Question about Alps MD 5000 Thermal Printer
Stripes on printout MD5000P
Hi
Is there anything I can do to adjust lighter stripes that happen on each pass of the printing process?
The stripes do not happen at the same exact place for each pass.
If you have a suggestion please pass it on to me.
Thanks
Rich
  • doolingbros Dec 29, 2007
    If you know how to calibrate the printer or adjust it I would be very greatful.
    Thanks
    Hi JeremyM49,
    I had a jam and after the jam this started to happen.
    Before the jam, with the same ink, it worked perfect. So, I don't think it is a ink cartridge problem but thanks for responding.
    Thanks
    New Friend:
  • 127 Answers
This happens alot, iteithermeans your inks running low, your inks too new, or its a low quality printer.
My suggestion would be to check your ink level, and if its fine, print out a few pages, then see if it helps.
Posted on Dec 29, 2007
Hi, I have a Canon MG5370 and recently stripes of lighter shades colour appeared and they ran horizontally across the colour printout. What is the cause of this? How do I fix it? Thanks.
There is a strip about 1/4 inch wide that passes through the back of the print head. Be very careful and clean this strip on both sides with isopropyl alcohol. Be very careful not to let the spring on the left end of this strip become disconnected.
Dec 25, 2014 | Canon Office Equipment & Supplies
Printing every other line lighter
Use the Canon software to do a "nozzle check".
The print-head has multiple "jets" that spray ink onto consecutive "rows" across the width of the paper. If some of the jets are clogged, then you get the "every other line is lighter" effect, and the printout from the "nozzle check" will show a pattern of "stripes".
May 10, 2014 | Canon PIXMA Office Equipment & Supplies
How to solve streaks in printout
If you have tried running the "eliminate light stripes" process in the troubleshoot print quality without success, you may want to look at the print quality sheet and do "jet substitution" on the ink nozzle numbers that aren't printing out. That will slightly slow down the printing, but will eliminate white streaks down your prints.
May 04, 2014 | Xerox Office Equipment & Supplies
Stripes
try cleaning printer head from maintance page
Jan 28, 2014 | Kodak HERO 7.1 PRINTER
My printer works fine except for the photos. The pictures that print out have vertical stripes that are lighter on the picture. what is causing this? and how can I fix it?
go to the printer properties,servicess perform print head/nozzle clean two or three times then check if not resolved check which color caetrige effected stripes replace it.
Sep 19, 2011 | HP PhotoSmart 7960 InkJet Printer
Why do my pictures look faded with up and down stripes?
Check the paper to make sure you are using the correct paper type for the project. If the paper is too fibrous, the ink applied by the printer might not fully cover the print surface.
  1. In the program being used for printing, click File , and then click Pring . The Print window opens.
  2. Make sure the appropriate product is selected, and then click Preferences or Properties . The Preferences/Properties window opens.
  3. Click the Printing Shortcuts tab. Consider modifying some or all of the options in the Printing Shortcuts menu to increase print quality.
    • Print quality : If the quality of the printouts is not acceptable, try increasing the print quality. To print more quickly, try decreasing the print quality.
    • Paper type : If one of the options matches the paper type exactly, select it instead of Automatic .
    • Paper size : Make sure that this option matches the paper loaded in the product.
    To see additional options, click the The Advanced Features window opens. Consider changing the following option: Ink volume : Adjust the amount of ink that prints on a page. For lighter images (less ink), drag the slider to the left. For darker images (more ink), drag the slider to the right. The lighter the ink volume, the more quickly the printout dries.
Press and hold the asterisk (* ) and pound (# ) buttons on the product control panel.
  1. When the control panel reads *******#######, release the asterisk (* ) and pound (# ) buttons.
  2. Press the 3 , 2 , and 9 buttons, in that order.
  3. Press the right arrow button (c00420524.gif ) to select Special Reports , and then press OK .
  4. Press the right arrow button (c00420524.gif ) to select Print Cartridges , and then press OK
Aug 12, 2010 | HP Officejet J5780 All-In-One InkJet...
Stripes through printout epson c86
Click on Printer choose properties and choose maintenance and cleaning
Aug 29, 2009 | Epson Stylus C86 InkJet Printer
Thought I would ask you, since u have answered Ricoh CL3500N
According to the maintenance manual, broken lines are caused by the "dithering" setting. Also there is an in depth color calibration process you can execute. Have you checked the PCU unit?
Here is the maintenance manual:
http://www.ricoh-usa.com/downloads/downloads.asp?tsn=Ricoh-USA&path=http://support.ricoh.com/bb_v1oi/html/oi/rc2/model/cl3500/cl3500en.htm
You may have to copy and paste the link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 16, 2008 | Ricoh Aficio CL3500N Laser Printer
Stripes down left margin
Hi, I have the same problem, which has just been diagnosed as a defective developer drum by a repair specialist. The new part is $120.00. Should have the serviced unit back
SR
My Canon PIXMA MP760 printer had been printing a horizontal stripe of a lighter cyan where ever that colour occurred. Today during printing it displayed an error. Unfortunately I didn't catch the number. I...
Maybe an obvious answer, but have you cleaned the print heads several times? You can also remove the cartridges, remove the entire print head and clean it with rubbing alcohol and a q-tip.
Mar 28, 2008 | Canon PIXMA MP760 All-In-One InkJet...
Alps MD 5000 Thermal Printer Logo
131 people viewed this question
Top Alps Office Equipment & Supplies Experts
Jesse Walters
Jesse Walters
Samuel Konger
Samuel Konger
Saleem Baig
Saleem Baig
Are you an Alps Office Equipment and Supply Expert? Answer questions, earn points and help others
