Question about Sony PlayStation 2 Slimline Console
Power failuer power failure
Hey slims do HAVE FANS assho*e
Posted on Feb 14, 2008
    New Friend:
  • 127 Answers
Check the outlet, power cord and ps2. Also, PS2 slims dont have fans so it could just be overheated, so just wait an hour or so, should fix it.
Posted on Dec 29, 2007
Code 1475 1471 1477 1472 and wont start sonetimes
This should give you some problems to look up:
P1471 EVAP Emission Control LDP Circuit Short to B+
Possible failuer of OBD II Fault code P1472
  • Signal line short
  • Sensor failure
P1472 EVAP Emission Control LDP Circuit Short to Ground
P1475 EVAP Emission Control LDP Circuit Malfunction/Signal Circuit Open
P1477 EVAP Emission Control LDP Circuit Malfunction
Apr 07, 2015 | Cars & Trucks
1400 suzuki intruder electrical failure
The clutch safety switch on the handle bars might be bad. I changed mine when I had this problem and had no problems after this. Hope this helps.
May 03, 2012 | 1995 Suzuki VS 1400 Intruder
Why is my built-in camera on phone giving error failure to start preview
Hi
Try setting the camera to its default settings.
Remove the phone battery and load it again.
Feb 28, 2012 | LG P509 Cell Phone
Jeep 89 dianostic scanner
the renault designed (pre1991)jeep computer systems were very simple and diagnostic codes were non existant diagnosis is by scan data not codes common failuer parts were oxygen sensors and crank sensors throttle position sensors were failure prone also BUT need to be ajusted correctly to ork properly
Feb 16, 2010 | 1989 Jeep Cherokee
Volvo s80 2.9 brake failure stop safely asap , srs
Try removing the battery for half an hour or so and then reconnecting (check you have all your radio codes etc before you do this).
Jan 09, 2010 | 1999 Volvo S80
The red power light is consistently blinking and will not turn green
power board failuer - known problem, contact b and w service for collection.
Oct 16, 2009 | B&W Bowers and Wilkins Zeppelin iPod Music...
Lr code
HI, this is an electric motor issue. its possible that it is windings failuer or , the hall sensor may be bad. It is recommend to cal for service in this case. the motor will need to be replaced.
**NOTE(((It is also possible that your issue will be a Motor Control Board issue as well. you can confirm the issue by manually rotating the drum. If the drum can be turned easily with very little resistance, this will confirm MCB failure. if there is considerible resistance when manually turning the drum, this will lead to the motor failure.))
Jul 26, 2009 | Maytag Neptune MAH5500B Front Load Washer
Air ride will not pump up.
OK, this will happen if you have air line failuer or , the compressor is damaged(busted seals). the compressor is unusually located inside the trunk area. check to see if its operational. if its operational, you will need to check for air leaks in the lines. The most common issue will be compressor failuer.
Jun 11, 2009 | 1995 Lincoln Continental
Ont stop filling with cold water
Hi. the pressure sensors in the water valve assembly appear to be damaged. you will need to replace the inlet water valve assembly in this case asap.
This is solenoid failuer. (basic water valve failure this case)
May 31, 2009 | Kenmore Washing Machines
Sony PlayStation 2 Slimline Console Logo
97 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
