I have been trying to download an updated driver for my CANON scanner since my new computer is running Windows XP and apparently does not recognize my "olde" scanner. I have tried several times unsuccessfully to get the necessary driver, but, each time I try to install and run "Driver Detective", it throws back error messages that I cannot get past. All I want/need is the correct driver from CANON so that I can use my scanner (again...!.....). Any help that you could offer would be appreciated. Regards, Doug Carey
Canon CanoScan 4400f -- Havent used it in a while. Have a new PC - set up the scanner using the...
(More)
Canon CanoScan 4400f -- Havent used it in a while. Have a new PC - set up the scanner using the "set up" disk. The light is on the scanner - seems ready to go but it will not scan. (Trying to scan to a PDF doc).
I have a canoscan 8800f. I haven't been able to install it. I've uninstalled and reinstalled a few...
(More)
I have a canoscan 8800f. I haven't been able to install it. I've uninstalled and reinstalled a few times now and it comes up cannot connect with scanner. When I click that box another one comes up saying There is a Twain error, maybe device is not connected. Help!
slides are being scanned in as if they were negatives instead of color. this isn't consistent. it...
(More)
slides are being scanned in as if they were negatives instead of color. this isn't consistent. it will scan slides quite nicely and then all of a sudden start scanning the negative image. I am using a CanoScan 4400F
An image was repeatedly scanned with the Canoscan 4000f and now is always there without it being on...
(More)
An image was repeatedly scanned with the Canoscan 4000f and now is always there without it being on the glass plate. I have uninstalled and reinstalled the software. But to no avail. The image remains visible with every other image I scan.
