Question about E-Machines eMachines Desktop PC
Emachine help My Emachine T2542 won't turn on, when i turn the monitor on it says to check system cable.
  • Nia1 Dec 30, 2007
    when pc turned on screes says
    monitor is working B
    check pc and system cable R
    I've rebooted, checked all cables, everything appears to be connected correctly. That's all I've done because it won't let me do much more.
    Frustrated in AR.
    Sergeant:
  • 310 Answers
Hi. could be a few things
1st thing if theres no power going to the base unit, the power supply is gone will cost about £20 for a new one.
2nd thing it could be graphics card, memory needs refitting. ie take them out and refitting them usually fixes it.
theres a few other things it could be but less likely. i suggest trying the above..
have a great new year
John
Posted on Dec 29, 2007
Emachine 786n mointor frozen emachine logo
Try a different monitor. Most likely your having operating system issues that cause the monitor to do this.
Also - try this - As you turn the machine on tap the DELETE key - this will take you to the DOS platform of the computer. If the screen changes to anything you have operating system issues. Try a repair with the original disk or the operating system disk that was last installed.
May 08, 2010 | Computers & Internet
When I turn on my machine, I get 3 beeps and my monitor tell me no signal, the model is a T5026 emachine, please email me any suggestions
First use the following steps:
Turn off the system and disconnect power cables
Press and hold the power button for 10-15 seconds.
Reconnect power cables and try to turn it on.
If it remains same, the next step will be to:
Open the case and re-seat memory modules
If you have more than one modules installed, try to test the system with a single module at a time.
Mar 12, 2010 | E-Machines Emachine T5026 power supply **...
I just lost all my cd 's with my emachine t2542,i re install new W XP OS because my hard disk was damaged and replace new one,the problem is,it's usb ports doesn't work,help me pls.tnx
In order for us to assess possible drivers that are available for the eMachines T-Series T2542, please download the trial of Driver Detective and run it to ensure a more accurate list of drivers for your computer with less chance of error.
http://www.drivershq.com/Drivers/eMachines/T-Series/T2542/22605/22647/22688/Drivers.aspx
Oct 05, 2009 | E-Machines T2542 PC Desktop
My emachine will turn on and run without doing anything. The monitor states no signal.
Either the VGA cable (cable from your monitor to computer) or VGA port on your computer is faulty. Try connecting another monitor to your computer to determine the problem. If the other monitor works, then your VGA cable is faulty. If the other monitor doesn't work, the VGA port is faulty. Hope that helps.
Aug 03, 2009 | Gateway Computers & Internet
I have a t2882 emachine it won`t turn on light on frount is on but won`t turn on
Check the monitor connection the pc or you may have to buy a video card for your pc.
Jul 18, 2009 | E-Machines T2882 PC Desktop
COMPUTER WON,T YURN ON
first of all,is your power cable properly connected to your system unit.if it is not,connect it properly and turn the system unit on again
secondly,make sure your signal cable from the monitor to the system unit is properly connected
after following these instructions,reboot your computer again.
thank you for consulting fixya with your problems
Feb 14, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Emachine t2542
When you say out, do you mean they are broken, or just disconnected? Most of these computers have a plug on the end of the wires to the front panel and it just plugs into the system board. If you look at the board you'll see where the front panel wires go. Sometimes it's hard to read the small type, but there are labels on the board that tell you what connector does what.
Nov 17, 2008 | E-Machines eMachines Desktop PC
Emachine T2542 Won't power on
you need to open the PC and check the power supply for some fuse and safety device that acts like a fuse , these fuse looks like a 3 leg transistor only that it have 2 , look for this , and of course the typical fuse . hope it helps
Apr 19, 2008 | E-Machines eMachines Desktop PC
E-Machines eMachines Desktop PC Logo
80 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
