Question about GE WCVH6260F Front Load Washer
No spin at end of rinse
Our 6-month old washer goes through the initial wash cycle but does not spin the excess water out at the end of cycles. Many minutes before the end, the Pause/Start button light starts flashing -> when pushed, the washer starts water flowing into the drum for many minutes but does not ever get to the spin cycle. I cleaned the filter next to the pump and got out some coins but nothing else. Water drains to the waste pipe OK. I do not see any error codes on the display. Please advise.
  • David Steinhorn
    David Steinhorn Dec 30, 2007
    Yes. I paid for the premier service yesterday and your so-called expert has given me worthless suggestions including suggesting that I read the owner manual. Your "service" best suited to someone who doesn't know how to plug their appliance in
  • poei Jan 31, 2008
    I have the same problem with a Bosch WFB2000 frontloader.
    I replaced the front door lock and after that the drain & spin cycle is n the blink
    Any sugestions?
Luckkily I have the washer on a pedestal. No need for the boards or the wet vac. I just put a gallon jug under the drain. Drained out about 1 1/2 gallons of water. I pulled out throw rug reminents, 1.50 in quarters and dimes, hair band, rocks a plenty, a knife, and a lighter. I hope that was the problem and nothing serious was damaged.
Posted on Oct 14, 2008
  • 1,003 Answers
Posted on Jan 31, 2008
See the post for the WCVH6240F
catriver Solution #3
Worked for me - here it is
remove the bottom panel and right in front you will see the pump filter. Get a bucket and remove the filter cover, pull the strainer out and see if it's clogged with lint. If the pressure switch on these models detects too much water in the tub (which you wouldn't be able to see) it will not go into a high spin and do this slow tumble you are refering to. Check this first and see if it operates normally, back.
Posted on Jul 12, 2008
Washer fills on wash won't fill on rinse. Does on old washer and new washer. Checked and plumber said not the plumbing. Help PLEASE
It seems that you are out of cycle; meaning you are washing on rinse phase and the you are not getting water on rinse because you are at the end of the cycle. Try this; set the washer to the end of the rinse cycle, let it spin and stop. then wait 1/2 hour then start a wash you will be at the beginning of a new wash cycle..
Nov 10, 2016 | Washing Machines
My washing machine top loader once reaches the spin cycle, with 21minutes time remaining, it goes back to rinse and repeats the cycle. What is the problem of my washer and how do I fix it? Thanks
If the washing is not distributed evenly by the time it reaches the rinse/spin cycle, it goes back to rinse cycle. Be present at the machine when it reaches the spin cycle. observe the drum to see if it is of balance and swaying to the sides, if so distribute washing evenly. Usually happens if there is a big garment or more with smaller items,
Oct 06, 2014 | Samsung SW62ASP Top Load Washer
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
My GE top load washer is about 5 months old. It fills up and runs through the agitation cycle but then stops at the end spin cycle. The clothes just sit in the water. I checked the hose for kinks and...
I have had this problem with two of my previous washers a top loader and front loader.Each time it was a faulty pump that drains the water from the tub after the wash cycle is complete. If the water does not drain from the tub the machine will not go to the spin cycle. Both of my washers were 5 or 6 years old when this occurred. If the washer is only 5 months old it should be under the manufactures warranty. Good Luck.
Nov 12, 2010 | General Electric WBB2090G Top Load Washer
Maytag washing machine skips rinse cycle
I found this problem with mine intermittently and it was because i had filled the machine too full that it was too heavy to initiate the spin. maybe try a lighter wash?
Jul 03, 2009 | Maytag Washing Machines
Kenmore front-load washer stops at rinse cycle
When the washer initially fills for the wash, is it only hot water entering the drum? Try switching the water temperature between hot and cold as it fills. If any of them show little or no water getting through, it sounds too easy but check to make sure water supply taps are on, and that the cold/hot fill hoses aren't reversed. Remove the fill hoses and check any of the screen filters for blockage (in the hoses and in the inlet water valve). When the machine stops and waits to fill but all you hear is a hum, it sounds like there is power going to the valve but water is not able to get through it.
Mar 03, 2009 | Kenmore 43142 Front Load Washer
SD error code won't go away
Manual says -
"Sd" (Suds Detected)
Did you use regular detergent?
Regular or hand-washing detergents are not recommended
for this washer. Use only High Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's
If excessive suds are detected, the washer will display this
code while running a suds reduction correction routine at the
end of the wash cycle. The suds reduction routine removes
extra suds and assures proper rinsing of your garments. If the
code remains and the wash cycle dial is flashing after the
recovery routine has stopped, re-select your desired cycle
using cold water. Press START. Do not add detergent.
Let me know if this helps, or you would like more information/help.
Feb 03, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Basin will not fill with water during rinse cycle but will agitate and spin.
most new washers have cold water only rinse and spray rinse ck cold water coming into machine during wash if no cold comes in suspect cold side of fill vale not opening ..could be wiring issue or a bad valve
Oct 24, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
GE WCVH6260F Front Load Washer Logo
273 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
