Question about Viking 31 in. VGSU101 Gas Cooktop
Electric Cooktop Heating Elements Get Hot, Turn Off, Get Hot, Turn Off
I have a DECU 165-5BSB electric cooktop. When I turn the cooktops heating elements on they will get hot and then turn off--and then get hot agian. Also, when they get hot and I decide to turn it down to a lower setting the heating element will kick off. Is it suppose to do this? The heating elements should stay red hot continuosly correct? What is the problem? Thanks.
    President:
  • 1,314 Answers
No they are made to cycle that way they are halagen and cycle with a sensor dont work like the old coil ones do enegey efficent and hotter than old coils dont use them without a pan on them to reflect heat back to the sensor to prolong their life
Posted on Dec 30, 2007
Burn knobs and fan turn on, lights are on but the burners don't come on and there is no heat.
hello after looking at your wiring diagram the only thing it can be is a blown breaker in your home. half of it works off 120v of the 240v circuit and the heating elements off the other 120v line. so you are only getting half the power to your unit. turn the breakers off and on see if maybe it just tripped.but its not the cooktop. hope this helps please dont forget to rate me thanks ken
Jun 06, 2011 | Jenn-Air JED8430 Electric Cooktop
Jenn Air cooktop JED8430ADB not heating, fan & knob lights work?
Some times a breaker can be partially tripped and not visible . You should try turning the breaker off and on several times.
always unplug electricity before attempting to repair on any electrical appliance
Sep 09, 2017 | Jenn-Air JED8430 Electric Cooktop
All 4 elements suddenly won't heat--worked fine this am. Circuit breaker was tripped. Reset, now lights on knobs come on, but still no heating.
Likely a short in the junction box. Turn off the breaker and open the junction box for inspection. Problem is likely at the cooktop end of the feed from the breaker.
Check voltage at the junction. Should one side of the corcuit be dead, turn off power and call an electrician as the wiring probably has had a short due to staple or nail penetration and would be a fir hazard. Call an electrician if this is the case.
Jan 12, 2010 | Jenn-Air JED8430 Electric Cooktop
Whirlpool ceramic cooktop
Scott,
On each of the heating elements there is a thermostat that does two things. It is a high limit safety thermostat and then a different set of contacts turn on the hot surface light. Unfortunately, you can't just replace that part. You will need to isolate which element it is with a mutimeter and replace the entire element.When you turn one of the units on high you will see a dark line under the glass running 1/2 way across the elements. Those are the thermostats... Find the defective one and the rest is pretty simple to replace
Dec 18, 2008 | Whirlpool 30 in. RC8700 Electric Cooktop
Whirlpool electric Cooktop's one burner not heating
Initially, it could either be:
  • open heating element (most likely);
  • open temperature limiter (least likely);
  • faulty/loose connection/wiring (a possibility).
Please confirm that it is a Whirlpool RCC3024 Electric Cooktop.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information. Good luck and kind regards. Thank you for using FixYa.
Nov 11, 2008 | Whirlpool RCC3024 Electric Cooktop
Smooth surface frigidaire electric cooktop
hi there,
you will need to replace the elements. it's quite common for them to stop functioning.
Sep 30, 2008 | Frigidaire 31 in. GLEC30S9E Electric...
Knob not working and some burners not heating
The switch under that knob is bad.  It's called an infinite switch.  As far as the elements go, first thing to check is for proper voltage (220) to the cooktop.  Let me know what you find.
Oct 19, 2007 | Jenn-Air JED8430 Electric Cooktop
Cannot turn on cooktop.
I have a Kenmore Elite Induction Cooktop and we had some milk boil over and now the cooktop is locked. How do you unlock it?
Aug 30, 2007 | Smeg 24 in. SE2663TC Electric Cooktop
Viking 31 in. VGSU101 Gas Cooktop Logo
171 people viewed this question
Top Viking Cooktops Experts
Dan Webster
Dan Webster
Lawrence Oravetz
Andrew Taylor
Andrew Taylor
Are you a Viking Cooktop Expert? Answer questions, earn points and help others
