLTV-32 Television
Protron PLTV-32 Television Logo
239 people viewed this question
Top Protron Televison & Video Experts
Jaime Hernandez
Are you a Protron Televison and Video Expert? Answer questions, earn points and help others
