Question about Sony Cyber-shot DSC-M2 Digital Camera
C:32:01 & system error, Blue screen
Hi ,
I'm getting on my screen c:32:01 or & system error with blue screen or without.I have tried all the troubleshooting tips on the manual, it still wont work.I've pulled the battery out for 24hrs, tried the on&off ,tried to reset.Nothing seems to work it.All other features and camera mode works fine.Thanks for any help i can get.Franco
  • 641 Answers
SOURCE: memory stick error
Look at the bottom of the memory card slot, you probably bent one or more of the contactor pins. Use a small screwdriver and carefully try to straight the bent pin then carefully put the memory card back in. From now on, use a USB cable for downloading your pictures and don't pull the card out anymore as the pin is probably weaker than before and can break. Good luck
Posted on Sep 04, 2007
  • 326 Answers
SOURCE: Format Error C:13:01 on Sony DSC-W7
Please try with the new memory stick. Regards, Arpi
Posted on Mar 27, 2007
SOURCE: File Error
I also have the same problem
Posted on Feb 10, 2008
SOURCE: File Error
i have the same problem too! ughh it so annyoing.
Posted on Apr 06, 2008
  • 89 Answers
SOURCE: cat knocked my digital camera off the desk now the screen is blue
Try reseting your camera
  1. Locate the RESET button on the camera.
  2. Use a pointed object (like a ballpoint pen) to press and hold the RESET button for 2-3 seconds.
  3. After 2-3 seconds has elapsed, release the RESET button.
  4. if you dont have a reset button try the manul reset below
Performing a manual power reset
  1. Turn off the camera.
  2. Remove the battery pack.
  3. Remove the button-sized lithium battery.
  4. Allow the camera to remain without power for 30 seconds.
  5. Reinsert the button-sized lithium battery.
  6. Reinsert the battery pack.
  7. Turn on the camera.
If your camera is experiencing an issue and the issue is not resolved by performing the appropriate reset procedure above, then service may be required. hope this helps
Posted on Aug 02, 2009
  • 57 Answers
SOURCE: the flash wont work on the camera...still
1. Even if the flash is set to always ON, the flash will still not work in the following circumstances:
* When shooting MPEG movies. * When shooting in the Twilight or Handheld Twilight mode. * If shooting with the Burst or Multi Burst mode. * Shooting with Sweep Panorama. * Shooting with the Fireworks or High Sensitivity mode. * If an external flash is connected.
2. You can also Initialize the Camera. Touch the Home option. Then, select the Main Settings and then, select the Main Setting2 option. Then, select the Initialize option to OK.
3. You can also try to select the Flash Forced option to ON. The Flash Forced option is located under the Flash Settings.
Posted on Feb 17, 2010
0 characters
1 Points
When I try to view the photos taken I get a blue screen on most of them with 'file error' shown on screen. How do I overcome this?
Format memory card, format option is available in camera menu and if this dose not solve problem, replace memory card.
Jan 20, 2010 | Sony Cyber-shot DSC-W30 Digital Camera
Polaroid i733 digital camera
Initially, let's try a hard reset by removing the battery. Let it be without batteries for a couple of minutes to about an hour. Thereafter re-insert battery and try again. Additionally, pls verify that the battery is fully charged
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Jun 07, 2008 | Digital Cameras
PC Cam Driver install - blue screen driver error after restart
Try to update your outdated or corrupted drivers with a <a href="">driver update tool</a>.
Apr 27, 2009 | iClick Intova IC800 Digital Camera
Blue screen access error when viewing or taking pics or vids
Please try to take as many pictures from memory stick as you can then format memory stick through format option in setup.
Hope this will resolve this blue access issue.
You can use another memory stick like 1GB in this camera.
Mar 13, 2009 | Sony Cyber-shot DSC-S700 Digital Camera
Blue screen and error code
control panel problem... could be lens port... but needs to go to repair
Dec 03, 2008 | Olympus Stylus 710 Digital Camera
5f 08, 5e 02, Olympus 710, Help!
hi alexandra olympus cameras are know for having a few lens problems when ever a blue screen comes on the camera is faulty it sounds to me like you have some dirt or dust in the lens i have seen this problem a few times hope u get it sorted goodluck
Sep 28, 2008 | Olympus Stylus 710 Digital Camera
Olympus Stylus 710 Error: D: 5f08 5f0a 5e02 5f08
i have the same problem with my camera it show 5foa 5f08 5e02 with the blue screen
Sep 24, 2008 | Olympus Stylus 710 Digital Camera
Hi, I have an Olympus FE-150 which kept coming up with the error XD picture error on a blue screen, which would then delete the photos I had taken. Now the camera has totally just seized up and will do...
Once you delete the photos you have to format the camera each time, which I hadn't done.I contacted Olympus cameras and they sent me a program to retrieve my photos.
Mar 26, 2008 | Digital Cameras
Lens Error on my Photosmart M525
The lens extension mechanism is probably damaged,
or the circuit that drives it.
It could also be caused by poor batteries or bad
battery connection
see my other posts on the same topic.
Jan 19, 2008 | Olympus Stylus 700 / 700 Digital Camera
Card Error
Camera says card error-blank blue screen behind it and it won't let me do anything.
Nov 16, 2007 | Fuji FinePix A340 Digital Camera
Sony Cyber-shot DSC-M2 Digital Camera Logo
321 people viewed this question
Top Sony Digital Cameras Experts
Larry Spears
Larry Spears
Vish Iyer
Vish Iyer
Rick Johnson
Rick Johnson
Are you a Sony Digital Camera Expert? Answer questions, earn points and help others
