Question about Tomtom ONE GPS Receiver
I had the same problem...and let me tell that I was desperate... but there's a very easy solution
go to the menu file/device/tools/help
top of the left side
go to tools and choose latest maps guarantee
there you can download and install a new map
and there you go
i don't speak english very well but i just want to help all of you
hope you can fix the maps not found problem
Posted on Feb 07, 2009
Hi All,
I too had the same problem. What a pain in the @$$. Here's what I did... after I tried everything under the sun I finally decided to Log In... even though it says you don't need to in order to do updates.
So I created an account.
Then I updated with the TT ONE New Edition software.
Then I closed TT HOME program.
Then I clicked the icon at the bottom right of the screen for safely removing devices and clicked to remove the TomTom.
Then the TT ONE updated itself and I got my map back.
Good Luck!
Posted on Jan 01, 2008
0 characters
3 Points
My A350 satnav will not charge from laptop message USB not recognised any ideas?
It shouldn't matter. The USB is just a permanent 5 volts supply with data exchange pins. You could of course load the software for the sat nav to the computer. This is used for updating maps, software and firmware.
Ah, I see it is Binatone, which regrettably is cheap nasty stuff. Having said that it has all the features of my Garmin except Lane Assist, which was my reason from updating from my first Garmin.
I found this in your manual
Where can I get technical support?
Please contact our help line 0845 345 9677.
Where can I get software updates?
Please contact our helpline or your retail store for information about software
Where can I get additional maps and guides?
Please refer to (looks like this has been hijacked. Time for a Garmin :>)
Your manual
Jul 19, 2016 | GPS Devices
Garmin nuvi
This is an indication that the map or map unlock key is either missing or corrupted. If you have registered your unit with Garmin, try connecting to your PC and try downloading the map again. More info on missing maps can be found here:
Sep 30, 2013 | Garmin nuvi 200 Car GPS Receiver
I was updating it and was running late so i unplugged it from my computer and now it sayd no maps found. i have tried to "find the solution and fix it" but the computer says theres no problems...
While updating there shouldn't be any form of interruption. If there is, then it means the files that support the programs will be missing. There fore there might be a couple of problems arising from such interruption.
the solution is for you to connect the gps to your computer, then format it and reinstall its software and get new maps for it. Ensure there is no interruption while doing this.
Complements of the season to you over there.
Dec 25, 2010 | GPS Devices
TomTom One has lost connection with satilet
To regain connection back to th satelite, first remove it and reinstall it back, if it does not connect still, then you have to update the tom tom reciever by connecting it to a computer, remove all the maps on it, the update it from the home website.
After updating, upload the new maps back on it, the you connect it to the car system, after doing this, then you try to use it. If it does the same, then it is due to a poor signal in the area that the gps in not connecting to the satelite.
Take care
Sep 09, 2010 | Tomtom ONE GPS Receiver
No Maps Found!
try re- updating it or see if you can find a map pack (like one for europe or something) from tom tom and load that on. it may have to be loaded onto an sd card for the maps to be read
May 26, 2009 | Tomtom GO 720 GPS Receiver
No maps found when updating garmin with latest maps
I can help you reset and fix your Garmin Nuvi 265WT.
Not starting, getting stuck on the flashing Garmin logo, or a message about not finding any maps, are indications that the firmware / system software inside your GPS has been corrupted.
There are three steps to take to get your Nuvi 265WT running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin 265WT WebUpdater to replace its firmware / system software.
I hope that helps.
Nuvi 265WT Manuals here.
Apr 12, 2009 | Garmin n?vi 265WT Car GPS Receiver
Updating maps
Press the power bar in the upper right c orner for 10 sec. and You will go into servicemood. Ther You can reset and run memorytests, Otherwise Use the lttle pihole under the tape on the bottom side
Aug 31, 2008 | Garmin nuvi 200W GPS Receiver
Need more info, what maps? Are you updating the system or just causing trouble for yourself?
Jul 07, 2008 | Garmin nuvi 250W GPS Receiver
Tomtom1 original
You cannot use a card from another tt. The navcore and maps are for that individual device only. Check the tt forums you can find a wealth of information on them.
Mar 06, 2008 | Tomtom ONE GPS Receiver
Tomtom ONE GPS Receiver Logo
171 people viewed this question
Top Tomtom GPS Devices Experts
Martin Murray
Are you a Tomtom GPS Device Expert? Answer questions, earn points and help others
