Question about Samsung Weather Resistant Security Camera SSC-12C
Ssc-12c samsung b/w camera.
Camera hooks up with rj11e from monitor. will a phone line with 6 connectors work? what is the green connector for? where do i find the cables i need?
  • 5 more comments
  • cableguy1054 Jan 24, 2008
    i do not have the power cords for my ssc-12c where would i find wireing schematics and the proper cords
  • Anonymous Feb 17, 2008
    wiring diagram
  • aws1969 Feb 17, 2008
    cord was cut only hae one end how elese can i wire
  • rinellip Mar 02, 2008
    After a storm, some of my cameras stopped working. Is there a reset I need to locate? How is this accomplished? Does the wiring schematic detail tell me what I need to know locate the source of my problems? Can I get a copy of the camera schematics?
  • Anonymous Oct 05, 2008
    same problem
  • Nina Hartman Nov 30, 2008
    I have the samsung ssc-12c camera and the ssc 3000n recorder. I can not get the recorder to record. Is there a wiring diagram that can help me?
    Thanks
  • Anonymous Mar 13, 2014
    need redone inside connectors. Camera falled and cables were broken
Im trying to get the wiring dirgam for a ssc-12c camera
Posted on Sep 05, 2009
  • 423 Answers
Phone line with 6 connectors will not work. You can sub it out with RJ45.
The green connector is for PIR.
Posted on Feb 15, 2009
    New Friend:
    Problem Solver:
  • 6 Answers
The 6 line telephone cord will not work, Rob is correct, however if you reverse they wires it will be a cheaper solution vs new cables... they are expensive.
Here is the manual to SSC-12a
http://downloadcenter.samsung.com/content/UM/200604/20060413114602671_SSC-12.pdf
Another solution is to use Cat-5 network cable, I made my own sets years ago around 150 feet with no video loss.
FIBEROPTIC/FBR, The HUMBLE Guys, Napalm and Worship Inc. http://downloadcenter.samsung.com/content/UM/200604/20060413114602671_SSC-12.pdf http://downloadcenter.samsung.com/content/UM/200604/20060413114602671_SSC-12.pdf
Posted on Nov 09, 2017
Complete service manual for Samsung B/W Observation Monitor SSC-12M AC120V, 60 Hz, 38 W. The green front panel power lamp flashes and the machine emits a clicking sound. I have checked connectivity to...
Unfortunately, the devices aren't listed as the "set" - can you reply with the exact model number from the main unit?
If i cannot obtain the schematics after hearing from you... I will contact Customer Service to initiate a refund or switch to another expert.
Thanks!
Sep 28, 2011 | Samsung Weather Resistant Security Camera...
I have a standard old Dell desktop, I hooked up a set of Creative T7700 speakers, they worked wonderful for about twenty minutes and the quit all together. I re-hooked the single line back to the flat...
By the single line I assume you mean the green line out cable and you have connected this to the sound connector on the monitor, so that you have the Dell computer using the monitor speakers?
The problem may be down to the sound chip on the Dell conflicting with Creative labs speakers, it may not support the 7:1 sound. You can try updating the Dell sound drivers, however Given the problem, I'd invest in a pci soundcard and hook the speakers up to that, or look at an external soundcard
Jul 28, 2011 | Computers & Internet
How to crimp 1 end of cat 5e cable with rj11 connector that was cut off. What is pinout order that each wire should in the rj11 connector? the colors are: Black,green,red, yellow & clear. ...
The pinout of the modular camera connections is as follows:
Pin 1 ----------------------- Alarm / In
Pin 2 -------------------- +15Vdc Out
Pin 3 ---------- Intercom Audio Out
Pin 4 ------------------------- Video In
Pin 5 ------------ Intercom Audio In
Pin 6 -------------------------- Ground
Goodluck
Oct 18, 2010 | Cameras
We purchased a home with 4 samsung cameras in various places around the exterior. They are all wired back to the master bedroom with what looks to be CAt-5 cable. What do I need to make this system work??...
Hi there, depend on the model of your cameras, normally if there are samsung it should say the model # ( ssc-12c,soc-c120 and so on) What look like CAT-5 are normally RJ-11 very similar to a phone connector. If your cameras are one those mentioned above you will need a monitor that support that type of connection like the ssc12m or ssc-17webm if there are black and white or the SMT-190M if there are color cameras. or a DVR with similar connection type like the SHR-1041.
Thank You,
nationalprosecurity.com
Oct 17, 2010 | Samsung Weather Resistant Security Camera...
I need a wiring diagram for rj-11e.
rj11e pin lay out with turned over. brass pin facing you.release
pin to the bottom. 1 left to right to 6.
1 2 3 4 5 6
bk---red--green--yellow--clear (bare ground)--
that is it.
Aug 22, 2010 | Samsung Weather Resistant Security Camera...
I have 3 outside cameras (SSC-12C) hooked up need cameras
i recommend pelco day night dome camera they are cheap and the resolution is great. they are originally bnc type connector which usually take rg59 or rg6 coax cable but if you have like cat5 or some other kind of stranded wire you can by a balum adaptor that takes stranded wire but has a bnc female end. now with your monitor they make a cheap device called a multiplexer it takes bnc connectors and to hook up to your monitor you can use regular adio video cables like for your vcr. the multiplexer also lets you scan thru your cameras one at a time or have all three up or it can scan thru by itself like every five minuets.
Jan 17, 2010 | Samsung Weather Resistant Security Camera...
I GOT A SAMSUNG SOD14C , OKAY I WANT IT TO CONNECT TO A DVR WITH BNC INPUTS, BUT.. MY CAMERA USES RJ11E WICH NUMBER OF THE RJ11 JACK BELONGS TO POWER, VIDEO AND AUDIO?? SO I CAN RECONNET?
I salvaged an SOD14C and found this out by playing around with it.
the 6 pin RJ11 is wired as follows, holding the cable, connector up, cable hanging down with the pins facing you the pins count from left to right.
Pin 1 is green it is the Microphone +
Pin 2 is red it is the +12 Volts DC
Pin 3 is yellow it is the Speaker +
Pin 4 is the bare copper shield it is the common (-12 Volts DC, Microphone -, and Video -)
Pin 5 is whitish clear it is the Video +
Pin 6 is black it is the Speaker - got-samsung-sod14c-okay-want-connect-kkfjmd05sw3quyoyjvycjykz-5-0.jpg
Hope this helps!
Mar 09, 2009 | Samsung Weather Resistant Security Camera...
Slightly blured picture
the best solution is coaxial cable. or shield CAT5 cable.
Feb 02, 2009 | Samsung Weather Resistant Security Camera...
Samsung Weather Resistant Security Camera SSC-12C Logo
3,019 people viewed this question
Top Samsung Home Security Experts
Gary Banta
Level 1 Expert
Cesar Quant
Cesar Quant
Colin Stickland
Colin Stickland
Are you a Samsung Home Security Expert? Answer questions, earn points and help others
