Install HD3870 graphic card
I didn't succeed to install a jetway graphic card HD3870.
I supress the old pilot whith windows and then stop the computer. Install the new graphic card and boot. In windows the screen is very strange due to poor color and definition level ( only 4 bit fo color and 400*600 for definition, and now way to improve it ). Neverthless, I install the new pilot and try to reboot the computer, but the boot fail after the "windows" screen and the computer start to reboot. During this second boot, I have a very strange boot screen, with a lot of white points included in the normal Asus screen. Then the boot fails again at the same time and start to reboot....
The only way to recovr the computer is to reinstall the old graphic card ( HD2400 ) , and then it's work perfectly.
I try it on my two computers, and it's the same.
System:
motherboard: Asus P5KC, bios update 0804
CPU: E6750
memory: 4 x 1 Mo kingmax PC8500
HDD: seagate caviar 40 Go
graphic card that I try to install: Jetway X38XTEN512Q, n°7BC086T024484, based on HD3870 GPU.
    Genius:
  • 1,601 Answers
Follow these steps:
Uninstall current graphics card drivers. Before you install your new card, you'll need to uninstall your current graphics card's drivers to avoid any potential conflicts. Right-click My Computer and select Properties. Under the Hardware tab, find the button to open the Device Manager. Your graphics card should be listed under the Display Adapter heading. Double-click the name of your graphics card to open a properties window for your current card. Last step: Under the Driver tab, click the Uninstall button.
Remove old card. Turn off your PC and unplug it from the wall. Open the case Make sure you first ground yourself by first touching a metal part of your PC case or by wearing an antistatic wrist strap. (Grounding yourself will prevent you from getting shocked and from unintentionally damaging your PC's components.) If you are replacing a graphics card, you'll need to remove a small screw attached to the back plate prior to taking out the card.
Install new card. It wouldn't hurt to page through your new card's instruction manual at this point. Then, take your new graphics card out of its foil wrapper and slide it into your motherboard's slot. Press down firmly with even force until it is securely in place (your system won't boot up unless the card is in all the way). Screw it into the back plate and close up your case.
Install new drivers. Turn on your PC and install the drivers. Windows XP should automatically recognize the new hardware and walk you through the installation wizard. If Windows doesn't detect the card, click Settings from the Start menu. Open the Control Panel and click Add Hardware. From there, a wizard will help you install the new drivers from the CD that came bundled with your new card. It's a good idea to check the graphic card vendor's Web site for more up-to-date drivers, just in case the vendor has released drivers since manufacturing your card. Once you've downloaded the drivers, simply restart your PC. Now, you're ready to start gaming.
If this doesnt work, then your card is BAD.
Posted on Dec 31, 2007
Motherboard with power no display
Hello here is the homepage:
http://www.jetway.com.tw/jw/download_show.asp?productid=P4X400DBP
I think maybe the graphic card has died.
Try to add a new or used AGP graphic card
in the slot on the mainboard.
Check also the screen/ or cable on another pc for fault.
Good luck
Nov 22, 2012 | Jetway P4X400DBP Motherboard
Graphic card
Yes provided the expansion slot on the motherboard can fit this graphics card. If your motherboard has a built-in graphics chip then you most likely need to disable the on-board graphics before installing this graphics card and driver..
Sep 05, 2012 | Jetway JI31GM4-L-LF Motherboard
Palit hd3870 driver, can i use it with ddr2 memory?
Primo,
A graphics card has it's own Processor and graphics memory.
The Processor is a GPU,
http://en.wikipedia.org/wiki/GPU
Slang? Graphics chipset.
This means it runs independent of the system resources;
the Processor and Ram Memory on the motherboard.
Means if they come out with a graphics card using GDDR1000, you can still use DDR2 Sdram ram memory.
For additional questions please post in a Comment.
Regards,
joecoolvette
[TIP:
Windows running, install ALL of the graphics card's software.
The drivers, and the user interface;
(ATI? Catalyst Control Center)
It's okay as Windows won't use the software yet.
If you are asked if you want to restart your computer -> NO
Close all windows, go back to the desktop screen.
Turn the computer OFF.
Open the computer case, FOLLOW Anti-Static Precautions.
Remove the monitor cable from the motherboard, or previous graphics card.
Remove the old graphics card IF you were using one.
Install the new graphics card. Plug the monitor cable into it.
Close the computer case. Plug the computer into power.
WAIT 1 minute, turn the computer on.
Why?
Because when a device is installed on a computer, (Device = Graphics card in this case), Windows will 'break it's neck' to find suitable matching drivers.
If THE drivers for the graphics card are not already installed, Windows will match up one of it's THOUSANDS of generic drivers.
This = No.
Will cause a driver conflict.
Windows: "Which drivers do I use? These or THESE?" ]
Jul 27, 2012 | Computers & Internet
I'm trying to install windows 7 x86 on my ATOM-GM1-230 motherboard but it keeps asking for a driver. after downloading all the x86 drivers from the jetway website, copying them to a usb drive, it still is...
http://windows.microsoft.com/en-US/windows/downloads/upgrade-advisor
You might want to run this. It should tel you whether is compatable or not and/or give you a suggestion as to what to do before or after download. Some software,ie, graphics card, itwill tell you to uninstall software before download of Win 7.
Mar 17, 2011 | Jetway (JATOM-GM1-230-LF) Motherboard
About graphics
There appear to be 10 different revisions/models in the G41 family...
Here is the link that lists all of them and their individual specs...
http://www.gigabyte-usa.com/Search/Search_List.aspx?Keyword=g41&SearchType=Spec
Jun 06, 2010 | Gigabyte 512MB ATI RADEON HD3870 DDR4...
Diamond Radeon HD3870, 512MB DDR4
According to ATI this is a known issue. They refer problems to microsoft about this error as they say it is an o/s issue. Microsoft refers you back to ATI saying it is a thermal issue. I have an ATI card as well & have the same problem. Hopefully the next driver will fix this issue when released. Hope this helps.
Jan 23, 2009 | Viper Diamond ATI RADEON HD 3870 PCIE...
When I insert my graphic card Ati HD 4850,my system does not boot.I am getting post code error 52 -Test memory(clear all extended memory to 0).Also the fan spins to 100% and does not want to stop.Two...
are your system meet the requirement???
ATI Radeon™ HD 4850 System Requirements
  • PCI Express® based PC is required with one X16 lane graphics slot available on the motherboard
  • 450 Watt or greater power supply with 75 Watt 6-pin PCI Express® power connector recommended (550 Watt and two 6-pin connectors for ATI CrossFireX™ technology in dual mode)
  • Certified power supplies are recommended. Refer to http://ati.amd.com/certifiedPSU for a list of Certified products
  • Minimum 1GB of system memory
  • Installation software requires CD-ROM drive
  • DVD playback requires DVD drive
  • Blu-ray™ playback requires Blu-ray drive
  • For a complete ATI CrossFireX™ system, a second ATI Radeon™ HD 4850 graphics card, an ATI CrossFireX Ready motherboard and one ATI CrossFireX Bridge Interconnect cable per graphics card (included) are required
Dec 12, 2008 | Computers & Internet
Is My Computer Compatible With New Graphics Card?
You need to know if *********** board supports PCI-E, since your new VC is an PCI-E device. Check the mobo's manual if this can support PCI-E, if it is then it will be compatible (the next thing is the OS, check if the card supports your OS).
Jun 07, 2008 | ATI RADEON X1650 Pro, (512 MB) PCI...
HD PLAY BACK
have you tried to update the drivers?
Apr 12, 2008 | Gigabyte 512MB ATI RADEON HD3870 DDR4...
Computers & Internet Logo
288 people viewed this question
Alun Cox
David Payne
David Payne
