Question about HP Compaq FP 7317 17" Flat Panel LCD Monitor
Black screen The monitor keeps cutting off , like it's in sleep mode or power save mode. I can unplund it for a few secounds and it will go back to working ?
  • Anonymous Feb 13, 2008
    monitor goes blank; disconnect monitor from computer and unplug monitor from power; reconnect power and computer and monitor work for a while; sometimes minutes, other times days.
  • Anonymous Mar 24, 2009
    my screen goes on n off
    n refuse to start ..
    even if the comp is on .. the screen goes on n off..
    ive test evrything
    with / without graphic card.
    upgrade / downgrade the systems..
    re-install comp
    n all
I had the same problem and I found one florescent bulb which was dying. This monitor has internal protection and will shut off back light, but monitor still works just no light. You need to replace baclight bulbs.
Posted on May 27, 2008
  • 472 Answers
Faulty capacitors in the power supply will cause this to happen.
The capacitors will be sending out bad current to the controller board and give you the results you are seeing.
Take it to your local TV repair shop and get them to change the capacitors, it should not cost alot to have it done.
Hope it helps =)
Posted on Apr 09, 2008
When I try to bring my LCD monitor out of sleep it just comes up a dim lighted screen and cannot see desk top. I put my PC in sleep mode then wake it back up and monitor is perfectly fine? how can I
I suspect the monitor. For the sake of troubleshooting: Try another monitor for a few days. If you have the same issue, we will know it is the video card.
Sep 16, 2014 | Computers & Internet
Monitor switch always return to Sleeo Mode
You can open the VGA cable and connect it again, sometimes there are two or three vga ports behind your cpu, connect the right one. Try it, if not success, change the cable.
Mar 11, 2017 | LG W2252TQ Monitor
Enable Hibernation in Windows 7 Starter on Samsung N150
Sleep mode on a Windows 7 PC saves power without you having to turn your computer off and without losing any work. This option cuts the power to your monitor, powers down the hard drive and pauses all functions until you awaken the computer from hibernation. Whether you have a laptop, desktop or workstation, putting your computer into sleep mode will lower your electric bill and save money! Click the "Start" button in the lower left corner of your desktop. In the lower right corner of the Start menu, next to the "Shut Down" button, is a button labeled with a small, right-pointing arrow. Mouse over the arrow. The Shut Down menu appears. Point at "Sleep" and click on this option. Your Windows 7 computer goes into sleep mode. Wake your computer from sleep mode by jiggling the mouse. There may be a delay of a few seconds before your hardware powers on. All of your open programs are still open and your work is intact, just as you left it before the computer entered sleep mode. Configure your Windows 7 PC to go into sleep mode automatically when it is not used for a certain amount of time. Click "Start" and select "Control Panel." Click "System and Security." Click "Power Options." A menu opens. Click on "Choose when the computer sleeps" and select the number of minutes of inactivity. You can also set a separate time interval to put your monitor into sleep mode. If you set both to 10 minutes, then your PC and monitor will automatically go into sleep mode after 10 minutes of inactivity Your Computer in sleep mode b> First, save all of your work. Information in computer memory is not saved while your computer is on standby. From the Start menu, select Settings, then Control Panel, then Power Management. Click Standby Beside When I Push the Power Button. Push the Power button. b> Automatically Putting Your Computer on Standby b> Save all work before leaving your computer. From the Start menu, select Settings, then Control Panel. Double-click Power Management. Set the times that you want your system to go on standby, to shut off the monitor and to shut off the hard disks. Click OK. Your computer will go on standby according to the schedule you have entered. b> Putting Your Computer in Hibernation b> From the Start menu, select Settings, then Control Panel. Double-click Power Settings. Click on the Advanced tab. At the When I Push the Power Button On My Computer screen, click Hibernate. Click the Power button. Hope this helps.
Jan 16, 2013 | Samsung N150 Series Netbook
Windows sleep mode problems
Dec 21, 2012 | Computers & Internet
Won't go into sleep mode
Which operating system ?
A menu opens.
Hope this helps.
Nov 25, 2012 | Dell Factory Refurbished 4700-HH79N81...
VA902b monitor will flash on for half a second and then go black even though the light shows green. Didn't have any problems with the monitor until updates were automatically installed for windows....
The "sleep mode" is probably set too low.. or a "power saving" mode is set too cut off too quick..(sorry for the low information) .. I am at work on an Apple.. geeezzzz :(
Jun 06, 2017 | ViewSonic VA902B 19" LCD Monitor
Why does my HP vs17 monitor screen keep going to blank black screen like it turned off but did'nt.....blue power button light is still on? Everything is running but no picture.....keeps happening everytime...
this old monitor has 2 issues.
1: it has CCFL tubes that love to burn out (backlamps)
most this old are long go, yell,dim.,blinking or DEAD.
2: push the menu button on front of mon. turn off power saver.
3: if the PC goes to sleep, or hibernete mode (parked)
then that is 100% normal
if you dont like feature then go to windows control panel
click power, ICON and turn off all monitor sleep /hibernate modes.
that assumes windows, no OS stated.
if the lamps are dead,
use flash light pointed to sceen, see data. ? bingo for bad CCFT tubes.
as seen here
http://www.pcdied.com/monitors.html#flashlighttest
Jan 12, 2018 | HP Vs17 17" LCD Flat Panel Monitor
Monitor going to sleep
juanmgerman0, Connect SDM-X82 to known-good pc that has all sleep mode, power-save mode disabled. (turned-off) If unit still goes to black screen mode, then look at the "date of Manufacture" on rear of unit and let me know if you see "2002 -2004" as the year produced. Retrevo lists unit as "time to retire". Power supply may be going into shut-down mode having detected a problem with itself or the CCFL inverter circuit. 12fixlouie
Aug 19, 2010 | Sony DELUXEPRO SDM-X82 18.1" LCD Monitor
My problem is the same, it happens when i'm in fullscreen.
go in and fix the power settings under screen saver disable sleep mode on drives and monitor disable sleep mode on every thing just use blank screen instead
bes fix 4 ya
Jul 29, 2009 | Gateway GT4010 (RBGT4010) PC Desktop
Monitor keep going into "sleep" mode
Check the power setting in control panel of windows. If you have a monitor from another computer swap them and see if the problem stays with the computer or monitor.
May 12, 2009 | Dell Dimension 3100 PC Desktop
HP Compaq FP 7317 17" Flat Panel LCD Monitor Logo
672 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
