Question about SanDisk Sansa e200 MP3 Player
NX-122 I was attempting to install the CD that came with this product. I received a message that the device will not be operational until an update was made. I have attempted to do the update and am unsuccessful. The device blinks constantly and it cannot be used. Please let me know if you have a solution. Thanks!
If the problem you are talking about is a red popup that says "synchronize to continue your music subsciption." try to delete all your songs if you can and put them back on.
Posted on Dec 29, 2007
Ntldr cd boot fault
Computer is booting from a non-bootable source
Many times this error is caused when the computer is attempting to boot from a non-bootable floppy disk or CD-ROM. First verify that no floppy diskette is in the computer, unless you are attempting to boot from a diskette.
If you are attempting to boot from a floppy diskette and are receiving this error message it is likely that the diskette does not have all the necessary files and/or is corrupt.
If you are attempting to install Windows XP or Windows 2000 and are receiving this error message as the computer is booting verify that your computer BIOS has the proper boot settings. For example, if you are attempting to run the install from the CD-ROM make sure the CD-ROM is the first boot device, and not the hard disk drive.
Second, when the computer is booting you should receive the below prompt.
Press any key to boot from the CD
Important: When you see this message press any key such as the Enter key immediately, otherwise it will try booting from the hard drive and likely get the NTLDR error again
Mar 31, 2010 | Computers & Internet
The power light is on, but the monitor is off
This error can be caused by one or more of the below possibilities.
Floppy or CD that is not bootable is cur...
BIOS or CMOS setup is not setup properly...
Hard disk drive does not have bootable f...
The hard disk drive is bad or not connec...
Solution: Floppy or CD that is not bootable is currently in the computer Verify that no floppy diskette or CD is currently in the computer. If a diskette or CD is in the computer that is not bootable your computer may attempt to boot from that diskette or CD causing this error message.
BIOS is not setup properly Additional information and help with getting into BIOS or CMOS setup can be found on http://www.computerhope.com/issues/ch000...
Verify that your hard disk drive is setup and detected properly in BIOS. You're computer should list a hard disk drive installed either under the main page or the drives page in BIOS. If BIOS indicates the drive is not installed or not detected skip to Hard Disk drive is bad or not connected ....
Verify the boot options are properly set in BIOS, almost all BIOS setups should contain options specifying how your computer boots. For example, most computers should have their boot options setup similar to the below example.
 - Floppy drive
 - CD drive
 - Hard drive
Rest your BIOS to default values. Many BIOS will enable users to reset the values to the default settings. If you've tried the above options without success try resetting the BIOS.
Hard disk drive does not have bootable files on it It is possible that command.com or another bootable file may be missing from the hard disk drive. Follow the below steps to possible resolve your issue.
Windows 95, Windows 98, and Windows ME users
Boot from a bootable floppy diskette.
At the A:\> type fdisk <press enter>
If you receive a message no fixed disk present, read Hard Disk drive is bad or not connected ....
If you are able to get into fdisk, choose option 4 to display the partition information. In the partition information, if the System is listed as FAT16 or FAT32 then continue to step 5. If you have a message indicating no partitions defined, no information is on your hard disk drive and you will need to create a new partition. See our fdisk page for additional information.
If you see FAT16 or FAT32 in fdisk press the ESC key until back at the A:\>
Once at the A:\> type, sys c: <press enter> (only do this command if you are using the same operating system that this diskette was created on).
This should return a message 'System Transferred', if you receive bad command or file name and have verified you have typed the command properly, you will need to obtain a bootable diskette with the file sys.com on it.
If system was transferred successfully, reboot the computer and issue should be resolved.
Windows 2000 and Windows XP users
Boot from either your ERD, your bootable Windows CD, or your bootable restore CD.
Once boot attempt to repair Windows. If you're able to repair Windows remove the disks and reboot the computer.
All users
If your operating system is not listed above or the above steps did not resolve your issue you can also try erasing the hard disk drive and starting over.The hard disk drive is bad or not connected properly
If you have attempted all above suggestions and you are still encountering the same issues, verify the connections are properly connected to the computer if the hard drive was recently installed or the computer was moved.
Unfortunately, if all connections are setup properly and all the above recommendations have been attempted, it is likely that the hard disk drive is bad and it will need to be replaced.
Or:
Cause:
This is an expected operation. In the Boot Device priority setting in BIOS, you will see Removable Dev. (floppy), Hard Drive, ATAPI CD-ROM, and typically last is Intel® UNDI PXE 2.0. This setting will attempt to boot off a remote agent using the onboard NIC. By seeing this message it means the PC cannot find a boot partition on the floppy disk, hard drive or the CD ROM to load the operating system. Solution:
Install an operating system or put in a bootable device into the floppy or CDROM. If you do not plan to boot to a remote boot host, you may disable the Intel® UNDI PXE 2.0 option from the BIOS setup utility boot order. Relevant Information: No operating system installed
C drive does not have an operating system loaded
No bootable floppy diskette in diskette drive This applies to: Intel® Desktop Board CA810E
Intel® Desktop Board D810E2CA3
Intel® Desktop Board D810E2CB
Intel® Desktop Board D815EEA/D815EPEA
Intel® Desktop Board D815EEA2/D815EPEA2
Intel® Desktop Board D815EFV/D815EPFV
Intel® Desktop Board D820LP
Intel® Desktop Board VC820
End of Interactive Support Announcement
These products are no longer being manufactured by Intel. Additionally, Intel no longer provides interactive support for these products via telephone or e-mail, nor will Intel provide any future software updates to support new operating systems or improve compatibility with third party devices and software products.
THESE DOCUMENTS ARE PROVIDED FOR HISTORICAL REFERENCE PURPOSES ONLY AND ARE SUBJECT TO THE TERMS SET FORTH IN THE "LEGAL INFORMATION" LINK BELOW.For information on currently available Intel products, please see www.compaq.com and/or developer.qompaq.com
Comment by Beni S-P, posted on Oct 26, 2007
And i forgot :
check power suplay and ram???Let me know if u get help???
Oct 30, 2007 | HP Compaq Business nx7010 Notebook
When i install the window xp than sound driver is not working so i want the sound driver . my pc product code is AZ001064
There are 4 ways you can download and install audio drivers :
1.From Device Manager
(1).Click Start, type Device Manager in the Start Search box, and then press ENTER.
(2).In the Device Manager dialog box, expand Sound, video, and game controllers.
(3). Right-click the device, and click Scan for hardware changes.
You should see a message that a hardware device is being installed. Additionally, the uninstalled audio device is now present in Device Manager.
(4).Close the Device Manager dialog box, and then determine whether you can hear sound.
2.From the motherboard or installation CD - If your computer came with a motherboard CD, the audio drivers should be on the disk.
3. From manufacturer's website - If you don’t have the CD go to your computer manufactures web page to search for updated sound driver software. Read the instructions on the download pages carefully before installing.
4. Microsoft's Windows Update feature : If there are no updated sound drivers available, use Microsoft's Windows Update feature. Connect to the Internet and try the following items until Windows Update opens:
(1).Click Start, and then click Windows Update (if it is listed).
(2).Click Start, click Settings, and then click Windows Update (if it is listed).
(3).Click Start, click All Programs, and then click Windows Update (if it is listed).
(4).Go to Microsoft's Web site and click Windows Update from the Downloads menu.
Mar 17, 2010 | Computers & Internet
Netgear wg111v3 adapter quit working with an error message
Go to the Netgear website, and download the newest software update. I was running 1.4 from the provided CD and got this message. I completely uninstalled 1.4 and installed 2.0.0 and it works like a treat now. All you need is the updated software.
Dec 29, 2009 | NetGear : WG111 54 Mbps Wireless USB 2.0...
I updated n73 mobile it is not working
hi, i had this problemonce with the n95, i tried re installing the software, it took about 3 attempts but it did work
Jan 02, 2009 | Nokia N73 Cellular Phone
One of my neighbors own a 1GB "Naxa (NX-122)" media player with an FM radio included. He asked for my help finding the solution(s) to his problem(s) (since I'm currently studying electronics...
Could be corrupt firmware.
Try running the Recovery or Restore software which should be on the product CD. This varies between different manufacturers.
May 01, 2008 | Audio Players & Recorders
I bought a refurbed H100 Digital Audio player and proceeded to try to install the cd software on my pc. When I put the cd in my drive it comes up with a message easy start cd Your operating system...
Select yes on updating from the internet. Sometimes the files on your computer may not cooperate with older software. If the download is from the factory website of the device, it should be a safe download.
Apr 04, 2008 | Audio Players & Recorders
Won't power up
- Floppy drive
- CD drive
- Hard drive
All users
Or:
Cause:
THESE DOCUMENTS ARE PROVIDED FOR HISTORICAL REFERENCE PURPOSES ONLY AND ARE SUBJECT TO THE TERMS SET FORTH IN THE "LEGAL INFORMATION" LINK BELOW.For information on currently available Intel products, please see www.intel.com and/or developer.intel.com
And i forgot :
Nov 20, 2007 | IBM ThinkPad T20 Notebook
Hi pc wont start
- Floppy drive
- CD drive
- Hard drive
All users
Or:
Cause:
And i forgot :
Nov 03, 2007 | HP Compaq Presario V2000 Notebook
SanDisk Sansa e200 MP3 Player Logo
21 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Mohamed Ismail
Mohamed Ismail
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
