Question about Karcher 2500 PSI Pressure Washer
Honda atv wiring
I have installed a 89 honda 125 atv motor on a go cart. both motor and go cart have their own harnesses. The go cart is electric start as is the honda motor. I need serious help wiring it all up
  • Anonymous Jan 10, 2009
    need wiring diagram for 150cc dune buggy...it is a roketa 150 with a honda motor i think
    Master:
  • 619 Answers
You need a starter box w/c includes push swtich , install near the handle put attachement to bolt , wiring to starter red in color to box terminal, black wire connect to box terminal direct battery , install fuse depend to the starter amphere , series to black line positive + .connect green wire to the negative -- from battery to body of the strater or ground bolt. then start it. Thanks
Posted on Jan 01, 2008
WIRING schematic for a Quannon Kymco 2010 125cc I have no wiring harness was given the motor AFTER bike right off and I'm going to put into go cart please help me with a wiring diagram
Hi, P for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Kymco, despair not, for a mere $0 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://circuitswiring.com/circuit-diagrams/17/2011/05/Kymco-Super-8-Wiring-Diagram.jpg
http://www.49ccscoot.com/manuals/Kymco_People_S_50-200_Service_Manual.pdf
http://www.kymcousa.com/owners/onroad/Quannon150.pdf
Kymco Scooter Parts ATVs Scooter Parts Performance Scooter Parts...
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jun 02, 2016 | Kymco Motorcycles
Will not shift gears & light blinking 5 times
500 rubicon trans problem. - ATVConnection.com ATV Enthusiast ...
atvconnection.com/.../honda/117842-500-rubicon-trans-problem.html
Sep 17, 2003 - It has low gear and reverse only will not up shift in any mode. ... Had the same problem with mine, went to my local honda shop and he had ... My lightswould flash and the trans. wouldn't do anything, had to shut ... Code 5 - Angle Sensor System (Motor lock i.e., angle sensor, wiring, .... All times are GMT -5. Honda Electric Shift (ES) Problem Solved
Mar 25, 2012
My Recon 250 ES Shifter Problems
Jun 28, 2010
HONDA 450 ES FOREMAN SHIFTING PROBLEMS - Page 4
Nov 20, 2005
recon 250 es shifting problem
Oct 10, 2004
More results from atvconnection.com
check engine light blink 5 times rsx ATVs Questions ... - Fixya
www.fixya.com > Forum > Tags > check engine light blink 5 times rsx
Question about 2012 Big Red MUV ... Check engine light blinking on Honda big red muv Check engine light slowly blinks ... My 2014 honda foreman 500 es 4x4 neutrallight blinks 4 long times and 2 short times and will not shift into gear.
Honda blink 3 times ATVs Questions & Answers - Fixya
Feb 08, 2016 | Honda 2012 Big Red MUV
On my 2007 Honda Rancher ATV the electric shifter will not shift. It just blinks the neutral sign
did you get water in it ? My sons did the same thing and come to find out there was inside the control box. we replaced the whole head and harness and it took care of the problem
If you need further help, reach me via phone at https://www.6ya.com/expert/allen_b068623c5003aa4b
Oct 13, 2014 | Honda 2012 FourTrax Rancher ES
I need to know how to wire up the motor of a 95 honda prelude h23 vtec
go to a local junk yard and pull the computers and the complte wiring harness out of a car with a vtec, your old computer will not work with that engine you need to replace all the electrical wiring harnesses
Mar 26, 2012 | Honda Prelude Cars & Trucks
Hi have an old 1996 Honda Big Red 300 FW ATV (four wheel motorbike farm use), the starter motor has gone in it. Want to be able to take out the starter motor to get it fixed but can't seem to get it out,...
Some times this job is just patience and persistence. Make sure you've got all the body panels, sections of wiring harness etc out of the way to make it easier.
DISCONNECT THE BATTERY!!!
Starters use VERY HIGH VOLTAGE!
Disconnect the wires from the starter. NOTE these terminals can snap if your too rough.
remove the two mounting bolts at the end nearest to you.
The motor should slide out. If not wriggle it and GENTLY lever it side to side. It should drop out.
Jan 12, 2018 | Honda Accord Cars & Trucks
I dnt know how to hook my sony explode cdx gt 200 to my honda civic hatchback 94
The Honda Civic requires a dash adaptor you need this wiring harness to install the stereo it dont seem a dash adaptor is required for the 94 model you use the cage/sleeve to install the sony in your car you will also need this removal tool and either wire nuts, heat shrink tubing, crimp caps and crimp tool or the common solder and wrap in electrical tape method to connect the wiring harness for the honda to the wiring harness for the stereo
Oct 14, 2010 | Sony XPLOD CDX-GT200 CD Player
Where is starter on 2002 honda crv?
Honda_Cr-V_2001-2006
Starter - Removal & Installation
2.0L Engine
  1. Before servicing the vehicle, refer to the Precautions Section.
  2. Remove or disconnect the following:
    Negative battery cable Starter wiring harness connectors Starter motor
To install:
  1. Install or connect the following:
    Starter motor. Tighten the bolts to 33 ft. lbs. (44 Nm). Starter wiring harness connectors. Tighten the battery cable nut to 79 inch lbs. (9 Nm). Negative battery cable
2.4L Engine
    Negative battery cable Knock sensor connector Starter wiring harness connectors Starter motor
    Fig. Starter mounting
To install:
Starter motor. Tighten the upper bolt to 33 ft. lbs. (44 Nm); the lower bolt to 47 ft. lbs. (64 Nm). Starter wiring harness connectors. Tighten the battery cable nut to 84 inch lbs. (9 Nm). Knock sensor connector Negative battery cable
Hope this help (remember comment and rated this).
Apr 04, 2010 | 2002 Honda CR-V
I have a 2006 Qlink Rodeo 400 atv that has ignition problems. It doesn't always have fire when you cut the key on. I have replaced the ignition coil, starter solenoid and regulator, none of which have...
From the way you have described it, I would say that you've got a bad electrical connection in either the ignition switch, the kill switch, or in one (or more) of the plugs that connect the various ignition components to the wire harness.
Try spraying some electrical contact cleaner (available at RadioShack) in the kill switch and in the ignition switch contacts (if accessible). Also check all of the wire harness electrical connectors for corrosion - especially if your ATV has been (as most are) operated in wet conditions. Unplug each one, clean any corrosion from the connectors, and re-connect. Carefully tighten loose connectors with pliers before re-connecting. Do the same thing where the harness ground attaches to the vehicle chassis.
Nov 05, 2009 | 2008 Qlink XP 200
Karcher 2500 PSI Pressure Washer Logo
455 people viewed this question
Top Karcher Garden Experts
John Trevino
Harold Baxter
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
