Question about Denon AVR-1506 Receiver
Sound Stops My receiver (Denon AVR 1506) seems to be overheating. After I've turned it on the first time for the day it will work fine for abour an hour then the sound will go out, nothing else changes. I can switch the listening mode it is in and I will get sound for about a minute, same thing if I turn the unit off then back on. If I leave it off for an extended period of time it will agin work normally for about an hour. If this is overheating how do I fix it? If it's not, what is it?
    President:
  • 4,402 Answers
Disconnect everything from the unit and see if it still does it.
if it does i would check the output transistor (ic).
Posted on Jan 25, 2008
No surround sound in TV mode
Surround sound will only work if the source signal is coded as surround. Many older TV broadcast programs are stereo only. If your surround sound is working with a DVD or blu-ray then the broadcast source is the problem
Dec 02, 2013 | Denon AVR-1506 Receiver
The green light flashes when power is turned on and then flashes red and turns off. Can this be reset ?
what do i do when my DENON AVR-1506 turns on then flashes red and turns off?
Mar 08, 2011 | Denon AVR-1506 Receiver
Unable to get my sub to work with my Denon AVR 1506 Receiver
Did it ever work? Are you certain the sub is getting a signal. It has to be defined. How about the speaker levels adjustment? Did that work? Give us a clue.
Jan 28, 2010 | Denon AVR-1506 Receiver
1 Solution for denon 1506
have the same deal go'ing on here, one of the cables were shorting out and never could figure it out
Apr 15, 2009 | Denon AVR-1508 Receiver
No video on Denon avr 688
After days of frustration the real problem was with the cable box. It needed a firmware update. Following forum advice I disconnected the cable box power cord for a few minutes, reconnected it, allowed the cable box to reinitialize. Turned off receiver and TV. Turned TV back on and set it to HDMI connection, turned on receiver and all worked fine. Great picture and sound.( Needed to buy an optical cable to go from the cable box to the receiver to get sound from the speaker system. )--the dirtybird
Apr 14, 2009 | Denon AVR-3300 Receiver
Connecting 2 sub woofers to denon 1506 receiver
Most receivers only handle one sub at a time. If you are deadset on connecting two, you might want to consider how much power your receiver will give to each if you split the signal then determine the power of each sub. If the subs aren't the same you can be sure they will sound strange.
If they are identical and your receiver has enough power to handle them both, examine the connection the subs use to connect to the receiver and split the connection by buying a splitter at a local radioshack.
You will probably be better off using the better of the two subs instead of having both connected. Your sound quality will be more balanced and clear when it comes to bass.
Mar 03, 2009 | Denon AVR-1506 Receiver
Denon AVR 1506
Try this, turn off the unit and remove the AC power cord from the electrical outlet, Hold the AUTO button and PCM button and plug the unit back into the electrical outlet, if the display starts flashing with 1 second intervals then release the 2 buttons, this initialized the microprocessor
Feb 09, 2009 | Denon AVR-1506 Receiver
Problem with Denon AVR 1508 in DTS NEO 6 Format
WHAT TYPE OF AUDIO CONNECTION IS USED FRON THE SAT TO THE DENON? IT HAS BEEN MY EXPERIENCE THAT YOU MUST CHECK THE OUT PUT FORMAT OF THE SAT OR EVEN USE A COAXIAL OR OPTICAL CABLE AND ON THE FRONT OF THE DENON PRESS THE INPUT MODE BUTTON TO DISPLAY AUTO
Sep 24, 2008 | Denon AVR-1506 Receiver
Protection on display
disconnect everything from the unit and see if it still does it.
Jan 25, 2008 | Denon AVR-1506 Receiver
Denon AVR-1506 Receiver Logo
135 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
