GE DBSR453EBWW / DBSR453EBCC Electric Dryer
Problem for GE DBSR453EBWW / DBSR453EBCC Electric Dryer
Maytag Model: MDE9806AYW suddenly stopped
By sassylaughli on Oct 20, 2009
Maytag Model: MDE9806AYW suddenly stopped "Heating"- Blows/Runs great still!! Just absolutely No HEAT I have cleaned all vents/hoses, checked breakers etc. Also took the entire "Heating Element " to be "checked" and it is working fine they say. Any suggestions would be Greatly Appreciated
Solution #1
posted on Oct 20, 2009
Not Rated)
twinman007
Rank: Guru
Rating: 89%, 34 votes
theres will be various over temperature devices ( small round ceramic devices with a metal cap with two push on connectors ) these will swich off the supply to the heater , these can and often fail , quite cheap to replace , always take note of what one goes where as they have different temerature ratings ( usually printed or stamped on them )
hope this helps
Was this helpful?
Yes
No
Popular Solutions for GE DBSR453EBWW / DBSR453EBCC
Questions and Unsolved Problems for GE DBSR453EBWW / DBSR453EBCC
Do you recommend GE DBSR453EBWW / DBSR453EBCC Electric Dryer?
Answer
Answer
The upper plastic trim piece that goes around the drum inside the door (drum bearing?) on my on my... (More)
Answer
takes two cycles to dry. settings correct. has low heat
Answer
GE dryer DBSR453EB2WW Timer doesn't work. Dryer functions , but timer doesn't shut-down as should if... (More)
Answer
Dryer makes buzzing noise when I try to start. NOthing is it. What are the possible problems.
Answer
The knob seems striped will not turn and pliers will not turn it. The dryer was running perfect... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For GE DBSR453EBWW / DBSR453EBCC...:
Top Dryer Experts
Rank: Guru Guru
Solutions: 14889
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Dryer Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
