sometimes the nozzle holes get plugged above the brushes. if you remove the solution tank you will see where the trigger rod connect to the resevoir to release solution. also you should see that a small amount of solution in the top of the resevoir if no water then the resevoir needs replacement and you are not gettingn the plunger pushed up far enouhg to release solution.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Hoover Floormate H3000 Upright
When you push the solution button nothing comes out, only puts out water just a little if you pump...
(More)
When you push the solution button nothing comes out, only puts out water just a little if you pump the button.
