Question about Whirlpool LHW0050PQ Front Load Washer
Whirlpool LHW0050PQ Front Loading Washer VERY NOISY during spin cycle
My Whirlpool front loader makes a slapping/banging noise during spin cycle. The house/floor is level on concrete slab foundation. The belt is fine. Lots of vibration and noise during spin cycle. Not over loaded or under loaded. Use correct laundry detergent and settings...any ideas?
  • 9 more comments
  • Anonymous Mar 14, 2014
    washer makes a very load sound during the spin cycle. Also, cycle status lights are out of synch?
  • Anonymous Mar 17, 2014
    HOW LEVEL A WHIRLPOOL FRONT LOADING WASHER
  • Anonymous Mar 19, 2014
    The washer started making a load noise during the spin cycle even w/o clothes.I can move the tub front to back by hand.Can it be the bearings?
  • Anonymous Mar 22, 2014
    during spin cycle washer makes terrible banging noise like unbalanced but is not
  • Anonymous Mar 25, 2014
    how do I add vinegar to the load I have a front loader HE washer
  • Anonymous Mar 26, 2014
    noisy
  • Anonymous Mar 30, 2014
    while in the spin cycle the washer is very noisy
    makes a lot of noisey and wont balance during spin
  • Anonymous Mar 31, 2014
    loud banging spin cycle leaking from bottom
    bottom leaking and loud banging during spin
    loud banging spin and leaking from bottom
    Genius:
  • 1,554 Answers
Remove the top access panel 3 screws in top rear.
now look around and push on the drum from top
it has suspension shocks and springs like your car they should resist any movements.
look/wiggle the concrete balance blocks , no cracks or loose.
inside the tub are the arm solid /not loose.
run it with the top open what do you see/hear and where
look under the rubber flap in front did anything get under the tub
Posted on Mar 04, 2008
Whirlpool Duet Washer Model WFW9400SZ00 bangs only during spin cycle.
Yes you are exactly right, these bearings have failed & are causing the noise very common problem with whirlpool front loaders. very expensive to repair worth while looking into replacing instead of repairing as it will just happen again.The new LG machines are the best in my opinion.
Feb 06, 2012 | Whirlpool duet Washing Machines
My front loader washing machine is make a banging sound during spin cycle
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Apr 16, 2011 | Kenmore Washing Machines
Whirlpool WFS1276AW bangs loudly when rinsing and spinning
Check out this tip I wrote about the noise and vibration that front load washers can make..
heatman101
Sep 06, 2010 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool Front Load Washer (LHW0050PQ) not spinning
Use a quarter inch nut driver to remove the bottom panel. A tech sheet should be under there that will give diagnostics. Open the pump filter and check for objects.616c06e.jpgea4423e.jpgfb90284.jpg
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Jul 12, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Loud banging noise during rinse
Most noises from a washing machine occur during the rinse or spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.This will solve your problem.
Apr 08, 2010 | Whirlpool GHW9100L Front Load Washer
We heard a large BANG and now it is so noisy
The rear bearing in most front loaders lasts an average of 5 years under normal usage. Spin the drum manually with your hand and seee if it is nice and smooth and quiet. If the bearing is ok it is probable that 1 of the shocks is broken on the bottom.
Mar 18, 2010 | Washing Machines
Banging noise during spin cycle
weight not distabuted in washer move cloths around so its even
Feb 10, 2010 | Washing Machines
Loud clanking noise during spin cycle. Will not
If it is a front loader, then remove the rear panel, remove the belt, and soin drum by hand, if it feels rough, or is noisy and rumbling, then the main drum bearings have failed.
This is a major repair.
Feb 01, 2010 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool Front Loader machine will not drain
On our LHW0050PQ the "Done" light stays on solid-- it does not blink, so on yours it may be indicating a malfunction, either in the electronic control or a problem with the pump. As VersaStyle suggested, you can check the connection to the pump, check for power to that connection and also look for evidence the impeller might have a pin or something stuck in it. If it used to work and it made a lot of noise before failing, I would suspect an object lodged in the impeller or a seized bearing.
(I find that when I use non-HE detergent, the pump gets really noisy, making sounds like the bearing is going out. I have a solution for that, but your situation sounds like a complete failure somewhere.)
Feb 19, 2009 | Whirlpool LHW0050PQ Front Load Washer
WASHER MAKES A BANGING NOISE WHEN SPINNING
Try redistributing the wet clothes for better 'balance'.
Jan 08, 2009 | Whirlpool LHW0050PQ Front Load Washer
Whirlpool LHW0050PQ Front Load Washer Logo
1,032 people viewed this question
Sal De
Marvin
Marvin
Gerry Harvey
Gerry Harvey
