right click on the printer icon in the printers page
select printing preferences
select the print quality as you wish and at the end click on apply and ok
and try to print .... i think this should work
still if it does not work
uninstall and reinstall the printer as a fresh and this should be a fix
still if that does not work
download the full feature driver from the below link and install the printer and it should work http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?product=3204785&lc=en&cc=us&dlc=en&lang=en&cc=us
................ thank you and do let us know for further help .......................... thank you
HAMID
C7280 connected to network but continues to disconnect and reconnect all the time. This prevents...
(More)
C7280 connected to network but continues to disconnect and reconnect all the time. This prevents faxes coming in.
I can't get Photosmart C7280 to send or receive faxes. We had a power outage a few days ago and ever...
(More)
I can't get Photosmart C7280 to send or receive faxes. We had a power outage a few days ago and ever since that it hasn't worked. Coincidence or cause? Solution??
hp cue scanning flow component on hp photosmart c7280 all-in-one
the scanner doesn't work...
(More)
HP CUE Scanning Flow Component on HP PHOTOSMART C7280 all-in-one
THE SCANNER DOESN'T WORK IMPOSSIBLE TO DESINSTALL WITH THE CD !
HOW TO DO ?
My HP C7280 prints an extra sheet with every page printed. The solution here for using the Hewlett...
(More)
My HP C7280 prints an extra sheet with every page printed. The solution here for using the Hewlett Packard driver instead of the HP driver will not work because the C7200 series does not show up under Hewlett Packard (even after doing the Windows Update). The reinstall suggestion will not work as I can not get my PC to delete the existing C7280 so I can reinstall it. Any suggestions on how to make these work before I try alternative 3, the driver for another printer? Not sure if I would lose any functionality with that driver
jammed paper the jam is obvious when trying to slide paper drawer in. Jammed Paper is not visible...
(More)
jammed paper the jam is obvious when trying to slide paper drawer in. Jammed Paper is not visible Lifting movable parts does not expose paper
