Question about Frigidaire 24 in. FDB126RB Built-in Dishwasher
I need to replace the Door Springs
I have a Frigidaire dishwasher (model # FDR252RBB0|) and I need to replace the door springs.
I've got the parts but I can't find anything online that has helped me install the new springs.
Can someone help me please?
  • Anonymous Mar 23, 2014
    White-westinghouse dishwasher model SU22ONXR1. How to replace door springs.
    President:
  • 1,314 Answers
If you just need to install springs pull the bottom kickplate can do it there only two screws
Posted on Dec 30, 2007
How do I adjust the springs on the door of a Frigidaire dishwasher Model # FDB24?
Springs run down both sides of the dishwasher from the door hinge to the back leg area of the frame at the bottom leg area. You adjust the spring/door tension but moving the spring to different holes in the frame area. Going one direction in the holes will loosen the door, going the other direction will make the door tighter.
Mar 26, 2015 | Frigidaire Dishwashers
Broken door spring on kitchenaid dishwasher
Please read our safety information before attempting any testing or repairs. Before repairing the door springs, unplug the dishwasher or shut off the power at the fuse box or breaker panel to avoid an electrical shock hazard.
The door opens and closes with the aid of springs. If the springs (or the cables that connect them on some dishwashers) break, the door will drop open hard. The door will also be heavier when closing. If the door drops open, it may also bend the door hinges out of shape resulting in a door that does not close properly and possibly leaks.
When replacing the springs or cables, all of them should be replaced at the same time.
To access the door springs and cables remove the lower panel located beneath the door. The panel is usually held in place with two screws either above or below the panel. It may be necessary to first open the door to the dishwasher to get to the screws over the panel, then close the door to remove the panel.
There are two common types of spring assemblies. One type connects the springs from a hook on the dishwasher cabinet of to a tang on the door hinge .
May 07, 2008 | Dishwashers
Door falls open, no restraints
Yes, I've fixed a few, and was unable to fix a few. You may need to remove the whole cover of the dishwasher to get to the insides. You should find either the springs are broken on both sides of the bottom of the door, or even more likely, the plastic parts between the springs and the body or the door have broken. The parts can be ordered from "Sears Parts" on the inter-net. You will need to provide the model number to look them up.
Be blessed.
May 21, 2013 | Frigidaire 24 in. FDB510LC Free-standing...
Need more tension on door. added a aftermerket raise panel door kit. added weight to door is about 25 pounds.
Are you sure 25 pounds seems like a lot? Anyway take off the bottom panels under the door. UNPLUG FIRST! you will see the springs on each side usually you can adjust them tighter by moving the springs into slots/holes futher back towards the wall. If this won't work on your model, take a spring off and go to your local hardware store and buy new springs that are shorter or have more tension.
Mar 23, 2010 | Frigidaire 24 in. PLD2850 Built-in...
Frigidaire dishwasher Fdb4315lfc2 door
There are two springs that support the door and control the rate it falls and stops at. They are located at the base of the door. One on the left side and one on the right.
Slide the machine out. Usually held with screws directly into the underside of the counter. You may have to lower the unit by turning the feet. Most of the time you can just slide it out.
Look on the sides and you will see the springs. One or both will have come off. They should be hooked to a slot in the door hinge and the other end to a hole in the frame of the unit.
Over time they can become over stretched. If you put them back and the door drops too quickly and stops with a jar then replace the springs. Spring are springs so you can get them at a hardware store or parts supplier.
Hope this helps. Please rate this answer if it helps you.
Mar 10, 2010 | Frigidaire 24 in. FDB1050REC Stainless...
Door opens all the way down does not stop
The door is very simple as you already know. The only adjustment is with the springs. If they are in place and the door still drops too low (and probably very quickly stopping with a jar) then the springs are over stretched. This does happen over time.
Take one off and go to a hardware store. Look for ones slightly shorter to replace. Springs are springs so if they fit you are good to go. Or go to a parts shop and purchase replacement parts.
Please rate if this helps you.
Mar 09, 2010 | Frigidaire 24 in. FDB1050RE Built-in...
Have problem with door on Frigidaire Electolux dishwasher. Door "falls open" rather than eases open.
there is a spring that connects to the side of the door (both right and left) than connects to the holes on the bottom of the dishwasher frame. These springs have either fallen off or broken. To see the area where they connect you will need to remove the very bottom panels below the door. Look at the frame where the leg height adjustment screws are and you will see several holes in the frame the springs will most likely be right there and just need to be reconnected to the frame itself. If the springs are not there then the springs will more than likely be right at the bottom left and right side of the doors. These springs should be set in the 3rd hole back from the front if the door drop is still too fast set the spring further back on the frame.
Hope this helped
Dave
Feb 04, 2010 | Electrolux Frigidaire Professional Series...
I have a frigidaire quiet clean I dishwasher model # MDB124BFS2 - the spring on the door has broken. How do I replace it?
Hi, The easiest way would be to pull the d/w washer out of the cabinet about 8". Try removing the kick plate below the door and see if you can access the springs ok. Here is the part # 154430501. I would replace both springs while you are in there.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 04, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Dishwasher door spring
remove the lower kickplate open the door hook the spring on the hooked part of the door and then in one of the holes in the frame youll see
Jan 31, 2009 | Dishwashers
The door on my dishwasher will not close
There are a few problems that can occur with the diswasher door assembly. These usually involve the latching mechanism, the door seal, the counterbalance spring assembly or the hinges. 1) The door latch plate can occasionally become out of alignment. Some door latch plates are adjustable, some aren't. If yours is adjustable, try loosening the retaining screws and repositioning the plate. It's trial-and-error, so have a lot of patience. If this doesn't work, then the latch needs replacing.
2) A new dishwasher or a newly installed door seal can be difficult to close for a while until the seal softens and compresses over time. You can try adjusting the latch, if possible.
3) If the door feels unusually heavy, there could be a problem with the counterbalance spring assembly. These counterbalance assemblies allow the door to open and close easier and are held by two springs. On some dishwasher models, holes are positioned in line so you can re-tension the springs by moving the spring hooks to other tensioning holes. If any of these springs break, they will need to be replaced as a pair.
4) The door hinges might be bent. They can seldom be adequately fixed and should be replaced.
hope this helps
Nov 24, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Frigidaire 24 in. FDB126RB Built-in Dishwasher Logo
636 people viewed this question
Top Frigidaire Dishwashers Experts
Carmen Mikulic
Mike
Are you a Frigidaire Dishwasher Expert? Answer questions, earn points and help others
