Question about Ovens
Where is TCO in Whirlpool GBD277PDS1 Oven?
I have a Whirlpool Gold single, electric, built-in, convection oven model #: GBD277PDS1, ser. #: XJ4601006. Yesterday I ran the self cleaning cycle, and now the oven is locked. I can open it with a screwdriver, but as soon as I shut the door it locks again, and I need the screwdriver again to open it. The display works fine (no error code) and the light can be turned on using the light on/off switch, but the oven does not heat or broil, and the light doesn't come on automatically when I open the door. I have tried to reset the oven by switching the power off for up to 10min, but no change occurred - the display showed PF for power failure, and after setting the clock, the display returned to normal, but the oven was still locked and no heat.
Reading through previous cases on this web site, I am guessing it is the Thermal Fuse, or Thermal Cut Off (TCO) that is likely to be the culprit, and I have ordered one (part # 4451442) via eBay ($29.55 incl. shipping). Being on a weekend and shortly before New Year, it might be some days before I get the thing, and I'd like to prepare myself for the installation. Most responses for related oven models indicate the TCO sits at the back of the oven, but one said it was at the back of the control panel. Does anybody know where it is in my particular oven, and do you have any tips for the installation? Many thanks!
Frank
  • Frank Mueller
    Frank Mueller Dec 30, 2007
    Well, I found the TCO under the back panel. Of course it's not a recommended procedure, but since it seems a fair assumption that the only reason for the TCO to fry was that I used the self cleaning cycle, it will take at least a week to get the replacement, and I can't live without an oven for so long, I simply short circuited it, that is I replaces it by a piece of wire.
    Not the over heats again and the light comes on automatically, but it is still locked, and I need a screwdriver to push the looking hook just a quarter inch to the left every time I want to open the lock. I have a hunch that there is a spring on the hook behind the front panel that usually pulls the hook over to the left, but I have not yet opened that part of the oven to check. Any advice on how to tackle this, or part numbers for the spring or any other parts I might need?
    Many thanks
    Frank
  • Frank Mueller
    Frank Mueller Jan 11, 2008
    Just for the record, in case other people encounter a similar problem. A new TCO fixed all electrical problems, ie the oven heated again and the light worked, but it didn't bring back any functionality beyond what short circuiting the TCO had already done. The locking turned out to be a mechanical issue.
    I had to remove the top cover of the stove after taking it out of the cabinet it is built into. This allowed me to access the latch assembly (part # 4451424, $145 at Sears). There is no need to remove the control panel, and luckily I did not need an expensive new latch assembly either, but simply removed the spring that moves the latch into it's resting position, adjusted it a little, and snapped it back in place - it just clicks in. I also put a drop of WD40 on the moving parts of the latch. After that the thing worked again like new.
    I don't know if this problem was at all related to using the self cleaning cycle or unrelated, but the heat could have warped the spring a little, allowed it to move out of position, evaporated any remaining lubricant off the latch assembly, or all of the above.
    President:
  • 1,314 Answers
Frank i like you e mail me at b4829@yahoo.com
Posted on Dec 30, 2007
Door is locked after self cleaning
Most ovens with self-clean cycles have a door lock to keep things closed when it ramps up the the extreme heat levels for cleaning. Usually, the door will stay locked until the thermostat sensor says that the oven is back down at or close to room temperature. If you just finished the cleaning cycle, you'll likely need to wait a while longer.
Nov 24, 2015 | Whirlpool Gold 30 in. Electric Convection...
Whirlpool Gold Electric convection oven does not heat up.
Check for a broken wire or even broken element on top and bottom of unit. To do this, the unit must be unplugged or otherwise removed from power completely, then remove the screws that hold each heating element in place and gently pull out and inspect the wire connections. You should have just enough slack to check them. There should also be just enough slack to strip the wire clean to make the new connection to the heating element.
If the repair has been done before, you may need to fish a new lingth of high temp wire into the location.
Jul 13, 2012 | Whirlpool Ovens
Our home has a Whirlpool Gold built-in convection oven. The home is @5 years old. We've lived here for one year. Today, the display had an error message (E6). After we cleared the error message, the...
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Apr 21, 2017 | Whirlpool GBD307PD Electric Double Oven
Oven wont work after self clean
I have a Whirlpool MOD. RBS275PDB17 single electric self-cleaning oven; although the manual is generic, it specifies, "When the cycle is completed and the oven cools, "End" will appear on the lower oven display and "LOCKED' will disappear" and "To Stop Self-Clean any time: Press UPPER/OFF, LOWER/OFF or OFF/CANCEL. If the oven temperature is too high, the door will remain locked. It will not unlock until the oven cools." Has your oven had time to cool?
Jun 13, 2008 | Whirlpool RBS275PD Electric Single Oven
Whirlpool Oven/Convection Oven Timer Problem
replace the control cpu unit the main control board is deffective
Apr 11, 2008 | Whirlpool RBS305PD Electric Single Oven
Oven not heating
Gallow, Whirlpool put out a service flash on this model concerning the TCO located in the back. Regarding oven wont heat up, control panel normal. It has to do with the TCO (thermostat fuse) located just under the vent in back and it's tripping. Since you had the elements checked out, Im suspecting this TCO. Usually when these thermostats open, they are non resetable and you don't have any heat at all. The best thing to do is check this TCO with a meter. If it shows open, thats probably the culprit. They recommend moving the new TCO over to the left about 6 inches so it is not directly under the vent. You are going to need help pulling the built in out just far enough to get at the TCO. The part number for it is 4450934. The service flash is 22-647. Catriver...post back.
Oct 11, 2006 | Whirlpool RBS305PD Electric Single Oven
Single oven not heating
diydoris, you would have to have someone ohm out the lower element to make sure it is good. If the element is good, then your problem probably is in the TCO. This is a thermostat that sits on the back of the oven that can go bad. You can test this with a meter, if it shows open (no continuity) its bad. Part number for the TC0 is 4450934. Part number for the element is 4448696. Catriver...post back.
Sep 27, 2006 | Whirlpool GBS277PD Electric Single Oven
Ovens Logo
501 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
