Question about GE Profile JT915 Electric Single Oven
Clock flashes and the key pad doesn't work
I came home after the power had been off and the clock was flashing on the oven. When I went to set the clock, nothing on the touchpad works. I have tried opening the breaker for 10 seconds to see if it would reset something but no change. Is there some way to reset the touchpad?
  • amnesia Dec 29, 2007
    None of the buttons on the key pad do anything!
    President:
  • 1,314 Answers
Use stop/clear reset clock then
Posted on Dec 29, 2007
  • robert samples Dec 29, 2007
    ill call ge and ask them when the open ok
No power to neff bottom oven
Bottom oven is directly linked to the clock, If the clock is on but not set ie 0:00 or 12:00 flashing it won't work, set the time (doesn't have to be right, just not flashing) try oven again. If this is not the problem please contact me again and we'll look further. Cheers
Nov 25, 2011 | Neff U1721 Double circotherm Electric Oven
Clock constantly flashes `A` and cannot get top or bottom oven to come on. Have tried resetting the clock but the buttons do not appear to be functioning. The mains power `has` been off due to having a...
It looks like the clock has failed. Try leaving the power off for at least 10 mins, turn it back on at the main switch and then try it. If it still doesn't work Espares can get you a new one. Incidentally, if there is power to the oven, the grill will work even if the clock is not set.
Jun 28, 2011 | Stoves 720EF Electric Double Oven
No name on the oven so presume it's a Europa same as the cooktop. It won't move off 0:00 with automatics on the lefthand side showing.
Hi -
I'm assuming this is an Omega/Creda Europa oven. All you need to do to make the oven work again is set the clock. The 0:00 and "AUTO" will stop flashing and the oven will work again. You didn't specify a model number, but you should be able to set the clock as follows:
1. Hold down the two buttons on the left-hand side under the clock display. One should have a symbol of a bell and the other, a symbol of a cookpot (not a cookpot and 'STOP').
2. While still holding both of these buttons, use the + and - buttons to set the clock to the correct time. The clock needs to be set in 24 hour format.
If this doesn't work, look for the buttons under the clock with the bell symbol and the cookpot symbol. Hold both of these buttons in and use the + and - buttons to set the clock.
If this doesn't work or your clock doesn't have these buttons, let me know and I'll check for other possible methods of setting the clock on Europa ovens. If you can find the model number it would assist me greatly. This should be on a sticker on the rim of the oven and can only be seen when the oven door is open - possibly at the bottom. The model number should be something like 40-1, 60-1 or 66-1.
If you can't find the model number, please let me know how many buttons there are in total below the clock and which symbols are written above each button and the order from left to right. I will then be able to provide the correct instructions for your oven.
Hope this helps.
Regards,
BElectric
Apr 18, 2011 | Ovens
Power went off now oven wont work. The timer keeps flashing
If you look at the timer control you will see a button that is used to set the clock. most likely the oven will not operate until the time is set. Press the clock button, set the time and either press start or the clock button again.
Aug 29, 2010 | Ovens
The timer clock has gone off.
to stop the clock area from flashing and for it to display time, the time must be set.
Apr 09, 2009 | Ovens
F2,F5,F7 message
MAYTAG
Range/Stove/Oven Fault Codes Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (usually the touch pad)* F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or bad oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Feb 07, 2009 | Maytag MEW5527B Electric Single Oven
Oven not heating but the fan is working and clock flashing auto
You need to rest the timer. to get it off auto,otherwise the oven will not work.
Refer to your instructions.
Oct 20, 2008 | Neff B1421 Electric Single Oven
Gaggenau EB 270/271 Electric Clock
To set the clock:
1. Press the clock key 3 items until the hr/min icon flash.
2. Press the + or - key until it come to your desired time.
3. Press the confirmation (check) key.
You have your time.
If not, call the service support.
Aug 21, 2008 | Gaggenau EB 270/271 Electric Single Oven
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
GE Profile JT915 Electric Single Oven Logo
1,045 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
