Question about CTX S762A 17" LCD Monitor
Monitor too dark
My StarLogic monitor is not set right - all pictures and videos are way too dark and almost impossible to see without holding the button down ( on the monitor) and still it comes back dark. Anything I can do to fix this?
Thanks
  • 3 more comments
  • mewtoo Dec 29, 2007
    I have no idea what that means. Please tell me what to do to fix it. Thanks.
    I just spent ten dollars to have someone tell me to solder something? If this is the 'help'
    I just paid for I'd really like to be reimbursed.
    Thank You
    would someone please tell me where to go to request a refund?
  • mewtoo Dec 31, 2007
    No octacon, troylove11 was not absolutely right and I'm sorry you have such faith in him/her. This is not what I nor others consider technical help, but rather just something to say, it was obvious the problem was not even given the rightful probing and it most certainly didn't even come close to resolving this.
    Hello smilemaker,
    Thank you for trying to give me more ways to fix this, however I have no idea how to update the drivers. Could you possibly let me know how to do it.
    Thanks
    President:
  • 1,944 Answers
To get a refund you need to send an email to experts@fixya.com.
I would like to add that troylove11 is absolutely right.
Posted on Dec 31, 2007
  • 1 more comment
  • Damen Wong
    Damen Wong Dec 31, 2007
    To update your monitor driver.
    - right click my computer
    - select properties
    - click the hardware tab and click on device manager
    - expand monitors and double click the monitor listed
    - then pick update driver
    - then a wizard opens
    - you can try a windows update search if you want
    - if not then point to specific location where the downloaded driver is located
    - download the LCD driver from here
  • Damen Wong
    You can also download the driver from the CTX support site here.
  • Damen Wong
    Say, did you try to reset and then autotune your monitor?
  • 790 Answers
Send an email to experts@fixya.com
before that i like to help u ... Just give a try updating the display drivers ...
  • Kanth raj
    Kanth raj Dec 31, 2007
    Take the motherboard cd ... and update the display drivers from the cd..
    Genius:
  • 1,153 Answers
You have caps in power supply going back, or leaky
Posted on Dec 29, 2007
  • Lashawn Robinson Dec 29, 2007
    This is a problem that you would have to solder out a part and solder in a new one. If you are not familiar with this, then it's not for you to try. You would have to take monitor apart and find the power supply and locate the leaky capacitors. You may need a tech to do this, sorry.
    I am sorry but I don't see any other way except to go inside of unit. I can only tell you what I think you need. I talk to people like you everyday with problems like yours most of them are happy with the info and some are not. I would be glad to go into more details with you if you decide to open it up.
My Starlogic monitor fails to power up. We had a recent power outage. Everything else on the computer seems to work properly however when I power up the pc the monitor will not turn on. Have manually...
Not sure if you have done this so give this a try.
* If possible, plug your Starlogic monitor into another working computer. If the Starlogic monitor works then it is the port on the original computer that has gone bad. The solution would be purchasing a new video card such as PCI or AGP video card. (Assuming all other aspects of your PC are working fine)
*However, if the monitor does not work then you know your monitor is dead. You will need to buy a new or used monitor. **You may want to barrow someone's monitor and test your original computer just to make sure the port on that original computer is fine.
Jun 16, 2010 | Star Logic 17" LCD Monitor
StarLogic- Out of range
The computer needs its screen resolution reducing or changing in aspect ratio to suit the StarLogic monitor. Use a previously-working monitor and reduce the resolution on the computer to 1024 x 768 pixels or less (right-click an unused part of the desktop, click Properties and select Settings; slide the resolution slider to the left to adjust). The StarLogic monitor will now work; plug it in - do the resolution adjustment again as above, but increasing the resolution until you are happy. Going this way around, your computer will failsafe back to the previous (lower) resolution if the monitor says Out Of Range again, so you cannot lose the display along the way..
Sep 07, 2009 | Star Logic 17" LCD Monitor
Intstalled starlogic moniter to PC and got error message
the "Out of Range" message usually appears when the video card is putting out a video resolution or frequency that the monitor isn't able to handle. You should reboot your computer and BEFORE the Windows screen shows up, press the F8 button once every half-second. THis will bring up the boot menu for Windows. Select "Enable VGA Mode" and press enter. THis will load Windows in VGA mode where the screen resolution will be 800x600 @ 60Hz. Any modern monitor is able to use this. Once you log into Windows with the basic video settings, you can go into the Display properties within Windows and bump up your resolution and frequency as needed.
May 11, 2009 | Computers & Internet
Starlogic 17'' as dual display not clear
Check and see if your NVIDIA drivers are up to date. Then try changing the resolution on your laptop to match the native resolution on the monitor and see if it works. If it does then you will need to look for the option to set custom resolutions on each monitor so that you can have both devices working at diferent resolutions if 1 is wide screen and the other is not.
Let me know if this does not work and you need more help.
Apr 20, 2009 | Computers & Internet
Black flickering line vertickally through monitor screen
It could be either of these:
You're monitor is dying and you need a replacement (Starlogic brand is notorious for dying early and giving poor performance)
You're graphics card is going out. If you have an extra monitor laying around, take out the Starlogic one and plug in the other to see if the same results occur, if not, it's the Starlogic monitor, if the problem still persists, you need a new graphics card or need to update your current drivers.
Dec 15, 2008 | Star Logic (11004998) (Black) 15 inch LCD...
17" starlogic monitor model M19BNK serial M9B49CKVoo4584
blown capacitors on the vga board or the resolution for the display adapter is set too high for the monitor reduce the resolution in safe mode and you should be ok, if not then the bad capacitors are in need of being repalced
Sep 17, 2008 | Star Logic 17" LCD Monitor
Dark
It could be a few things, it may be the monitor itself, which naturally has dark picture.
Or by factory default the monitor has low brightness.
Try going into the menu and putting the brightess up.
Most monitors have low brightness by default.
have a happy new year.
Dec 29, 2007 | CTX S762A 17" LCD Monitor
19" starlogic monitor
If you are getting a "No Signal" message, someone may have inadvertantly pressed the wrong button on the monitor. Use up arrow of button #5 below to cycle through RGB (normal VGA connection) and DVI sources. Down arrow will result in "No Signal" message.
There are five buttons at the bottom of the screen on this monitor. From the left:
1 - sound volume
2 - degausser
3 - power on/off
4 - monitor set-up
5 - RGB/DVI source
Nov 20, 2007 | Star Logic 17" LCD Monitor
CTX S762A 17" LCD Monitor Logo
111 people viewed this question
Top CTX Computers & Internet Experts
Rommel Balcita
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
