GE XL1800 1100 Watts Microwave Oven
Problem for GE XL1800 1100 Watts Microwave Oven
Capacitor on bore pump burnt out what can cause
By kmheap on Oct 20, 2009
capacitor on bore pump burnt out what can cause this
Solution #1
posted on Oct 22, 2009
Not Rated)
miket756
Rank: Guru  Kitchen Appliances  Expert
Rating: 85%, 275 votes
a capacitor is nothing more than silver paper raped in plastic in a coil stufted in a can,a cheep one can be + or - 50% of what it sayes it is there is a potassium fluid as an electrolyte in side the can only if its a big one though! if you get to much ripple on the line this will blow the cap....or they just get old and pop off, they will pop off if you overload them as well, there there to sock up ripple's on the line and smooth out the flow of power, in a car they act as an electrical shock absorber and they help to recharge the car ignishion coil faster this also stope the points from burning by stoping the arking,,,
Was this helpful?
Yes
No
Popular Solutions for GE XL1800 1100 Watts Microwave
Questions and Unsolved Problems for GE XL1800 1100 Watts Microwave
Do you recommend GE XL1800 1100 Watts Microwave Oven?
Answer
Answer
no calienta pero fuciona es decir enciende pero no calienta
Answer
on startup the display shows " presionar clock " and leypad is locked
Answer
Doesn't heat food, and sounds much louder than normal. Any suggestions?
Answer
micro, fan on, light on, timer works, NO HEAT
Answer
F3 code comes up on display. tried unplugging and re-plugging. still does not work.
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Microwave Ovens Experts
Top Small Appliance Repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
