Can you help.......
I dont know how to do this.....and i am having such a hard time fig. out.
thanks!!!
    New Friend:
  • 127 Answers
I can help you out, just describe your problem a bitmore.
Posted on Dec 29, 2007
How to remove ford taurus window switch
Door Panels
Print
REMOVAL & INSTALLATION
See Figures 1 through 8
This procedure applies to both the front and rear door panels.
Fig. Fig. 1: Remove the cover from behind the inside door handle by gently pulling it out to release the retaining tabs
Fig. Fig. 2: Remove the pull cup retaining screw cover and...
Fig. Fig. 3: ... remove the retaining screw from the cup and lift the cup straight up out of the door panel
Fig. Fig. 4: Remove the two sail panel/speaker grille retaining screws and...
Fig. Fig. 5: ... remove the panel/grille from the door
Fig. Fig. 6: The door panel is retained to the door by 11 retaining clips
Fig. Fig. 7: Carefully lift the door panel off of the door and...
Fig. Fig. 8: ... detach the electrical connectors from the switches and remove the panel from the vehicle
  1. Remove the cover behind the inside door handle.
  2. Remove the screw from the bottom of the pull cup retaining the front door trim panel to the front door.
  3. Remove the two screws retaining the sail panel/speaker grille assembly and remove the panel/grille from the door.
  4. Remove the three screws retaining the front door trim panel to the front door.
Do not attempt to remove more than one pushpin at a time.
  1. Use a suitable tool to remove the pushpins from the door.
  2. Carefully lift the door panel away from the door.
  3. Detach the electrical connectors as necessary and remove the panel from the door.
To install:
  1. Installation is the reverse of removal.
Aug 15, 2012 | 1998 Ford Taurus
Wiring diagram for 1999 ford mustang
Fig. Headlamps (1999) - ZOOM LINK
Check links...
Fig. Courtesy Lamps, Page 01 (1999)
Fig. Courtesy Lamps, Page 02 (1999, Coupe, Convertible/Hard Top)
Fig. Courtesy Lamps, Page 03 (1999, Convertible/Soft Top)
Fig. Courtesy Lamps, Page 04 (1999)
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day
Feb 15, 2012 | Ford Mustang Cars & Trucks
How to replace a dome light switch on a 1999 for mustang
Yes, you have one in each door frame;
Check links...
Yes, check frame door;
Check links...
Vacuum hose diagram for 89 honda prelude
Hi there:
I suggest check this links, according with the fuel system:
- Fig. 62: Vacuum hose routing-1989 carbureted Prelude (except California)
- Fig. 63: Vacuum hose routing-1989 carbureted Prelude (California)
- Fig. 64: Emission component schematic-1989 carbureted Prelude
- Fig. 65: Vacuum hose routing-1989 fuel injected Prelude
Hope this helps; also keep in mind that your feedback is important and I will appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Dec 21, 2011 | 1989 Honda Prelude
I need a vacuum diagram for my 1984 cj7 jeeep
I suggest check this image redirect links:
- Fig. 8: 1980-86 California 6-258 with automatic transmission
Fig. 9: 1980-86 California 6-258 with manual transmission
- Fig. 10: 1980-86 Canadian 6-258 with automatic or manual transmission
Dec 20, 2011 | Jeep Cars & Trucks
I need to know were the thermostat is located
According with your type engine...
Fig. 1: Thermostat and gasket-4A-F engine
Fig. 2: Thermostat and gasket-4A-GE engine
Fig. 3: Thermostat and gasket-4A-FE and 7A-FE engines
Keep in mind that tTe thermostat is installed on the inlet side of the water pump. Its purpose is to prevent overheating of the coolant by controlling the flow into the engine from the radiator.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Nov 15, 2011 | 1994 Toyota Corolla
I need a belt diagram on a 87 f150 ford truck
Please let me know if you have any questions, and thanks for using FixYa.
Fig. Fig. 13: Drive belts-4.9L EFI engine
Fig. Fig. 14: Drive belts-5.0L and 5.8L engines
Fig. Fig. 15: Drive belt adjustments on the 4.9L, 5.0L and 5.8L EFI engines
Apr 19, 2011 | Ford F-150 Cars & Trucks
Location of thermostat
Ford Tempo/Topaz 1984-1994 Repair Guide
Fig. 1: Engine thermostat-2.0L engine
Fig. 2: Engine thermostat-2.3L engine
Fig. 3: Engine thermostat-3.0L engine
Fig. 4:
Remove the harness from the housing
Fig. 5: With the retaining bolts removed, take the thermostat and housing out of the engine compartment, and place on a clean surface
Fig. 6: Remove the thermostat from the housing. Remember the direction in which it was installed
I really hope helps with this (remember rated this help) Good luck.
Jan 07, 2010 | 1991 Mercury Topaz 4 Door
Where are the timing marks for a 03 lancer es
Review this diagrams:
Fig. Timing belt sprocket alignment -3.5L engine
Fig. Align the timing belt sprockets as indicated before removing the timing belt-1.5L engine
Fig. Align the timing belt sprockets as indicated before removing the timing belt-1995-00 1.5L engine
Fig. Camshaft and crankshaft sprocket alignment for proper timing belt replacement-1.8L and 2.0L SOHC engines
Fig. Silent shaft sprocket alignment marks for belt replacement-1.8L and 2.0L SOHC engines
I hope help you with this; remeber rated this help.
Aug 24, 2009 | Mitsubishi Lancer Cars & Trucks
 Grubhead
Grubhead
