Question about Sanyo DS27510 27" TV
Tuner roams The tv whows for a while and then the picture just goes off sometimes for hours. Then the picture returns and the process repeats itself.
  • I Marshal I Dec 29, 2007
    i have a diffrent tv but it is doing the same
  • 373 Answers
If the picture is roaming as you say then check to see if you have 33 volts on one of the pins of the tuner. If not this will trace across almost the whole board to a resistor: some models will be 39k and other will be 27k. May be (don't remember exactly) R106. Anyway there will be 130 volts on one side and 0 on the other. This feeds the tuning voltage to the tuner 33 volts. I have seen it where the picture is not there at all and sometime I have seen it as you say sort of roaming off frequency. Hope this helps
Posted on Dec 30, 2007
Screen goes blue and returns if cable cord moved
try do the same thing using the dvd or cd player plugged in.
Oct 21, 2008 | JVC AV-36890 36" TV
My tv displays no sync detected and I have checked all the cords running into the tuner. Also, occasionally the tv goes in to 'demo mode' and disables the remote, and cannot get out of it for a long time....
This tv is running through a cable box or a satalite box?Yes,tries unplug both the box and the tv for like about an hour.The tv,will reset itself and return to the factory setting.The boxs,will going through it resetting and will be upgrading it softwares.The tv should work again now.If not,than the tv Tuner signal board is the problems and the causes.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish tv Tuner signal board for the replacement.
Dec 04, 2010 | Televison & Video
Half the tv screen goes black randomly,then returns to normal
The Tuner signal board have problems.The board CPU,Chip,have intermitten short.When the chip is completely dead.The tv will get only LED light indicator power only,will not get tv signal pictures.
Apr 12, 2010 | LG 42LC2D 42 in. LCD HDTV
Lcd tv loses picture, power lght flashes grn; picture return
It sounds lamp is weak in TV and requires replacement.
I would be in better position to help you out if you post model and brand of your TV.
Dec 31, 2009 | Televison & Video
Picture goes out - but has sound
i have had this problem on one of my tv s all i did was remove the back of the tv and re-solder all the joints around the tuner (thats where the arieal goes) they go with time because the joints there get so hot . hope this helps
puggy
Jul 07, 2009 | Televison & Video
Picture Flickering
The sony tuners have been known to get intermittent, it might be a bad ground where the tuner connects to the main chasis, If the problem is in the tuner itself it will be most difficult to resolve since the connections are so small and compacted together.
Good luck
Apr 19, 2009 | Televison & Video
Television stays on one channel
You likely have bad solder connections in the tuner.
I’m happy to help further over the phone at https://www.6ya.com/expert/dewayne_4a10eab6caecdb92
Jul 12, 2007 | Sony KV-35V75 35" TV
Picture on tv
check for a bad solder at the the tuner section or within the tuner . Bad solder ground within the tuner can cause this fault
Apr 21, 2007 | Panasonic CT-36D32 36" TV
Sanyo DS27510 27" TV Logo
24 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
