DOES THIS ERROR MESSAGE USUALLY CAUSED BY THE NEED TO REPLACE THE IMAGE DRUM.
If the machine is saying "Please Call Service"..You will have to access the Service Call function to determine the exact problem.
Press PROG,*,6
Press PROG to select "service call" mode, then press ENTER.
The Error Message will be displayed.
For example Heater Error, Drum Fuse Error, Inside Fan Error, etc, etc...
**Most common (given m/c age.) would be "Heater Error"...which indicates a problem with the Fuser Unit.....if this is the case you will need to contact local Muratec service for parts.
Hope this helps. Please rate my response.
Thanks.
Have a good day
