Question about Western Digital WDG1C2500N MyBook Premium 250GB External FireWire USB Harddrive Hard Drive
Windows does not support this CD-R. Please try another dick
Trying to send info to harddrive and receiving this meesage:
0 characters
1 Points
How do i reprogram a harddrive to use it for a laptop
Try this...
Aug 22, 2012 | Hard Drives
You cant open the harddrive only the cd/dvd. The harddrive is a physical component inside of your computer that store your files. If you are having a different problem please try to word it different and I can help
Mar 15, 2011 | LaCie Hard Drives
I have samsung (Model hd501hi) hard disk but it
Hi. Sounds like a problem with the harddrive boot block. Try the torubleshooting steps i provided to you below. If same issue appears after thes troubleshooting then theres a need to replace your Harddrive.
* If you have a floppy try to boot with bootdisk
if you have a bootable windows CD - try booting that then go to the repair console.
have a good one!
Jul 29, 2010 | Samsung 250GB HD250HJ SATA II 300 7200rpm...
Windows 7 is not recognizing and comes up as a cd drive?
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
And remove upper filter and lower filter.Then restart computer then check.
If your harddrive still not recognized then you need to repair your harddrive.Try your harddrive in different computer if it is not recognized on another computer then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Jun 22, 2010 | Buffalo Technology 1TB DRIVESTATION COMBO...
I want to upgrade my computer so I just purchased a maxtor 320 gb harddrive for my computer. I install the new harddrive and put the restore cd and choose the quick format. Computer reformat normally and...
Here are some solution that might help
Option 1 Do a fresh install, used the original Operating system CD
Option 2 Install Norton ghost 2010 or Acronis Migrate on your OLD HDD and make your new HDD as Slave then Clone your Old HDD to the new one..
i hope it help.
Jun 15, 2010 | Hard Drives
XP sees CD/ROM for WD1600JS USB Harddrive. (It's
Try to format the drive!
WARNING! This procedure will erase all files on the drive! Please vote!
Feb 18, 2010 | Western Digital Caviar SE WD1600JS...
Jumper settings
If you try to enter in safe mode or at last known config and the laptop reboots or freezes then you need to reinstall the operating system if you want to use that hard drive on hp pavilion a1000n. The laptops have different chipset and XP requires to be the same or similar chipset to boot properly.
Oct 06, 2009 | Maxtor Hard Drive
Verbatim 250GB portable harddrive is not working on my computer
look at what pops up in your my computer window when you connect it to your computer
May 12, 2009 | Hard Drives
Xp pro repair/reinstall problem
check the connection of your hard disk, its properly conect or not
change the cd of windows and check it,
Sep 28, 2008 | Maxtor Hard Drive
Western Digital WDG1C2500N MyBook Premium 250GB External FireWire USB Harddrive Hard Drive Logo
35 people viewed this question
Top Western Digital Hard Drives Experts
Brian Sullivan
Brian Sullivan
Mark Taylor
Mark Taylor
Are you a Western Digital Hard Drive Expert? Answer questions, earn points and help others
