Sub-Zero 690 Side by Side Refrigerator
Problem for Sub-Zero 690 Side by Side Refrigerator
Need to change the water filter on my Sub Zero
By brooke411 on Oct 20, 2009
Need to change the water filter on my Sub Zero 690
Solution #1
posted on Oct 23, 2009
Not Rated)
techwurx
Rank: Wiz
Rating: 82%, 16 votes
Hello. The factory indicates your unit required an in-line water filter if your plans were to use one, or the installers added it. There was no indication of an internal filter in the fridge itself. If there was it should be easy to see or find. However this can be good news for you also as your filter (if installed) migt be easy to find and access behind or near the fridge if installed well and a good quality but common form of water filter you can easily replace may have been used, if installed. Otherwise if you have whole-house water filtering already they may not have added any further filtering.
If you can contact who installed your 690 they should be able to tell you where they installed it and what type. If not just have someone follow your water line to the fridge unit, and see what turns up as you make your way along to the place where water connects to the fridge.
http://www.subzero.com/resources/products/downloads/600installguide.pdf
Was this helpful?
Yes
No
Popular Solutions for Sub-Zero 690 Side by Side
Questions and Unsolved Problems for Sub-Zero 690 Side by Side
Do you recommend Sub-Zero 690 Side by Side Refrigerator?
Answer
Answer
brown liquid coming out of the bottom of my subzero side by side refrigerator/freezer. what is the... (More)
Answer
Sub Zero refrig has vacuum condenser indication even after I cleaned the coil and the unit seems to... (More)
Answer
when you open the refrigerator the inside light sometimes comes on and sometimes it dosnt. i... (More)
Answer
Where is the light terminator located in a sub zero 690 freezer?
Answer
I can't get at the light bulbs to change them in my Subzero side by side. Its any older model and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sub-Zero 690 Side by Side...:
Top Refrigerator Experts
Rank: Guru Guru
Solutions: 1205
Experience: installed and repaired audio/video equipment for over 23 years at 2 colleges and 3 businesses.
Ask Me
Find more Refrigerator Experts
Top Refrigerator Repair
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(650) 616-9292
Refrigeration Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
