top loader hoover 600mb automatic washing machine will fill water to right level but willnot wash or spin. Timer turns normal and also drains water out.
Comments:
Oct 21, 2009
- the motor on this machine is a brushless motor squirel cage type.
If this machine has a motor that uses brushes, check them for damage, wear, or weak/distorted springs.
Comments:
Oct 21, 2009
- The first thing to check on an AC induction motor is to see if it is getting proper voltage. If ok, then look for a phase shifting capacitor if equipped (motor will not start, but hum loudly if the capacitor is bad). If it doesn't hum, then suspect a faulty relay or solid state equivalent. If the motor is rated for 230 volts, not 115 volts, check for 230 volts at the power socket (read with a voltmeter across the two slanted slots. As you have already surmised, I'm not familiar with this brand of washer, but with your help, we may be able to get you running again.
Was this helpful?
Yes
No
Popular Solutions for Hoover HTC243 Top Load Washer
We moved house and now our Hoover 200m machine does not work at all, seems like a fuse or something...
(More)
We moved house and now our Hoover 200m machine does not work at all, seems like a fuse or something similar as there is no power to it at all now
