Question about Voice Recorders
Olympus foot pedal works backwards
I bought the AS 2300 transcription kit to do transcription and the foot pedal seems to work backward. When you press on the right pedal the transcription fast rewinds and when you push on the left pedal it goes into fast forward. I do not think I have the pedal placed upside down.
4 Suggested Answers
  • 928 Answers
SOURCE: Lost CD for Olympus AS-3000 Transcription kit, need to download
you can go to the link below and just follow the steps to get the right software.
Posted on Nov 16, 2008
  • 5 Answers
SOURCE: DS-2300 recorder and DSS player transcription system
try reinstalling the software. And as for the foot pedals, take a good look at them and see if anything's wrong. If you don't find anything then plug it in and out a couple of times and make sure it's snug. For the phone, i suggest you buy a telerecorder. There about 5.35 and you plug into the microphone jack of your recorder and make sure to press record before each conversation on the phone. So far, that's all i can muster up.
Posted on Dec 31, 2008
  • 207 Answers
SOURCE: Sony BM-147 transcription unit rewind/fast forward problems
Hello just get a really cheap foot pedal replacement at
Posted on Jan 07, 2010
  • 145 Answers
SOURCE: During transcription, when you release the foot
It could be the rewind solenoid is jamed up or there is a switch that comes loose under the tape deck. Either way, it will need to be serviced.
Posted on Nov 03, 2011
0 characters
1 Points
My Olympus RS25 foot switch stopped working.
Yes, you can assume that after 6+ years, the pedals have gone bad and you need new ones.
Jan 08, 2016 | Olympus AS-2300 PC Transcription Kit
Hello your foot pedal don't need drivers but you need for sure a transcription software, the pedal will required a program to work together to control your audio files for example you can get a Olympus transcription software that will be compatible with your pedal, at or you also can used
May 01, 2014 | Olympus AS-2300 PC Transcription Kit
Auto Rewind
Try clicking on Tools, then set auto backspace.
Aug 09, 2012 | Olympus AS-2300 PC Transcription Kit
I have just installed the software for an Olympus DS 2400 and cannot get the foot pedal to work.
The player standard software that comes with your DS 2400 does not support the Olympus wav pedal (RS 27). You need the transcription version of software, the AS 2400 transcription kit (169.95) or, just the software, Player Standard T (99.95).
Jan 25, 2011 | Olympus DS-2400
My foot pedal is not responding
Check out this link at Olympus for PDF manual and software downloads for you product. Just copy and paste into your browser.
Hope this helps, let me know if I can help you with anything else.
Oct 09, 2009 | Olympus AS-2300 PC Transcription Kit
Olympus AS-2000 Dictation Kit - Foot switch doesn't work on Vista
HTML clipboard Olympus AS-2000 is not Vista compatible, you need to upgrade your software, I am not sure which version you have, but I think its version 6 ? You need to upgrade your software from version 6 to 7 (free) and then from version 7 to Standard (also free ) . check your foot pedal if it's RS-23 ( check the back of it ) then you need a new foot pedal ( RS-25 or RS-27 ) , if you have the RS-25 or RS27 you are ok .
Hope this will help
Feb 09, 2009 | Olympus AS-2300 PC Transcription Kit
Olympus AS-2300
The new DS-5000 SW has still got some quirks. The RS-25 is no longer available and I too have had issues with the 27. If your PC has a serial port try the serial plug, I know it is a step backwards but it has worked for me several times. Hope this helps. For now I steer clear of the DS-5000's.
Jul 13, 2008 | Olympus DS-40 Digital Voice Recorder
Foot switch will not respond.
The answer is all in the serial number you use to install the DSS player!
Look carefully and you will see the recorder disk has in my case an [E] printed above the install serial number and the transcription pedal has [T]
Install the same disk with the E the driver is there, the control in Control Panel is there, but the foot switch does not work with the software. Put in the serial number with the [T] and foot switch works first time!
If you uninstall the play and then reinstall with the [T] serial number you do not need to reboot or even unplug the foot switch from the USB.
Feb 13, 2008 | Olympus AS-2300 PC Transcription Kit
Voice Recorders Logo
99 people viewed this question
Top Voice Recorders Experts
David Burkhart
David Burkhart
Are you a Voice Recorder Expert? Answer questions, earn points and help others
