Question about Dryers
Dryer won't turn on
The dryer part of my stacked washer/dryer will not come on. Yesterday evening I set a load to dry, assuming that it would shut off when it was done like it always has. When I woke up this morning the dryer was still running! I removed the load and tried to start it again - nothing happened. I flipped the breaker and it came on. Started another load and came back to check it in an hour, dryer had cut off again. Tried to restart but nothing happened. Flipped the breaker switch again and it came on. I'm guessing it is some sort of electrical problem but the same breaker switch controls my washer (which is fine) and the light in the laundry room (also fine). Any ideas?
  • honeyfixlist Sep 09, 2008
    My maytag dryer kicked the circuit in my basement a few times and after resetting it worked fine. Now the light is on in the tumbler but nothing on the control board.
    Problem Solver:
  • 14 Answers
The heater element on the drier has gone short circuit.without a model no. its impossible to give more me on dazzie@blueyonder for more assistance.
Posted on Dec 29, 2007
Auto dry not working on stack washer/dryer
If your dryer isn't drying, check for a simple fix first. Make sure the dryer is set on a high heat setting, empty the lint filter, and reduce the size of the load by taking out some items.
Also, check to make sure the clothes are not dripping when you put them in the dryer and make sure a dryer sheet is not blocking the vent.
It could also be a problem with your dryer not being level or the vent hose is clogged. For more tips and solutions, check out these troubleshooting steps in Dryer not drying.
Sep 12, 2012 | Kenmore 98702 Stacked Washer/Dryer
Dryer will not heat-up, clothes stay wet even after hours of drying! gas is on, gas bill payed,turning needlessly, no drying.
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
Nov 13, 2009 | Frigidaire FEX831CS Top Load Stacked...
Gas dryer heats fine but shuts down before the drying cycle is over taking longer to dry clothes. Lint trap and exhaust tube cleaned out.
You are going to most likely need a vent cleaning. The dryer is getting too hot and shutting off because it is not exhausting good.
Apr 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Spin cycle lasts indefinately
the spin cylce in washer, did not shut off?soundslike an issue with the timer itself, no servicing htetimer strictly replace, as far as teh time in the dryer, i would check for clogged/kinked dryer vent, biggest issue with any dryer, innadequate vent
Nov 25, 2008 | Kenmore 98702 Stacked Washer/Dryer
Thin twin stacked washer/dryer...dryer won't stay on
My twin stacking whirlpool washer/dry. The timer switch kicks on but does not dry clothes kicks off after 5 mins but, clothes still wet.
Nov 12, 2008 | Whirlpool LTE5243D Top Load Stacked...
Maytag haevy duty stack washer dryer unit model # SE1000 series 06
I hope you got this fixed by now but if not I'll put in my 2 cents.. I assume that your dryer is electric and not gas. Assuming that is true then you probably have an open heater element.. similar to this used in electric stoves... There may also be other components that could have failed and in so doing, disabled power to that element. Could be a contactor or temp switch/thermistor.. Hope this helps and that you've already solved the problem...
Jul 05, 2008 | Maytag LSE7806A Top Load Stacked...
Water keeps running.......
i assume washer never starts running if not suspect water level switch or connection hose also be sure small hose to switch is not plugged or mashed flat even a small hole in hose may cause it not to get pressure to tell switch drum is full ..if washer does start running suspect bad water valve may not be shutting off
May 19, 2008 | Frigidaire FEX831CS Top Load Stacked...
Dryer Problem
SHUT OFF THE BREAKER to the unit then open the panel (3 Screws) that is in between the washer and Dryer you will see your venting hose ther remove the flex vent pipe from the exh duct closes Turn back on the pwr and run a load in the dryer see if it drys ok if you wil need your vent to the outside cleaned out
Jan 23, 2008 | Kenmore 88752 Top Load Stacked Washer /...
Dryers Logo
114 people viewed this question
Top Dryers Experts
