Question about Whirlpool WFW8500SR
Door locked just purchased wfw8500sr. Loaded laundry. etc. Door beeped 5 times and shut down. F22 code. door now locked
  • ozzy10 May 25, 2008
    I wd40 the door hinges. Still stop working with code f22
    President:
  • 1,314 Answers
F 22 is the code for door Lock failed after six tries try hitting pause/cancel twice if door unlocks spray lock with wd 40 try again and advise
Posted on Dec 30, 2007
F22 flashing on hot point washing machine
Google it this is not the hotpoint website .
Jan 06, 2017 | Washing Machines
I am getting an F22 error code on my washer. Can anyone tell me what this code means.
Look at the information below and it should clear up your mystery.
F22
DOOR LOCK ERROR
A Door Lock Error occurs if the door cannot be locked. It will try to lock it six times before displaying the error code.
Possible Causes/Procedure ??  Door lock mechanism is broken or removed from door.
??  Door switch/lock unit failure.
1. Unplug washer or disconnect power.
2. Check door switch/lock unit.
3. Check the wire harness connections to the door switch/lock unit and Central Control Unit (CCU)
Feb 01, 2011 | Whirlpool Duet GHW9150P Front Load Washer
DRYER DISPLAYS CODE F22. What does this mean?
"F22" is a door lock issue Press the "Stop" button twice to cancel the cycle if "F22" shows. Check that the washer door is firmly shut--open it and shut it and try again. Make sure there aren't items blocking the closing of the door. Don't overload the basket. Try the cycle again.
Nov 25, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
F22 code ?? duet locks but will not run
"F22" is a door latch failure error code. At the beginning of the wash cycle the door will attempt to lock several times. If the latch fails to lock, the washer shuts down and the error code is displayed.
In some cases, the error code can also be displayed if the CCU goes bad. There is a door latch relay on the board that controls the door locking mechanism. The CCU is not serviceable and must be replaced if defective. In addition, make sure all the connector plugs between the CCU and door latch are connected and snug.
Thank you !!
Jul 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is code F22 on sport duet washer? The locking mechanizm buzzes a little, and when you push start it's locked and stays locked, and you have to stick your hand up in it to unlock it.Thanks.
Thank you !!
Jun 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Door will not open has a code 22
Apr 09, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Error code f22 whirlpool duet wash cycle
f22 is a door lock error try this hit cancel turn your dial to another setting, hit start and once it starts hit cancel again and it should unlock. thats what i did anyway.
If you're getting an F22 error, you will want to check anything to do with the door latch switch.
Mar 14, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F22
I have search for this and found:
This error code indicates that the door is not locking.
Is the washer door firmly shut?
The door must be completely closed for the washer to operate. The door may look as if it's closed, but it may not be latched. Open the door and firmly close it.
Were you washing a large load?
Before you close the washer door, check for laundry items sticking out beyond the door opening. Leave enough space in the washer to allow the clothes to freely tumble. Reduce your load size if needed.
More info can be found on The Whirlpool website:
Whirlpool Front-Loading Washer
Jan 18, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Cannot get washer door to open.
fl_doorseal.jpg To remove the error display, press Pause/Cancel twice.
If Pause/Cancel does not work:
  1. Unplug the washer or disconnect the power for one minute.
  2. Plug in the washer or reconnect the power.
  3. Re-select the cycle and press Start.
NOTE: If the error remains on the display, and all of the other conditions above have been checked, call for service
Dec 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool WFW8500SR Logo
119 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
