Question about Apple iPod MA446LL/A MP3 Player
Downloaded music plays for 10 seconds
The music plays for 10 seconds then goes onto the next song and the next song continuing to play for just 10 seconds. I have gone into the repeat sub menu, hit repeat and then normal and it corrects itself to play the music in entirity. The problem is that I have to do it every time I turn the player on. How can I set the default? Also, the music seems to start at the same point every time I turn the player on.
Also, can I download a book?
You can't download a book
Posted on Aug 04, 2008
    President:
  • 317 Answers
First try to reset:
First make sure your hold switch isn't on. It's on the top or bottom and slides back and forth. It needs to be switched to the left. Once it is to the left, here's how you reset:
You can reset your ipod by holding down the menu and select (round button in the center) buttons down for at least 10 seconds. You'll see an apple logo flash, that's when you stop pressing the buttons. It will shut off, then back on.
If that doesn't work, try a restore:
How to restore iPod
  1. Ensure that you have an active Internet connection as new versions of iTunes and iPod Software may need to be downloaded to your computer.
  2. Download and install the latest version of iTunes if you do not already have it installed.
  3. Open iTunes, and then connect your iPod to your computer using the USB or FireWire cable that came with your iPod.
  4. After a few moments, your iPod will appear in the Source panel in iTunes.
  5. Select your iPod in the Source panel and you will see information about your iPod appear in the Summary tab of the main iTunes windows.
  6. Click the Restore button. You will be prompted with one or more restore options that may prompt iTunes to automatically download the latest iPod Software. The 4 possible restore options are:
    • Restore Option 1: Restore - Restores with same iPod Software version already on iPod.
    • Restore Option 2: Use Same Version - Restores with same iPod Software version already on iPod even though a newer version is available.
    • Restore Option 3: Use Newest Version - Restores with the latest iPod Software available.
    • Restore Option 4: Restore and Update - Restores with the latest iPod Software available.
  7. If you are using a Mac, a message will appear prompting you to enter an administrator’s name and password.
  8. A progress bar will appear on the computer screen indicating that the first stage of the restore process has started. When this stage is completed, iTunes will present one of two messages on screen with instructions specific to the iPod model you are restoring.
    • Restore Instruction 1: Disconnect iPod and connect it to iPod Power Adapter (typically applies to older iPod models).
    • Restore Instruction 2: Leave iPod connected to computer to complete restore (typically applies newer iPod models).
  9. During the stage 2 of the restore process, the iPod will show an Apple logo as well as a progress bar at the bottom of the display. It is critical that the iPod remains connected to the computer or iPod Power adapter during this stage. Note: The progress bar may be difficult to see since the backlight on the iPod display may be off.
  10. After stage 2 of the restore process is complete and the iPod is connected to the computer, the iTunes Setup Assistant window will appear asking you to name your iPod and choose your syncing preferences similar to when you connected your iPod for the first time.
Posted on Dec 30, 2007
Songs only play for 10 seconds then the next song comes on
Might be a setting that needs changing. Some have shuffle, repeat, play in order etc. Some have an intro setting that plays a few seconds and goes to the next to do the same. Maybe this is the cause.
Sep 11, 2015 | Audio Players & Recorders
Format error, and can't view playlists- I am on OSX 10.4.11. When I load mp3s onto the player, that have been imported into itunes (dragged them over via the Finder), I get two files for each song. The...
I don't have a solution -- but I have the same problem and this is the first I've found mention of someone else having it. I'm Mac OS 10.6.5. I thought I could go through and just delete the second copies of everything, but I can't figure out how to do that either. They don't show up when it's plugged into the computer. And as far as I can tell, you have to be playing a song in order to delete it, and it can't play things in the wrong format. Beating my head against the wall and starting to look at buying something else... In case you found a solution elsewhere, please let me know!
Jan 29, 2011 | Freestyle Audio MP3 Player
Playing by album
To change the play mode on the GPX ML648B you need to play a song, hit the MODE button on the side of the player and select Play Mode.
The options are INTRO (this will play about 10 seconds of a song and then go on to play the next 10 seconds of every song.) NORMAL which will just continually play through everything on your device, Repeat One, which will repeat one song, FOLDER which I'm not sure of, FOLDER REPEAT which I assume repeates a folder, REPEAT ALL and RANDOM.
May 19, 2010 | GPX ML648B MP3 Player
Wont play the whole song
Sounds like the player is running in INTRO mode, only playing the first part of each song. To change playback mode, follow the steps as described below.
Switch the player ON and start music playback:
1. Press PLAY button to START music to play
2. Press PLAY button again to PAUSE the playback
3. Press MODE button to enter playback mode selection
4. Scroll with MODE button through selections
5. Press MODE button when selection REPEAT is in the display
6. Use MODE button to select from: Normal, Repeat One, Repeat
within current Folder (if any), Repeat Folders (if any), Repeat
All songs, Random Play back, and Intro
7. Press MODE button to confirm selection
May 02, 2010 | Element Electronics GC823 MP3 Player
ONLY PLAYS PART OF SONG
enter you menu and turn off review. Review plays 5 or 10 sec of every song on your player if its turned on. Trun it to normal and you should be ok....
Rate this solution if it helps.. Thank You...
Nov 03, 2008 | Nextar MA933A MP3 Player
Set the Delstar to Randomly play songs
Call Customer Support @ 1-800-998-7771 to get another copy of the manual or ask for their website or google it. Delstar is a company in India. But they have offices here and warehouses and service centers too.Mylittle manual says... Playing Mode (playing the sub-menu) The first item in the playing sub-menu is Playing Mode. When choice is confirmed, the player will play according to the setting rule. SYSTEMS SETTINGS is last on menu as SYS; then...
Replay Mode is the A-B with dual arrows back and forth above the letters on your players menu bar.
Repeat choose one setting when you wish a different playback mode.
[N] = NORMAL Once list song plays, done with. Will continue to play eachsong in the file till through all, then stops. This is the default setting.
[1] = REPEAT ONE Repeat playing one single song.
[D] = with arrow going backwards above it is... FOLDER Plays all the music in the playing folder.
[D] = with dual arrows back and forth above is... REPEAT FOLDER Plays the same file of music repeatedly.
[A] = with dual arrows above is ... REPEAT ALL Repeats playback of all music in the directory.
SHUFFLE
[R] =RANDOM Plays the music in the present folder randomly.
INTRO
[I] = Plays the first 10 seconds of all the music in the present folder in sequence.
Apr 29, 2008 | Delstar DS-3512 MP3 Player
Graig MP3 problem
will not connect to PC
Feb 08, 2008 | Audio Players & Recorders
Won't stop skipping songs after 10 seconds!!
WAHA i've fixed it it was on repeat intro which means it plays the first quarter of he song so pretty much try to look at the repeat button and see if it is on that.....
Jan 07, 2008 | Audio Players & Recorders
Innovage mp3
you should check the settings on the mp3 player. I remember that many mp3 players have a setting called play the first 10 seconds of every music. Anyway check the similar setting on your mp3. Goodluck!
Dec 28, 2007 | Audio Players & Recorders
Apple iPod MA446LL/A MP3 Player Logo
70 people viewed this question
Top Apple Audio Players & Recorders Experts
Nagendra Baliga
Computer Repairing
Computer Repairing
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
