Question about Microwave Ovens
Over the range microwave
My 1988 White Westinghouse KM777 over the range microwave has died and I am trying to remove it from the wall but it will not come off. I presume it is some how attached to a wall bracket. Can you tell me how to detach it?
  • 64 Answers
You remove the three screws at the top that hold the black plastic grill, then you will see two flat-bladed screw heads, when you turn those, they unlock. Be careful, it's heavy! You bring it down then lift from the back.
Posted on Nov 27, 2008
What is the wattage for the white westinghouse microwave model wmw 17778
Open your microwave door and look on the top or bottom, it should be on a sticker.
May 11, 2017 | Westinghouse Microwave Ovens
I have a kitchen aid over the range microwave that makes a humming noise ehen off. Almost sounds like a buzzing transformer. ykhms1850ss-0 Is the model.
Possibly the wall receptacle has been wired with black and white wires reversed and/or the green ground wire not connected.
I had a GE microwave that periodically would buzz white operating but eventually the buzzing stopped.
Sep 16, 2016 | Microwave Ovens
Uninstall Frigidaire FMV156EMA over range microwave?
If you have removed the bolts in the cabinet above, the unit is hanging down on the range. All you need to do is get a helper and lift the front edge a little bit and then lift the edge at the wall up about an inch and lift it off.
Mar 05, 2015 | Frigidaire Microwave Ovens
Remove microwave built in range
I) empty the cabinet above the unit.
2) unplug the unit from the outlet in the cabinet
3) locate the two bolts near the front edge in the floor of the cabinet and remove them. the unit will tip down to the range below.
CAUTION SUPPORT THE UNIT WHILE TAKING OUT THE BOLTS OR THE UNIT WILL CRASH
4) Two people can then lift the unit from the support on the wall.
Aug 22, 2014 | Whirlpool 1.6 Cu. Ft. Over-the-Range...
White westinghouse range
A model number would help, but if it's really old, information may not be available.
If this is a simple mechanical lock which you're supposed to be able to lock and unlock by hand, maybe it's rusted. A penetrating oil like PB Blaster may help.
If it's a relay-drive lock that's controlled by the circuit board, then it may need board repair, etc.
Jun 08, 2013 | Microwave Ovens
We're trying to remove our sharp R-1420B microwave oven off the wall. We're having absolutely no luck. How do we get this off the wall?
I just removed our Sharp R-1420B microwave. Unplug the microwave. Start by removing the two bolts from the top cabinet (one left and one right). Remove the decorative screws (one left and one right) from the bottom support bracket. I used a plastic bucket sitting on the range as support under the microwave (you may need a couple different sizes). Once the bucket is in place, pull down on the attachment brackets where the decorative bolts were located near the bottom. I used a vise grip to attach and pull them down, and they came down fairly easy. By doing this, the top of the microwave should become detached from the wall. Once you allow the microwave to tilt down far enough (you may need to move the bucket or use a shorter one), you should be able to lift the bottom of the unit off the lower support bracket. Now you can just pull it out from the wall.
May 16, 2010 | Microwave Ovens
Trying to remove my Sharp R1830 microwave. We removed the top screws (into the shelf above) and the thumb screws at the bottom of the microwave that clip into the back wall bracket; but the clips seem to...
remove the bottom of micro and filters / with a light look up wher the filter 's are on both sides and you will find a lever that when your pull it .. it will relace from back plate. make sure someone is holding it at this time so it will not fall on range below . ****
Jan 09, 2010 | Sharp R-1480 Microwave Oven
I don't see how you remove it from the wall mount
do you have cabinets abofe the microwave. open and see if the brackets that hold it on are in there.
May 25, 2009 | Kenmore 63792 Microwave Oven
How do I remove an old wall mounted Microwave.
I just removed mine this morning and was having the same problem, though mine did have the screws above going into the unit. You may have to pop the front vent cover off to locate the screws going to the wall bracket, if so remove those. Also,there are 2 tabs on the bottom of the wall bracket that the back bottom edge of the microwave slip into, keeping the microwave from being pulled forward. Tilt the microwave slightly forward and push the bottom back edge of the microwave up to clear the tabs. Hope this helps.
Mar 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How to replace bulb in #3501 Westinghouse Microwave
If there's no obvious removable cover over the bulb (most often on the rear or side) and the owner's manual doesn't address it, then disassembly will be required.
Always unplug a microwave before removing or installing any bulbs.
If it's an over the range type, remove the vent grille across the top and see if bulbs can be accessed there. There may be a panel on the bottom covering the light(s), instead.
If not, chances are you'll have to remove it from the wall, then remove the outer cover. If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
Once it's out of the wall, the outer cover (wrapper) will need to be removed, just as you'll need to do on a counter top model.
On a counter top model, be sure it's unplugged, but otherwise ignore the instructions above this paragraph.
The screws you need to remove should be pretty obvious, but a special driver (such as a T20H type or GTXH20-100) may be needed.
Be sure to put all the screws back in the right holes, since some may be special grounding screws.
Bulbs can be had in most grocery stores, hardware stores, home improvement centers, and big box or department stores.
Many models use halogen lamps. You must not touch the new one with your bare skin, as the oils will shorten the bulb life.
Dec 23, 2008 | Westinghouse WST3501 Microwave Oven
Microwave Ovens Logo
132 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Are you a Microwave Oven Expert? Answer questions, earn points and help others
