Dryer turns on, spins with heat and then turns off after 2-4 minutes.. I try to restart it and it will turn on and then stop again. Heat is present when it remains on.
the burner comes on for 5 seconds then go's back out .then off for about 60 seconds .then starts...
(More)
the burner comes on for 5 seconds then go's back out .then off for about 60 seconds .then starts over
makes a large clanking noise during the drying cycle, it will go on the entire 70 min cycle..is the...
(More)
makes a large clanking noise during the drying cycle, it will go on the entire 70 min cycle..is the belt broke?
The drum spins and gas is turned on. Took off the back panel and the manifold from burner to drum,...
(More)
The drum spins and gas is turned on. Took off the back panel and the manifold from burner to drum, reconnected the manifold thermostat, and I see no glow from the ceramic igniter, which looks to be intact. Checked the intake and exhaust thermostats, both show zero ohms. Don't know what else to check. Any advice and hints gratefully accepted.
I have a whirlpool 3622eqt gas dryer that will start and blow hot air but after a few minutes will...
(More)
I have a whirlpool 3622eqt gas dryer that will start and blow hot air but after a few minutes will stop blowing hot air. It will keep running but no heat. Any suggestions will be greatly appreciated. thank you
