Question about Whynter FX-6SW Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D
Water not getting cold
Our water cooler is not getting any colder than tap water, the hot side workd great, any info?
  • 1 more comment
  • eleni97 Nov 12, 2008
    no cold water..
  • Anonymous Mar 15, 2014
    water cooler
  • Anonymous Mar 30, 2014
    Water will not dispense from the cold water tap o
How do you check the compressor?
Posted on Jul 18, 2008
    Sergeant:
  • 263 Answers
See if the compressor is working or move the thermostat to a highter level
Posted on Dec 30, 2007
How do you remove cover to get at the taps
Either the taps pull off or unscrew. Think about it, the cover does not fit over the valves, so the valves must be removable .
Apr 06, 2014 | Avanti Hot and Cold Water Cooler
GE Water Cooler Cold Water does not come out, Why?
It works like a fridge or ac. When its charge gets low it can't cool. It will cycle on and off as freon goes around the circuit. Must be leaking around seals or crack in line. A good ac man could check its pressure to determine. Also, thermostat could be going bad, I would check that as well.
Feb 17, 2013 | GE Profile PXCF22RBS Hot and Cold Water...
Shower runs much cooler in winter this is the third go one we have had in the last 10 years all reacting the same way
Hi, going off a previous problem with my shower being colder in winter i found a simple solution. The copper water supply pipes in my house were not insulated and in the colder air that made a dramatic difference in temperature with the hot water being cooler and also because of the much cooler water from the cold supply going into the shower mixer. Please have a look to see if your pipes are all well insulated.
Jan 11, 2011 | Home
Our washing machine is putting out hot water when the temprature setting is on cold ...and cold water when it is on hot. All rinses are hot. What part could be bad?
The water temperature is incorrect The temperature of the incoming water determines the temperature of the water in your washer. You get either hot, cold, or a mix of the hot and cold water that's currently available to the machine. So if the cold water that enters the machine is very cold--or if the hot water entering the machine is very hot--the warm water is affected. If you live in a Northern climate, unless you adjust the hot and cold water taps that supply water to your washer, the warm water supplied to your washer is usually hotter during the summer months and colder during the winter months.
Jan 03, 2010 | Washing Machines
Cooling does not work either
Get in there with a vacuum and clean up the condenser coils then check the compressor relay. If all those are fine bypass the cold control just long enough to see if the water cooler works. Do not leave it bypassed or damage to the reservoir could occur.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 31, 2009 | Hamilton Beach Water Cooler with Storage...
I have a two year old american standerd singel handel faucet Two
Yes, change the cartridge, it sounds like the cold is bleeding into the hot.
Jun 03, 2009 | Oceana 009009022 Udermount Kitchen Sink-...
Cold water doesn't get cold
Having same issue. Water cooler about a week old, in use in a small office with about 10 people and 2 5-gal water jugs consumed weekly.
The chiller for the cold water no longer works, and they display lights on the front and on/off switch in the back no longer light up. The hot water is working, I'm wondering if there is a potential recall issue with the unit.
May 18, 2009 | Avanti Hot and Cold Water Cooler
Oasis water cooler taps started dripping
if the cooler is a hot and cold, even if its a cook and cold, the cooler always needs to be cleaned and maintained, not only on the inside but on the outside, as the cooler is used calcium builds up over time. that is why your taps are leaking, there is a build up in the taps, therefor the taps are not sealing properly and letting some water thru. i say take the taps out and clean them with vinegar.
the second thing u can do is the taps do come apart into smaller peices once u disconnect them from the cooler. take the taps apart and find the spring located within it, stretch the spring and than reconnect the peices together than reconnect to the water cooler.
Nov 14, 2008 | Oasis P1AQ
Whynter FX-6SW Free Standing Hot & Cold Water Dispenser with Storage, Microcomputer-controlled LED D Logo
676 people viewed this question
Top Whynter Water Filters & Coolers Experts
Tom Chichester
Are you a Whynter Water Filter and Cooler Expert? Answer questions, earn points and help others
