Computers & Internet Logo
Posted on Oct 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a VA1912wb ViewSonic monitor. Lately, when I power on the computer, the monitor is black, I press the buttons on the monitor, it takes 5-10min to power up.
Anonymous
Level 3:
  • Master 788 Answers
  • Posted on Oct 20, 2009
Anonymous
Master
Level 3:
Answers
788
Questions
0
Helped
253784
Points
2355
The viewsonic monitor is a good unit.
If the unit takes more than 30 seconds to power up, you have a problem with the power supply and will have to be repaired.
Anonymous
Level 1:
  • Contributor 2 Answers
  • Posted on Aug 12, 2010
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
1384
Points
5
The problem with it taking so long to work or anyone encountering a constant black screen is due to the sub-standard electrolytic capacitors in the secondary of the power supply.
Replace those caps and it will work well again.
2helpful
Viewsonic va1912wb-3 has solid green LED but a black screen
This is a very common problem on this series on monitors. The problem is caused by filter capacitors in the power supply board that have failed. You can rebuild the board and the monitor will be as good as new. Here is a link to repair information for the VA1912wb monitors.
http://www.ccl-la.com/catalog/product_info.php?products_id=90
Sir i am having viewsonic va1912wb black monitor , that was not getting display so please can u give me troubleshoot sir
hi dear friends step 1:check all the monitor wire step 2:if wire is correct then u must take a computer shopkeeper to clear a right solution
OK i hope you are agree with me thanks!
1helpful
2answers
I pushed the button next to the power button now i have no screen, i pu7shed the button again but to no avail, please help
Common failure is the caps in the inverter/power board, look for caps with bulging tops, see example of failed VIEWSONIC monitor due to bad caps: http://s807.photobucket.com/home/budm/allalbums
4helpful
2answers
ViewSonic VA1912wb 19" LCD need sound driver
operation174 -
Here is the driver download page for your monitor:
http://www.viewsonic.com/support/downloads/drivers/?prod_name=VA1912wb
Choose the correct download for your operating system.
Thanks,
videoman7
White static flickering on Viewsonic VA1912wb
Please check the line voltage 220V AC and check the earthing voltage 3V AC..
2answers
The screen is black even though the green light is on
try with another cable, pc if nothing. need to get service.
1helpful
2answers
Your inverter or backlight need to be replaced those are the main components that light up the display.
If you find this helpful please rate so.
Thanks
3helpful
Viewsonic va1912wb monitor goes blank for few seconds and comes back and this happens very often
Your power/inverter board needs to be overhauled.
Your capacitors on the board are probably burned out.
If you open it up and send me a picture , I may be able to tell you if they are or aren't.
There is also a chance a transistor has gone bad on the board.
I repair many viewsonic boards on ebay
bammbammfran
Top ViewSonic Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a ViewSonic Computer and Internet Expert? Answer questions, earn points and help others
