Question about Hotpoint HSS25GFP Side by Side Refrigerator
Evapartor fan motor
Where i sthis located at
    Sergeant:
  • 263 Answers
Http://www.repairclinic.com/0001.asp there is all about yours and video diagrams for locations and parts
Posted on Dec 30, 2007
How to replace fan motor
Which fan motor you are asking for, you have 3 fan motors built in on you vehicle, 1. Main drive radiator fan has no motor, 2. Condenser or auxillay fan motor located at front right side of radiator assy. Evaporator motor located under your dash board assy.
May 24, 2014 | 2007 Nissan Frontier SE Crew Cab
1989 toyota celica convertible passenger power window goes down & not up
take off the door panels and try the switch from the other door and see if that works. if so then the switch is bad.
Sep 28, 2012 | Toyota Celica Cars & Trucks
My refrigerator makes a loud humming sound.
sounds like its bearings in a fan motor probably your evaporator fan motor it is located behind the plastic shell in your refrig. you have to take out the lining and then you will see the fan, evapartor and etc.
Jul 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
The fan in the 1st compartment freezer is making a loud noise - what might me the problem?
sounds like your evapartor fan is going out? This is located inside the plastic shell inside your freezer.
Jul 06, 2010 | Sub-Zero Bottom Freezer Refrigerator
Air Cond. Freezeup problem
Sounds like one of two things either you have an airflow problem or low on charge. have you cleaned the filter? Cleaned the outside condeser coil? The evapartor coil? Is the inside fan blowing air out? to clean the outside condenser coil take a stiff hair brush and go up and down on the coil not sideways. Then use a water hose to clean out the dirt and etc. next take the brush and clean the inside oil go up and down not sideways because you will bend the fins on the coil. I would use a squrite bottle to rinse it with. I hope this helps!!!
Jul 08, 2010 | Frigidaire FAA065M7A Air Conditioner
My freezer is cold with some ice at the back and water drops by the door the fridge is not hot but it is not cold either why?
sound like your evapartor coil is freezing up. Does the evaporator fan run? you should be able to hear it when you open up the door. if it not then thats your problem. if it is running you may have an airflow problems I would first clean the condenser coil on the back of the box down at the bottom I use a still hair brush and a vaccum cleaner to clean all the dirt and gunk out. The first thing your going to have to do is let the evapartor coil thaw out and you need to unplug the unit to do this or take a hair dyer on low and thaw it out. If this doesn't do it I would take a look at the defrost timer and heater. Good luck and I hope this helps. Check to see if your fan is running on the condenser also.
Jul 02, 2010 | Maytag MTB1891ARW 18 cu. ft. Top Mount...
We have a sub zero 550 fridge with freezer on bottom. Our freezer is not holding temperature. There is grinding sound when we open like a fan scraping.
its problably your evapartor fan and it located in the back of the freezer you will have to take out the plastic lining on the freezer to access the fan not real hard just take some time. once you have it out plug it in and see if the fan is hitting. I hoped I helped you.
Jun 30, 2010 | Sub-Zero Bottom Freezer Refrigerator
Freezer builds ice on inside wall not cold in refrigerator whats worng
your evapartor is freezing up. you have an airflow problem or low on freon. I would first clean the condeser which is on the back of the unit by the compressor you will see a fan and a coil I use a brush and vaccum cleaner to clean it. You will have to turn off the unit to unfreeze the coil. You might listen in the freezer to see if you hear the fan running. if it is not the fan is located behind the plastic sheild in the freezer. sounds like the defrost timer or defrost heater is not working,
Jun 30, 2010 | Refrigerators
Our freezer continues to forms frost/ice along inner backside and is not freezing our foods properly. we have defrosted it over and over yet problem continues
sounds like the evapartor is freezing up. Have you tried cleaning the condesor coil on the back of the unit. It is located by the compressor take a vaccum cleaner and clean the lint and dirt off of it. then see if this does the trick if it doesn't I would check the defrost timer it is inside the box behind the plastic liner.
Jun 23, 2010 | Kenmore 54662 / 54664 / 54669 Side by Side...
Protection
doe sthis do it on all dvd or just 1 is fan out on it in well vented place
Jan 27, 2008 | Samsung HT-DS610 System
Hotpoint HSS25GFP Side by Side Refrigerator Logo
66 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
