Brothers fax machine
I am using the the same line for phone and fax. How can i use the fax machine and leave it pluged in the phone line,
when every time when the phone rings the fax machine kickes in.
  • Anonymous Feb 10, 2008
    i have the intelifax 680 and would like to delete the existing telephone numbers and put in new ones; how do i do this?.
  • pat-ron May 03, 2009
    fax and phone on same line, do i need to fix something so my calls can come in? they ring into fax
I have a brothers 560 How do i set it to recieve a fax
Posted on Apr 15, 2009
  • 1,113 Answers
Set to manual answer, user guide available at
http://solutions.brother.com/index-asia.html
Posted on Dec 30, 2007
Hi ive got this bt phone and have it pluged in to a fax phone machine for the answering machine but I cant get it set up as I record the message but when u ring u cant here it
A fax phone answering machine would usually be supplied either with a standard handset or with a modified one-piece phone.
I have owned a number of fax machines and have yet to find one where there is a facility to plug in another standard phone except at the line plug itself.
The fax line plug usually serves as an adapter which provides a standard telephone socket into which a standard phone can be plugged in. It is wired so when making or answering a call, the phone used takes priority over the other and effectively disables it.
I have found the socket adapter provided by the fax line plug isn't suitable for an answering machine and a separate standard socket must be used.
Mar 03, 2015 | Office Equipment & Supplies
How to setup fax in my knoice menolta di3510f .i download user manual but did not get any help related to fax...
Do you have the phone line pluged into the LINE plug not the Telephone Plug?
Is the fax line analog line can not be digital if internet is over the phone line need DSL filter. Use only a 2 line phone line not a four wire line. If you have a two fax input then you can fax and receive faxes at the same time.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Feb 21, 2012 | Office Equipment & Supplies
Can not receive or send faxes???
If your fax machine was working before this could be a line problem. Call your fax number with your cell phone or another phone. If you get a message phone the phone company or it just rings busy its probably a line problem. Another check is to plug your hand set into the wall outlet jack, you should hear the dial tone. If there is no dial tone its also a line problem. Or just try pluging your fax machine in at another location, if it works there you know its a line problem. If its still not working its going to be one of the boards inside the fax machine. Good luck.
May 16, 2010 | Office Equipment & Supplies
Fax is trying to answer my phone
Check the settings of your fax. You have to set it on which ring you wish it to answer. You can't fax without having a hard line phone plugged in. Also, you must have a filter on your fax line if you use DSL.
Oct 13, 2009 | Computers & Internet
Difficulty sending a fax
Hello. Please make sure your telephone line is plugged into the correct outlet.
Most fax machines typically allow you to plug the line (the cord that goes from the fax machine to the wall jack) and and a telephone (the telephone connects to the fax machine).
In order to fax correctly, you must plug the line into the jack with a block (looks like a 'T') marked on it. Do not plug the line into the jack marked with a phone hand set marked on it.
http://gdlp01.c-wss.com/gds/0900002546/PIXMA_MP780_750_Easy_Setup_Instructions_EN.pdf
This shoulds in detail how to connect the line properly. For this printer the line cord must be plugged into the jack labelled "L"
http://gdlp01.c-wss.com/gds/0900002542/PIXMA_MP750_780_Quick_Start_Guide_EN.pdf
This will show you how to actually send the fax. On your PDF View select page 42.
Feb 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Fax machine not sending or receiving
First of all have you pluged a phone into the phone cord of the machine ? Just to verify the phone line.
Is your phone number and ID entered into the machine?
If that information was somehow deleted, that has to be reentered for the fax machine to work. Thats a legal thing.
If the phone line is fine and your ID is properly in the machine and it still is not working then you have a bad fax modem board.
hard to tell you much more without knowing the make or model number.
Apr 22, 2008 | Office Equipment & Supplies
Super G3 Fax Machine by Canon
Can you get a dial tone?... check that you have pluged phone line in to correct socket and that phone/fax line works with standard phone.
Oct 16, 2007 | Office Equipment & Supplies
Able to send fax cannot receive fax
make sure phone line is pluged into line on fax,make sure fax is set auto.there should be a button on fax panel that say's receive mode.
Sep 07, 2007 | Brother IntelliFAX 4750 Plain Paper Laser...
Unable to get my Intellifax 775 to receive any fax's
Make sure that the phone line is pluged into line on fax machine and not ext.
Mar 18, 2007 | Brother IntelliFAX 775 Plain Paper Thermal...
148 people viewed this question
k24674
jasbo
jasbo
Marvin
Marvin
