Question about Dell DJ Ditty MP3 Player
Dell COmputer I shut down and now it wont turn on...I took the power supply to test and it is working....And there is a green light on the motherboard that is on..
  • 8,596 Answers
Wrong section - clearing the queue - call Dell
Posted on Jun 13, 2008
Blinking green light, will not power on
Did you have a surge protector that your computer was plugged in if not it may have done something to your power supply good luc hope this helps Merry Christmas
Dec 09, 2017 | HP Pavilion a810n (PP164AA) PC Desktop
Dell optiplex gx520 wont turn on
This is most likely the power supply. You may be able to take it to a store like best buy for testing.
Dec 28, 2017 | Dell OptiPlex GX520 PC Desktop
Dimension 3100 wont turns no power button light there is also an green light on motherboard cpu and power suplly fans working but wont bot up
Contact technical assistance.They will most likely ask you to send it back to repair.
This chart is where I got my conclusion.
Power Light
Problem Description
Suggested Resolution
Solid green
Power is on, and the computer is operating normally. On the desktop computer, a solid green light indicates a network connection.
No corrective action is required.
Blinking green
The computer is in the suspended state (Microsoft® Windows® 2000 and Windows XP).
Press the power button, move the mouse, or press a key on the keyboard to wake the computer.
Blinks green several times and then turns off
A configuration error exists.
Check the diagnostic lights to see if the specific problem is identified.
Solid yellow
The Dell Diagnostics is running a test, or a device on the system board may be faulty or incorrectly installed.
If the Dell Diagnostics is running, allow the testing to complete.
If the computer does not boot, contact Dell for technical assistance.
Blinking yellow
A power supply or system board failure has occurred.
Solid green and a beep code during POST
A problem was detected while the BIOS was executing.
See "Beep Codes" for instructions on diagnosing the beep code. Also, check the diagnostic lights to see if the specific problem is identified.
Solid green power light and no beep code and no video during POST
The monitor or the graphics card may be faulty or incorrectly installed.
Check the diagnostic lights to see if the specific problem is identified. See "Video and Monitor Problems" in your Owner's Manual.
Solid green power light and no beep code but the computer locks up during POST
An integrated system board device may be faulty.
Check the diagnostic lights to see if the specific problem is identified. If the problem is not identified, contact Dell for technical assistance.
Mar 06, 2011 | Dell Dimension 3100 PC Desktop
Power supply to my Inspiron 1525 shows green but when I plug it into the computer, it turns off. Computer will not start at all.
possibly a bad/faulty PSU power supply unit or its leads your computer might be shutting down to protect it from damage test all the leads that are attached to your hard drive from your motherboard and all of your drives cd/dvd 3.1/2 floppy including electrical extensions or just replace them they might be bad/faulty
hope this helps
Nov 28, 2010 | Dell POWER SUPPLY Power Supply
I have a Dell Dimension 5100, after a power outage yestarday, the computer doesnt want to turn on. there is a green light in the motherboard that stays green for as long as i have power conected to the...
The greenlight is probably the UPS [Uninterruptible Power Source]. If the computer was shut down by a normal windows shutdown and the UPS remained plugged into the 120 Volt line and the computer's power supply plugged into the UPS and the UPS NOT turned off, there would still be 5 volt standby voltage applied to the computer's motherboard. ATX type computers never go completely off unless the power supply is turned off or unplugged.
That 5 volts would have to on steadily for the rest of the voltages from the supply to turn on.
If there is a reset button or on off switch at the back where your power cord plugs in toggle it back and forth. You can also try disconnecting the power supply and holding the power button in for about 15 seconds to discharge power.Leave it unplugged for a few minutes. Then try powering it back up again. If those don't work then you might have a bad power supply. They are not hard to replace.
Hope it helps
Nov 20, 2010 | Computers & Internet
What would make my motherboard just 'shut down'? The little green light comes on on the motherboard, but that is it. No fans spin, no HDD spin up. I tried a different power supply, didn't work. I took...
One bad/faulty lead can cause a computer to shut down
test or replace all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Sep 24, 2010 | Intel D945GTP Motherboard
Dell Dimension 5150 PC
this sounds like a motherboard fault, the green light shows power to the board but the orange can indicate that the board has failed
Sep 15, 2008 | Dell Dimension 5150 (DIM515MIN) PC Desktop
Computer wont turn on
So, lets say that you have double checked all cables, and everything is plugged in properly. When you hit the power switch on the case, do you hear the computer start then shut down several seconds later? Does the computer refuse to do anything but power a motherboard LED? Also, did the computer (or the person carrying the computer) bump into anything while moving it? The most minor bump can cause many problems.
I would try replacing the power supply with another one from a working PC, but just to make sure that the power supply unit is the problem. If it isn't, make sure all heatsinks are locked down appropriately and making full contact. Other than that, I don't know what you can do.
Dec 30, 2007 | Computers & Internet
Dell DJ Ditty MP3 Player Logo
26 people viewed this question
Top Dell Audio Players & Recorders Experts
jairo sanchez
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
