Question about Sony Playstation 3 (PS3) Console
PS3 internet problem
I have recently got the 60gb PS3, i have the ethernet cable and am connected to broadband and have no problems with the internet. The cable is connected to the PS3 however i dont know where the other end of the ethernet cable plugs in and what i need with it to function online
can anyone please help me
  • tomlinson Dec 30, 2007
    hi thanks, but im now trying to run it through my pc, what settings do i need to change or do i have to get anything else to connect please walk me through
    Sergeant:
  • 310 Answers
Hi, best way to connect the PS3 is to buy a router, wireless or wired router. and if you go for a wired one, connect the ethernet cable (RJ45) from the PS3 to the Router,
Other option is plug ethernet cable into PS3 & other end into the Network card which will be built into the base unit, otherwise you can buy a ethernet card which should cost you about £10.
but you will need the PC switch on, whenever you want to use the PS3, as well as you will have to configure the network setting to get it working,,
Have a good new year
John
Posted on Dec 29, 2007
  • John Anderson
    John Anderson Dec 31, 2007
    Hi, you will need to go into network connections in control panel, find your internet dial up icon, right click on it, share.
    if its aol its different please let me know
Connecting LC-52LE810UN to internet
Connecting to the Internet
To connect your TV to the Internet, you must have a broadband Internet connection.
Use an ETHERNET cable (commercially available) to connect the ETHERNET terminal on the TV to your
broadband router (commercially available).
If you do not have a broadband Internet connection, consult the store where you purchased your TV or ask your
Internet service provider or telephone company.
you need to have a cable connected to the ETHERNET port and then you will get more options. You need to connect it to your router ports. hopefully you have DHCP enabled on the router and then all will program automatically
Feb 01, 2014 | Sharp LC-52LE810UN LCD TV, 52 - widescreen...
I have ps3 internet but ps network! dns error 80 something and have been signed out of psnetwork! what do i do ?
This means you've been signed out of the playstation network. A problem with your broadband, not your PS3. Check the connection of the ethernet cable from your router to the ps3. Then switch off at the mains both your ps3 and your router. Leave for 30 seconds then turn both back on. Wait till the blue lights on your router are all steady blue not flashing red or orange. Then turn on your PS3, go to network settings, then internet connection test. This will check your internet connection, and whether or not you're signed in to PSN, and also your internet download/upload speed.
Hope this helps.
LJ
Apr 17, 2011 | Video Game Consoles & Games
How do i connect my ps3 to my internet
1 Before you connect to internet you have to complete network settings. If you have not done the same do the following I hope you have the followings available A broadband internet connection A network gateway device such as ADSL modem Ethernet cable
2 Connect the ethernet cable to the system. Select "Network settings" under "settings" in the "home" menu and then press X . When a message stating that the internet connection will be terminated, select 'yes' and press X. On the screen displayed select 'Easy and press the right direction arrow. Check the settings and then press X button.
Similarly a wireless connection can be set up but it will vary with the equipment being used. In this case the ethernet cable is not connected. You have to select 'wireless' after the "Easy" selection step. Then select 'Scan' and then select the access point you want to use.Then select the security settings as necessary. Enter the Encryption key. A list of settings will be displayed. Check the settings and press X. Once this is done PS3 system will automatically connect to the Internet when the system is turned on. This will remain active as long the system is on
Feb 14, 2010 | Sony Playstation 3 (PS3) Console
The internet connection on my laptop is thru a sprint 3g usb mobile broadband device unfortunately tht is my only nternet connection, how can i connect me ps3 with this device
If you have a cross over cable you could connect your PS3 to your Laptop via the Ethernet port and choose internet connection sharing on the 3G device on your laptop, then just make sure the PS3 and the laptop ethernet settings are set to auto detect settings (DHCP).
Jan 01, 2010 | Sony Playstation 3 (PS3) Console
PS3 internet connection problems
Hi there
do you run it wirelessly or with an ethnet cable? also have you tried enetering the settings manually from the wireless setup menu? entering the network key in capital letters etc? sky broadband seems to be very fickle. as i have no end of problems with it disconnecting and running very slowly.
Jun 03, 2009 | Sony Playstation 3 (PS3) Console
Need help with ps3 internet hook up
you can go wireless, but personally wired is better. what router do you have? switch everything off, plug a ethernet cable from one of your ports on router to ps3 then then switch it all on. on ps3 go to settings - network settings - internet connection settings - then select easy - then whether you wanna do it wireless or wired (up to you) then let it do its thing, once its found all your settings you can test the connection.
Have you set up an account on your ps3 yet?
Dec 31, 2008 | Sony Playstation 3 (PS3) Console
Ps3
Using an ethernet cable, bring the cable into the back ethernet port on the back of the ps3. Go into your connection setting and click set up, and then select wired connection. From there follow the quick online instructions. Test by trying to get onto the playstation store if it works it was successful. The same steps go for wireless. Though I would go for a wired setup.
Feb 10, 2008 | Sony Playstation 3 (PS3) Console
Connecting ps3 via t-mobile web n walk
now then or you hav to do is plug it to your pc go to internet connection t mobile properties then advanced allow to share to other connections then plug your cable to your pc from your ps3 you might have to turn your windows firewall off or just change the settings if you dont want 2 turn it off
Dec 09, 2007 | Sony Playstation 3 (PS3) Console
Internet
try updating the ps3
Sep 09, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
97 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
