Computers & Internet Logo
Posted on Oct 20, 2009
The printer sounds like it's ready to print, but does nothing. Only one of the two lights comes on. It has been working fine and I've done nothing different to it.
Anonymous
Level 1:
Problem Solver:
  • Contributor 19 Answers
  • Posted on Oct 20, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
19
Questions
0
Helped
4943
Points
36
Try turning off the printer, then turning off the computer. Next, restart everything. It might fix your problem. It works for me most of the time. Good luck!
Printer ready light never comes on but printer works
I've had this fault myself, If memory serves me right the control panel ( small though it is) we found to be the problem, once replaced the unit the displayed correctly, weirdly all functions of the printer were still available even though we were unable to see the display.
we were able to get config pages etc, and like you say the indicator lights were working- sort of - when they wanted to.
replace the diplay PWB ( its small and reasonably cheap)
Canon mx860 printer not using ink from PGBK 220
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
The black ink on my Brother DCP-130C won't print and it's a brand new ink cartridge. I thought it was a defected cartridge so I bought another one, same thing. The other 3 colours print ok though....
I have the same problem. Everything on the printer is working just fine. It'll do a test page just fine, so everything's working right. The %$^ thing just won't print. It makes noise like it's printing when you give it a print job, but it spits out blank pages.
My Canon iP90 has been working perfectly but now won't work at all. Nothing. Not a bleep. The green light's on and I've done all the utility checks and they're fine. I've tried turning...
Hi.
If you had done utility check and they are fine, had you try printing on a stand alone not using a computer. if you can print on a stand alone, there is no problem on the hardware side of the printer because u were able to print on a stand alone. you can focus now on the software side by uninstalling and re installing the driver of the printer and that should work.
My brother mfc-240 printer, prints fine from my computer, but this last week when I copy something from my printer, from the top of my printer, its sounds like its copying but nothing shows up, I print a...
You have I am sorry to say a blocked print head. You would have to fit a new one but only a trained engineer could do it as the head is not a separate part and its a pig of a job if you have never done one. Take a tip and take it to the tip and buy a new one. PS, part number is LK2179001
HP LaserJet 4 Printer stopped printing
Try putting a piece of paper in tray 1
HP laserjet 4L wont print from computer
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
The printer prints nothing
maybe the printer is out of ink! or try printing again!
laser printer at home did the same thing, but when i tried it again it was fine!
Printer is ready but nothing prints
Yes, there is a number for Epson printer technical support. Assuming you are in the US or Canada the number is on this web page: http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&category=Products&infoType=Contact&oid=29081&prodoid=37368464 If you?re interested in troubleshooting this further let us know and please don?t forget to rate this posting.
Top HP Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
