Home | Frigidaire | 24 in. FDB1050REC Stainless Steel Bui... | Stays in wash cycle, won...
Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher
Problem for Frigidaire 24 in. FDB1050REC Stainless Steel Built-in...
Stays in wash cycle, won't drain and is leaking
By tooosweet on Oct 20, 2009
stays in wash cycle, won't drain and is leaking from underneath the unit
Solution #1
posted on Oct 20, 2009
Not Rated)
techsarcana
Rank: Wiz
Rating: 78%, 10 votes
check the float.
it is probably stuck in the down position. lift it up.
my float is an "air trap" type and occasionally needs to be cleaned out. grease and junk gets caught up in it. I just reach under with my finger and scoop it out.
if you are having no luck at all, your float may be cracked or something. If so, and you just want to drain your dishwasher, prop up the float and run the dishwasher for a few minutes until it's drained.
Was this helpful?
Yes
No
Popular Solutions for Frigidaire 24 in. FDB1050REC
Questions and Unsolved Problems for Frigidaire 24 in. FDB1050REC
Do you recommend Frigidaire 24 in. FDB1050REC Stainless Steel Built-in Dishwasher?
Answer
Answer
My Frigidaire dishwasher is making a loud pulsating noise when the water is being pumped into the... (More)
Answer
it does drain water seems to be leaking out of the float area
Answer
Hi my dishwasher comes on but does not begin the cycle. Also, there is standing water on the bottom.
Answer
- my 2year old dishwasher Fr.daire 4000 shows "PF" error message and doesnt go ahead into... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Frigidaire 24 in. FDB1050REC...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
