Question about Whirlpool Calypso GVW9959K Top Load Washer
Whirlpool top load washer- tub will not keep balance
Water filling inside and outside tub, because tub will not maintain balance. Machine is level. Checked springs- found smaller rear spring off frame replaced which re-centered the tub, but as soon as I run it, even empty it becomes cockeyed again. Help?
    President:
  • 1,314 Answers
Did you take out the shipping bolts when you bought it if you did then its the universal joint under the agitatot or in it more likely
Posted on Dec 30, 2007
My Whirlpool Ultimate Care II Washer doesn't stop filling with water
If this only happens when the machine is turned on,the tube from the tub to the water level switch is pinched or broken. If the clear plastic tube is not pinched or broken,the water level switch in the control console is bad. If the machine lets water through when it is in the OFF position,the water valve where the hoses connect are bad.
Dec 27, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
My Whirlpool Cabrio is so out of whack that it will not wash a single load without going of balance. I am generally a Mr Fixit, so with the help of some web advice I opened the top and I removed the wash...
yes the balance ring is supposed to be filled with glycol..... these washers cannot runn bulky loades or single articles of clothing.... if the load your running is not coating the drum evenly the all the weight is going to be on one side of the tub which is going to spin vigrously uneven,,,
also cabrio washer top lids are very slanted which means u cant level the washer by using the top of cabinet .... put level on each side use split of cabinet top to bottom of cabinet as your straight edge for placement of level ... theb level front to back and left to right and check other side ... if it checks out level....then take a clear cup fill 3/4 with water and place 2 feet infront of washer and start washer spin cycle if you see any ripples in water in cup while washer is spinning the reinforce floor joist under washer ...
Jan 31, 2011 | Whirlpool Cabrio WTW6600SBT Top Load...
My washer wont aloud my water to go insidethe washer
If the washer makes a humming sound, but no water goes in, and there is no other action, the water shut-off valve is off (outside the washer), or the pipes are frozen.
For top-load washers: If the washer starts agitating immediately without filling the tub, the water level switch is bad (falsely senses the tub is full already) or the water level sensing hose plugged up while there was water in the machine, and it has still has pressure inside it to fool the level switch.
Nov 27, 2010 | Maytag Washing Machines
Whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
May 10, 2010 | Whirlpool LTE6234D Top Load Stacked...
Washer continues to fill and overflows
start to fill the washer,then turn it off,if water still keeps filling you have a bad inlet water valve,if it stops then check the water level water hose from the water level switch to the side of the outer tub-mike
Jan 30, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool washing machine (WTW5200SQ0) temp problem
I turn off the cold water during the fill up, and then turn it back on after it has filled. I hate this washer too because of that.
Jan 07, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
Water comming from under washer front side
 Check the following:
Are the fill hoses tight?
Are the fill hose washers properly seated?
Is the drain hose clamp properly installed?
 Is the sink or drain clogged? Sink and standpipe must be able to handle 17 gal. (64 L) of water per minute.
 Is water deflecting off the tub ring or the load? Center the tub before starting the washer. The wash load should be balanced and not overloaded. The fill or spray rinses can deflect off the load. The washer must be level. The front feet should be properly installed and the nuts tightened. Reset the
rear leveling legs (if needed).
Mar 22, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washer Fills/Drains at the same time
check that the drain hose saises above the water level of the tub. I f the hose does not come above the water level, the water will just drain right out
Dec 01, 2008 | Whirlpool LSB6200KQ Top Load Washer
You can hear water still in the washer - not inside the tub where you put the clothes but inside the washer machine.
I believe you are referring to a GE top loading washer. GE uses a liquid filled balance ring around the top of the washer to help compensate for off balance load. The sound is perfectly normal.
Aug 28, 2008 | GE Washing Machines
Just moved. New washer leaks water and appears tub is off center
CHECK THE BALANCE SPRING LOCATED (INSIDE LEFT REAR OF MACHINE). IF SPRING IS OFF IT CAN CAUSE THE TUB TO TILT TOWARD THE FRONT AND THE TUB FILL HOOD WILL NOT BE OVER THE TUB DURING FILLING OR THE TUB WILL BE ERATIC DURING THE SPIN WHEN RINSE WATER IS SPAYING IN CAUSE ING THE WATER TO MISS THE TUB AND SPRAY OUTSIDE. THIS IS COMMON IF THE UNIT HAS BEEN MOVED OR PLACED ON IT'S SIDE OR CARRIED AT EXTREME ANGLE.
Jan 17, 2008 | Whirlpool LSN1000LW Top Load Washer
Whirlpool Calypso GVW9959K Top Load Washer Logo
147 people viewed this question
Dan Webster
Dan Webster
Sal De
