Question about Akai PT4298HD Rear Projection Television
The unit will not turn on is there a fuse or reset
Replaced fusing unitbizhub501 Can't reset. Researched online how to reset. This is ridiculous that you have to call a tech out just to reset the unit. Everybody is trying to make an extra buck.
FIRST, if this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jul 29, 2016 | Konica Minolta Bizhub 501 Copier
Error code 3803
Fusing high temperature abnormality.TH1 thermistor detects a low temperature when a specified period of time elapses after the fusing heater lamp is turned ON for the fusing ON control.If the fusing unit is OK try to reset:
Turn off the copier.Press and keep pressed the Utility key and turn ON the copier.Keep pressed the Utility key when will Trouble reset displayed on screen.Release the Utility key,reset the error turn OFF the copier,wait 1 minute and turnON.
Jan 08, 2014 | Minolta bizhub 350 Black and White Copier
Pontiac montana dvd
The fuse panel lid has a listing of which fuse is where. Remove the fuse for the radio and the dvd will shut off. If it does not, one at a time, remove a fuse and see if the dvd turns off - replacing the fuse before going on to the next one. You'll figure out which one is the fuse for the dvd power quite easily this way. There is also a small reset hole on the face of the unit which you can use a paperclip to press in and this will reset the unit.
Nov 19, 2013 | Car Audio & Video
Fusing unit setting error
To prevent damage to the machine, the main machine cannot be operated until the fusing related
SC has been reset by a service representative.
? Enter "SP Mode 3" in the SOM.
Click "OK" in "Reset Fusing Unit SC" with "SP Mode 3", and then turn the main power switch off
and on.
Dec 11, 2011 | Ricoh Aficio 2228C Copier
How do I replace the brother fuser?
    The fusing unit and the parts around it are hot! Be sure to wait until the fusing unit has cooled down sufficiently before replacing the fusing unit. If you touch the hot parts, you might get injured.
  1. Turn off the machine's power switch. To avoid injury, wait until the machine has cooled down sufficiently before you replace the fusing unit.
  2. Open the back cover (1) and the scanner unit (2) of the machine.
  4. To release the fusing unit from the machine, release the lock levers that are on both sides of the fusing unit.
  6. Hold the handles on both sides as you take the fusing unit out of the machine.
  8. Put the new fusing unit into the machine. Be sure to insert the fusing unit completely into the machine.
  10. Secure the fusing unit with the two lock levers that are on both sides of thefusing unit.
  12. Move the fusing unit pressure release levers to the Set position.
  14. Close the scanner unit and the back cover.
  15. Turn the machine's power switch back on.
  16. Press the Menu/Set key.
  17. Press the up or down navigation key to select Machine Info. and press Menu/Set.
  18. Press the up or down navigation key to select Reset Menu and press Menu/Set.
  19. Press the up or down navigation key to select Fusing Unit and press Menu/Set. The confirmation message appears on the LCD.
  20. Press 1 to reset the life counter.
  21. Caution
      Please be careful when replacing the fusing unit. Do not put pressure on the fusing unit; it should go in easily. If it does not, make sure the fusing unit connector is free to move.
      Do not apply force! It could damage both the fusing unit and the machine.
Feb 02, 2011 | Brother IntelliFAX 4750 Plain Paper Laser...
Outside fan not turning on.
Reset buttons (if applicable) are usually located near the brass service valves.
There is a circuit breaker in your electrical panel that furnishes voltage to your outdoor unit. This is a seperate circuit from the indoor unit.
Outdoor units should have a service disconnect mounted within 10-15 feet. This service disconnect may have fuses or a circuit breaker in it.
Usually if a fuse opens, you will not be able to tell from a visual inspection. It is best to take the fuse to your local hardware store where they can test it and offer a replacement if needed.
I hope you find this to be very helpful moving forward.
Apr 21, 2010 | Heating & Cooling
Functional error SC548-00
SC548: Fusing unit installation error
- Definition -
The machine cannot detect the fusing unit when the front cover and right cover are closed.
- Possible causes -
• Fusing unit is not installed
• Poor fusing unit connection
Reinstall the fusing unit, ensure proper installation. You will need to enter the service mode in order to reset this error. Enter the service mode, then turn the machine off and then on via the MAIN power switch.
Dec 14, 2009 | Ricoh Aficio 450 Copier
I stop getting power or sound to my sub
Double check your fuses. It sounds like you blew a fuse. Check the fuse for the radio aswell as the inline fuse for you amp. On some amplifiers there is a circuit breaker reset button. Check to see if your amp is equiped for that. I did find this quote for reset out of the owners manual.
Remote Turn-on
Automatically turns amplifier on when connected to the head unit's remote output. The
amplifier will turn on and off with the head unit to save current consumption. This control
also operates the reset circuit for the amplifier's protection. It must be connected with
the head unit in order to reset protection circuits.
Mar 28, 2009 | Bazooka BA1500 Car Amp
Garmin Street Pilot C330
Check the fuse at the tip of the power cord. Unscrew the round black plastic and this will release the fuse. Otherwise there could be a problem with the power cord. If the cord is defective, replace only a Garmin replacement.
Apr 06, 2008 | Garmin StreetPilot C330 GPS Receiver
Error Message C3451
It is a fuser error.
Try resetting. To reset a Rank A error follow these steps:
1. Turn OFF the Main Power Switch.
2. Turn Main Power Switch ON while pressing the Utility/Counter key.
5. After turning off the Main Power Switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
If the error recurrs then do the following:
1 Check the Fusing Unit for correct installation (whether it is secured in position).
2 Check the Fusing Unit, PWB-M and PU1 for proper connection and correct or change as necessary.
3 Change Fusing Unit
4 Change PWB-M
5 Change PU1
Oct 02, 2007 | Konica Minolta bizhub C250 All-In-One...
Akai PT4298HD Rear Projection Television Logo
24 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Steve Allison
Steve Allison
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
