Question about Casio Exilim EXZ75 Digital Camera
Casio EXZ75 Camera
I received this camera as a gift. I set the language, city date and time but everytime I shut off the camera I have to reset it. Am I doing something wrong?
  • maceo87 Feb 01, 2008
    I'm also having the same, identical issue with my
    EX-Z75. Every time I power the camera off, then turn it back on, I end
    up at the world map to set the time zone and have to walk through every
    single step all over again.
    I've tried all of the following to no resolve,
    • Backing up and reformatting my 1GB SD Flash Memory card
    • Removing both the battery and the SD card, checking for dirt buildup, dust on either.
    • Skipping over certain steps, or the entire setup
      screen entirely by hitting the 'menu' button near the bottom right
      (next to the BS button).
    Another issue that I've found is that
    this is also resetting any customization settings you applied to my
    camera, having to not only skip over/reset all your settings every
    single time you'd like to take a picture, but namely changing back my
    flash preferences, switching video mode from 4:3 (fullscreen) to 16:9
    (widescreen) and turning Shake Control back on to "auto" instead of off.
    This
    sucks a lot because if you are trying to snap a picture, a camera that
    was once fast in getting off the ground and grabbing the shot you want
    now seems like a programming menace every time you want to use the
    thing.
    Any solutions out there yet?
  • Anonymous Apr 12, 2008
    same problem keeps resetiong when i switch it off what do i do?
  • 477 Answers
Your problem does not lye on any memory card. it is because the internal battery that helps the cmos "cameras internal memory" hold its settings has gone out and needs tobe replaced. all you need is 2 1.5 volt hearing aid batteries stacked and taped +-+- and soldiered in place of the old cmos battery. witch is located on the front side bottom close to the bottom left of the lens. and placed next to the speaker. get some small batteries to do this het smaller the better for placement location.Hope this helps I have done this to a few camera's and it works fine.
Posted on Apr 20, 2008
Casio EXZ75 Camera - moz-screenshot.jpgMy wife's z75 has this problem for months and it was maddening. It took some research and some fooling around with different tricks, but I found the fix and posted it on fixya at the link below.
FYI, very few digital cameras have CMOS circuits anymore. Flash memories have replaced them, in part, because they don't have button batteries that have to be replaced every few years. The internal flash memory is the root of this problem with the z75
see the fix:
http://www.fixya.com/ThreadView.aspx?prdid=293753&thid=153973
Posted on Apr 29, 2008
How do I manually re-set the time on my Casio Exilim camera? I have set the worldtime etc, but it's about two and half years behind and I can't work out how to re-set it. This has been a problem...
Press MENU. On the "Set Up" tab, select "Adjust" then press cursor-right. Use cursor-left/right to move between fields, cursor-up/down to change them. Press SET when done.
The instructions are in the "Changing the Camera Date and Time Settings" section of the manual (page 165 in my copy), which discusses both the world time settings and the home city date and time. If you need a manual, you can download a copy from
http://support.casio.com/pdf/001/EXZ75_DI_e.pdf
Jul 14, 2011 | Casio Exilim EXZ75 Digital Camera
My camera is not storing the lsettings
The next time you finish entering the info, press the button you use (menu/set/enter or whatever) twice.
May 02, 2010 | Casio Exilim EXZ75 Digital Camera
Have Casio Exilim EX-Z750, 4 yrs. old. Every time
read the manual again. and reset to automatic update
Apr 07, 2010 | Casio Exilim EX-Z750 Digital Camera
My camera casio exz75 doesnt want to hold a charge
I had the same problem some time ago. I called Casio Live Support number and they sent me a new battery free of charge that works.
Jul 22, 2009 | Casio Exilim EXZ75 Digital Camera
Have to reset date and time every time I turn it on!
If you have to do that each time you shut it off and turn it back on try this. Take your memory card out and format your internal memory. Reset the camera and then re-enter the information. Shut the camera off and turn it back on and hopefully it will still be in there. If not then you have an internal memory error and that needs to be fixed by Casio.
Aug 24, 2008 | Casio Exilim EX-S600 Digital Camera
Setting date, time, etc.
just go to menu dude!....
go to adjust time and date...
its prett much easy from there.
Mar 16, 2008 | Casio Exilim EXZ75 Digital Camera
Settings
Give the following a try:
How do I maintain the settings when I Power ON/OFF my Casio digital camera?
Turn the camera ON and switch to REC.
Press the MENU button.
Using the controller, scroll to the Memory tab.
To have any one or ALL so settings maintained when turned OFF, scroll down to each and then to the right. Any settings you want to be maintained when the camera is turned back ON must be set to ON.
Any setting set to OFF will NOT be maintained when the camera is turned OFF.
Dec 31, 2007 | Casio Exilim EXZ75 Digital Camera
Camera keeps resetting the settings when turned off
Possible solution?
PROCEDURE
1. Initialize the system.
a) Enter the TEST mode.
b) Select "3:ROM UPDATE" and press SET button.
c) Next, select "5:SYSTEM INITIAL" and press SET button.
d) The following message appears.
SYSTEM INITIALIZE
START ...
PUSH OK KEY?
e) Press SET button and System is initialized.
"SUCCESS !" appears on the monitor.
2. Write firmware.
Update the firmware version"
Write the firmware.
If the TEST mode boots automatically, change "USB TCC ON" to "USB TCC OFF".
Nov 06, 2007 | Casio EXILIM Card EX-S770 Digital Camera
Casio Exilim EXZ75 Digital Camera Logo
708 people viewed this question
Top Casio Cameras Experts
pontelemon
pontelemon
Starnley Johnwells
Starnley Johnwells
Are you a Casio Camera Expert? Answer questions, earn points and help others
