Question about Texas Instruments TI-84 Plus Calculator
List dimensions when i do ln reg and put in my lists it says i have a dimension problem, i checked the lists and they have the same number of entries i dont know what else can be wrong...
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 56 Answers
This is a pretty vague problem but not much of a problem. Your actualy plotting device of your stat plot is under your "y=". But before you do that you need to hit the stat button right next to the blue apps button. Then hit edit. These are your stat datalist dimensions - 1.gif. If you are trying to add data in you should notice what list they are under. (top of the screen L1, L2, ect.) You should also make sure that the number of data adds up for your two list. Now that you have done that you can go to "2nd" then hit "y=". If you don't want to graph your stat plots just make sure they all sat plot... off by hitting enter on the one that says that it is on. Now if you want one on hit enter and make sure your lists from your data match up with your stat plot. You can hit enter and see what one you need. they are above the 1, 2, 3, etc key. Hope this works. If all else fails you can clear your calculator by pressing "2nd", "+", "7", "1", "2". This will turn off all your stat plots if you have trouble understandsing this. But most importnat make sure your L1 and L2 match up on your stat plot with your list under your stat edit. If you don't understand this just i can help you out some more
Posted on Jan 10, 2008
Ariston instruction manual
A bit hard to come up with dimensions or user instruction manual without knowing the refrigerator type or model number.
Please visit this Aristron website and select the model number listed to download the user manual or check the dimensions. Cooking Appliances Kitchen Appliances Dishwashers Download Manuals
Aug 29, 2014 | Refrigerators
My Casio fx-9750GII wont dispay a table
The message dimension error usually refers to instances where two lists do not have the same dimensions (number of elements)
I checked and the calculator gives condition error. Check the type of function you are creating a table for. Choose the type y=
Nov 05, 2012 | Casio Calculator Graphing FX 9750GII...
I installed a new hard drive into a dell dimensions 2350 and I am trying to install windows xp from disc. it says "please wait while setup formats the partition" and the bar is at 2% for an hour?...
First try selecting "Quick Format" when you get to the place where you format the drive.
If that fails there is a program called diskpart.exe in C:\Windows\System32. Put your drive in a functional computer.
To do this you have to know the size of your drive.
Run diskpart.exe. Then enter "List Disk".
This file YOUR drive in the list. You identify it by it's size. If the drive can not be identified by size then EXIT.
The enter "Select Disk A" where A is the NUMBER of YOUR drive from the list "List Disk" showed you.
WARNING! Under NO circumstance select disk 0!
Then enter "Clean".
Then take the drive and put it back in your computer.
It will make it through the XP installation process after that.
Hope this helps.
Jul 23, 2011 | Dell Dimension 2350 PC Desktop
For ti 84+ HOW do I solve the error indication
Certain mathematical entities have so called dimensions: A list has a dimension, which is the number of elements in the list. Matrices also have dimensions which are the number of rows, and the number of columns.
If you are doing paired variable statistics, the data is in two lists and if the number of elements in one list is not equal to the number of elements of the the other, the dimension are not matched (equal), and calculator will give you dimension mismatch in any calculation that involves BOTH list.
The problem with your question is that you do not say what you were trying to do and I will have to guess or read your mind.
I suggest you reset the RAM to erase any old configuration that may be interfering with what you want to do.
  1. Press [2nd] [+] to access (MEM)ory management.
  2. Press [7:Reset][1:All ram][2:Reset]
  3. Calculator answers with "Ram Cleared" message.
  4. Press [CLEAR] to erase the message.
  5. Restart what you were doing (statistics, or graphs)
Jun 19, 2010 | Texas Instruments TI-84 Plus Calculator
What is DIM mismatch? It won't let me do anything!
Mar 04, 2010 | Texas Instruments TI-83 Plus Calculator
I want to install a memory upgrade into a dell pc dimension E510
Go to Crucial.com put in your model number then they will list the memory you need and the highest amount of memory your pc takes. And Shipping is usually Free.
Sep 18, 2009 | Dell Dimension E510 PC Desktop
Invalid dimension
Most of the time when you get the "invalid dimenstion" error, either list 1 or list 2 is longer than the other. Check your data and make sure you there are not more numbers in one list than in the other.
Another posssibility is that when you tried to clear list one, you may have deleted list one. If this is the case, you can get the column labeled list one back by pressing stat, then select set up editor form that menu which will take you back to the home screen. Press enter and the word done will appear. Now when you go back to stat edit, list one will be there.
Aug 29, 2009 | Texas Instruments TI-84 Plus Calculator
Wireless router with dimension 3000
It seems that you have Dell Desktop computer, unless you requested a wireless card to be put into the computer, it would not come with one. Just like stang_1 mentioned, you should check your network adapters to see if your wireless card is listed. Also since it is a desktop, you can check the back of it to see if you have an Antenna sticking out of it. That would indicate that you have a wireless card on the PCI slot. And if that is the case and you do not see it listed in the network connections, check the Device Manager and make sure that the drivers are installed properly.
Apr 14, 2009 | Dell Dimension 3000 PC Desktop
Motherboard ID
Try running Belarc advisor to check the motherboard manufacturer.
Lots of companies use Intel chipsets
Nov 16, 2007 | Computers & Internet
Texas Instruments TI-84 Plus Calculator Logo
189 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
